Question about Hotpoint Ultima WF860 Front Load Washer
SMELL PROBLEM It has worked brilliantly so far but now it has started smelling. My husband cleaned all the parts and pipes etc. but it doesn't work, the smell is still there !!!!! I don't know what to do, sometimes it seems to smell even stronger if i do a high temperature wash. I tried to do a cicle at 90 degrees on its own but that didn't work either, what can i do ?
  • 1,028 Answers
Have you tried a wash with chlorine bleach? if not aloow washer to fill with hot water open door pour in 1-2 cups clorine bleach aloow to wash a few min open door and with rag wet in bleach/water and wash inside front door boot rolling it toward you to get into inner portion alow to finish wash and rinse future leave door open a little to allow to air out ..moisture remaing in door boot tends to cause mold/mildew problems are not alone ALL front loads have same issue not just yours
Posted on Jul 17, 2008
I have a stove 61ehdo stainless Steele cooker which tonight has just stopped working I've had it approximately 7yrs . Oven rings etc won't turn on . I was in the middle of making dinner when this happened...
If you smelled a plastic burning smell you've burned some wiring somewhere. You would need to pull out the whole thing and start by looking at the back. I once had a dead mouse that had shorted across the relatively high voltage terminals common on most stoves. You should unplug the stove before doing anything like removing panels. Be very careful. Once you've found the problem you might need to call an electrician to fix it, depending on how brave you feel and where the problem is.
Feb 16, 2015 | Ovens
I have a 2002 Ford Taurus Sedan and I notice there is steam coming out of the hood. The steam is definitely not smoke. When I open the hood the car doesn't seem hot but I notice there is a little...
I'm guessing you have a minor anti-freeze leak.The condensation on the air conditioner piping is normal,as your AC works a lot,every time you select defosteror some other positions on your heater.
Check for a teeny leak coming from a hose on top of the engine. don-ohio
Sep 03, 2011 | 2000 Ford Taurus
I have a Rheem 41V50 gas hot water heater that came with our house. It is producing a terrible chemical smell that permeats the entire house, and is covered with black sooty residue. My husband cleaned...
Check your venting ..chiminy could be plugged.. w/ W/H running,,, burner on.. hold a match or lighter around vent cap at top of heater where flue pipe connects flame should bend toward cap.. check you tube there may be a vid on how to do this...
Jul 27, 2011 | Water Heaters
Product = model 15962 Problem = really bad smell
A good trick that i found was to fill tub with hot water and put a full cup of dishwasher detergent any kind but has to be powdered not liquid detergent. Do this two times in a row and then every month.
Jun 10, 2011 | Kenmore 15962 / 15964 Top Load Washer
I have an Alpine ZL-3 and we can't smell the ozone any more. Our air doesn't smell fresh any more. My husband has been cleaning the ozone plate with warm water. Does this have anything to do...
OK- The plate needs brushing with a bristle brush to get the oxidized crystals and grime off it. If you don't, it will not create ozone. I never use water any more, it rusts the plate eventually. Rust also stops the process. I use rubbing alcohol. Cheap and safer than ammonia...MUCH safer. Blow dry. The only bulb is the radio wave ionization indicator bulb, attached to the round antenna-looking thing. You should wipe the ionizers off with alcohol every 6 months too. If they are gunked up they don't work nearly as well. Look up the Living Air Classic manual.
May 25, 2011 | Alpine Air XL-15 Air Purifier
Need to have a foul smell removed in kitchen
bleach spray in a squirt bottle
1part bleach
10 parts water
pull the pan out from under the fridge, clean it
lift stove top, clean underneath
if dishwasher present, spray it and cycle
if garbage disposal present, spray and cycle
if A/C ducts in floor, open and clean
also, replace air filter, turn on blower, and spray solution into return
use your nose and try to find the source
Jun 27, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Washing machine was making noise when agitating & spinning
This sure sounds like a bad transmission. Turn the transmission by hand to feel and listen to it. It should be smooth and quiet.
May 04, 2009 | Maytag PAV2300 Top Load Washer
Smell with fridge
we had travelled to see grandmother for two days. Apparently my husband switched off the electicity from the mains. Came back found food in the freezer had defrosted meat, fish, liver etc and there was blood in it. i cleaned and all was well. After a week started to notice a foul smell coming from the back of the fridge where the stainless steel is. IT keeps getting bad by the day
Aug 15, 2008 | Refrigerators
Dryer burning smell
Have you painted or stained in your house or apartment recently? The smell gets everywhere, dryer, stove, heating unit. I recently primed with Kilz and the clothes from my dryer smelled burned. When I called for service, it was the first question the service person asked and said they made a lot of useless trips only to find nothing wrong with the appliance. That was my case. I had to rewash clothes and let the dryer run with towels for a while
Jan 22, 2008 | Dryers
Hotpoint Ultima WF860 Front Load Washer Logo
102 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
