Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore ice maker
Side by side Refrigerator w/ ice maker. The timing is too fast, tries to empty ice before it is solid and what gets sprayed everywhere inside the freezer.
How do you slow down the timer??
    Scholar:
  • 52 Answers
The time can be easily adjusted. You can find instructions here http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Posted on Jul 17, 2008
Why is my icemaker not working on Sears Kenmore 50562991
Two of my refrigerators stopped making ice because of frozen water lines going to the ice maker inside of the freezer door. I thawed the lines by unplugging the refrigerator and used a hair drier around the ice maker till all the frost was gone. After I plugged it in I heard water going to the ice maker. If you remove the ice bin you can check the ice tray to see if it has ice in it. If it is empty it is not getting water. It could also be a bad Solenoid Water Valve.
Jul 08, 2014 | Kenmore Side by Side Refrigerator
I have a Kenmore model number 106.51552104 my ice maker stopped making ice.. The water on the door still works but no ice what should I do??
I believe I answered this one on another page of unsolved problems HERE. Thanks for the model number. If the ice slots inside the ice maker are empty try pouring tap water in the slots and allow the water to freeze. If after the water freezes the ice drops into the ice bucket and the ice maker does not refill this would indicate that the side of the=> W10408179 Water Inlet Valve is defective on the side that controls ice maker water supply. If the ice maker just sits there and does nothing this would point to a defective ice maker. Depending what is wrong with the ice maker will determine what parts are replaced. Here is a list of those parts here=> Kenmore Refrigerator Model 106.51552104 Ice Maker Parts and if need you may be able to find a complete ice maker replacement by asking. Most people don't like replacing ice maker parts. I am here should you have questions or comments, Sea Breeze
Aug 30, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refrigerator Elite Mod # 106.55602400 is not making ice
Is the food frozen solid in the freezer? Does the ice maker get any water to it? Do you see any ice buildup in the freezer?
Jan 19, 2013 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Aug 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
Kenmore Side by Side not making ice
This problem is most likely the water control valve on rear of refrigerator. If your ice maker is empty pour tap water inside it and let it freeze. If it dumps the ice then the water control valve. If nothing happens the the thermostat inside the ice maker is defective. Thanks, Sea Breeze
Aug 18, 2009 | Kenmore 57029 Side by Side Refrigerator
No 110 volt to icemaker
additional info:
it has an infrared beam, so on both side walls has an eye. Also on the right side there is an on/off switch.
Apparently the eyes work Ok because pilot light blinks when the door is open and is solid when I move the plastic arm that cuts the beam.
Mar 05, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side by side - icemaker seems to run too fast because the ice cubes are often hollow and they stick together in large clumps. Everything else in the freezer is frozen solid, so I know the freezer...
IF FREEZER IS A THE CORRECT TEMP/ O-10 DEGREES, THE FREEZER IS NOT THE PROBLEM. THERE IS A THERMOSTAT IN YOUR ICE MAKER, IT IS NOT ADJUSTABLE. IT IS A SMALL BI METAL SWITCH THAT TRIGERS ICE MAKER WHEN IT REACHES ITS PROPER TEMP. THE PROBLEM IS, IT IS TRIGERING IT AT TO LOW OF A TEMP.NOT ALLOWING THE ICE TO FREEZE SOLID. IF YOU CAN HANDLE IT CHANGE BIMETAL SWITCH OR CHANGE ICE MAKER ITSELF.
HOPE WE HELPED YOURS TRULY FXIT
Feb 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Your motor module is bad on the ice maker. It is located on the left side when mounted in the refrigerator. It is under the White Cover over the end. It is brown in color. To verify the correct problem, the ice stripper arm in the ice maker that turns and pushes the ice out of the mold, should be pointing up towards you when it is in the mounted in the refrigerator. I call it the 2 O'clock position. If the ice stripper arm is pointing another direction, it is broken. I sell the module on Ebay as username, themackshack. My parts are genuine factory parts. Good luck!, Mack
Jan 08, 2008 | Kenmore 50522 / 50524 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
44 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
