Question about Dehumidifiers
Connection for continuous discharge
I have a dehimidifier, and am embarassed to admit I failed to write down the model no. I want to connect for continuous discharge into a sump rather than use the container which I have to periodically pour out. I have a short plastic pipe section which is threaded on one end for a hose connection. I can't find my manual.
Is this simple? I looked and couldn't see how to connect??????
Thanks.
Richard Wagner
Knoxville, TN
  • Anonymous Jul 19, 2008
    I have the same problem. Frigidiare informed me they NO LONGER make dehumidifiers. They sold the product line to some Korean? corp. After 15 hone calls and leaving messages, NO ONE has tried to help. Talk about NO SERVICE!!!!
There unit should have come with a small plastic tube. One end should have a thread connecion for hose hook-up. There should be an opening on the back of the unit that you push the tube through to connect with a little elbow tube inside the unit. You should be able to see the elbow connector from the front of the unit by removing the water bucket. Just push the plastic tube in from the back until it fits snuggly over or into the elbow tube and replace the water bucket. Run the connected hose to your sump pump.
Posted on Jul 21, 2008
Model AD50USS1 Dehumidifier, discharge hose is hooked up, but machine still empties water into the bucket, how do i get it to discharge through hose?
The problem is that either the discharge hose is clogged, to long. 48" is the standard length. In addition, the hose connector on the unit and it's interior tubing may be clogged.
The hose is easy to check for a clog. Simply remove it and either look thru it or blow thru it. If the hose is clear, the clog is in the hose connection and/or the inner drain tubing. To unclog it, do the following.
Turn the unit OFF & unplug it.
Using an appropriately sized, 18" long, plastic Zip Tie, carefully insert the tip of Zip Tie into the hose connection & tubing. Continue to push it in until you reach a bend in the tubing. You will need to gingerly work the Zip Tie past this bend, until it either bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip Tie back out while rotating (twisting) it. This will breakup any clogs. As you reach the inserted end of the Zip Tie, be prepared, as some water may follow.Reconnect the hose, plug the unit in and turn the Master ON/OFF Switch to ON. Set the humidity extraction level to 35% or Maximum if you have a manually controlled unit. Allow the unit to run, while you monitor the hose end, for water flow. It may take 10 minutes or more for the water to start flowing.
NOTE: If you don't have a Zip Tie, you may use something similar ( i.e.a long pipe cleaner), but NO wire coat hangers
Hope this helps you unclog the problem. Thanks for choosing FixYa.
Aug 21, 2011 | Whirlpool AD50USS Dehumidifier
What size of hose or tubing do I use to connect directly to my de humidifier, to drain directly into a drain. Thanks. I have model DDR451
A 48' long piece of garden hose will work fine. Connect the female hose connection to the unit's hose connector and be sure that the hose slopes down and straight to the floor drain. Drainage thru the hose relies entirely on gravity. Be sure to set the humidity extraction level low (32 - 35%) for continual operation.
I hope this helps you and thanks for choosing FixYa..
Aug 18, 2011 | Danby DDR451 Dehumidifier
The water/mositure won't discharge through the hose into the drain; instead, it collects in the bucket.
Hi! Either the hose is clogged or the hose connection on the unit or the interior tubing to the hose connection is clogged. OR the hose is over 5 feet long. OR the hose is not sloped downward from the unit. The unit depends on gravity to drain thru a hose.
To clear a clog in the hose connection and/or the interior tubing:
Use an 18" long plastic Zip Tie or something similar that is appropriately sized to fit the inside of hose connect and tubing (NO wire coat hangers though). Carefully insert the Zip Tie into the hole and continue to push it in, until you reach a bend in the tubing. You must, gingerly work it past the bend, until the Zip Tie bottoms out or you run out of usable Zip Tie. Slowly pull it back out while rotating (twisting it). This will help dislodge any clogs. When you start to reach the inserted end of the Zip Tie, be prepared for some water to follow.
Hope this helped you to solve the problem. Please let me know. Thanks.
Jun 16, 2011 | Haier HDN655E Dehumidifier
Unit not discharging through garden hose. Just cleaned unit inside and out. Works great, BUT, only discharges into its container. What am I missing. Cleaned all hoses - no blockages. What should I be...
The blockage is not in the hose, it's inside the hose connection drain tube. To clear this clog, you will need an 18" long plastic Zip Tie, sized to fit into the drain hole. You can use something similar, but NO wire coat hangers. Carefully thread the Zip Tie into the hole and continue to firmly, yet gently work it in, until it reaches a bend in the tubing. You will need to gingerly work it past this bend, until it either bottoms out or you run out of Zip Tie. Then slowly pull it back out while rotating it. This will help remove the clog. Once you have pulled it almost all the way out, be prepared for some water to follow.
That should solve the problem for you. Please let me know. Thanks.
May 26, 2011 | Danby DDR586R Dehumidifier
My dehimidifier quit running..outlet is good where can I take it in WA
Call the manufacturer (Therma-Stor) at 1-800-533-7533 for advice on servicing this unit.
http://www.thermastor.com/service.aspx
Oct 08, 2010 | Santa Fe (4025081) Dehumidifier
My dehimidifier is not draining thrrough the hose
Run a straightened coat hanger through hose or try to blow through. Or connect to faucet to clean out clog.
Make sure drip pan is clean & level. Basically vacuum any dust from inside drain area.
Apr 14, 2010 | DeLonghi DE500 Dehumidifier
Why does my bucket fill when I have connected a continuous feed hose for discharge? The hose does not seem to empty the humidifier.
Check to make sure the drain hole connection on the Dehumidifer's reservoir, that you have the hose hooked to, isn't plugged.
Also, you might want to see if the hose connection on the reservoir, still has the "knock out plug" still in place. Look at the hose connection on the reservoir, and if you can't see through it, or put a screwdriver through it, you need to punch it out the middle with a screwdriver. Open up the hole as much as you can so it will drain into and through your hose.
Check your hose also, as it might be plugged, disconnect it and blow through one end to make sure the water can flow through it.
Those are the only three things that could be preventing it from draining out the reservoir, through the hose connection, and through the hose to your drain.
Hope you find this Very Helpful and best regards!
Aug 23, 2009 | Dehumidifiers
Cant find our user guide to the maytag dehimidifier m7dh45b2a, is there somewhere i can down load it or print a copy?
hi ... try to log on the official website (if there's any) of the product manufacturer and then search for the manual of your product... then look for the printable copy... thank you very much...
Jul 07, 2009 | Maytag M7DH45B2A Dehumidifier
Have an LG dehimidifier which seems to have stop working
Could be a failed compressor start relay. They are replaceable. Get one at an appliance parts store for your model or a generic one. Make sure you are unplugged before changing.
Jul 01, 2009 | LG LHD45EL Dehumidifier
Dehumidifiers Logo
259 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
