Question about GE GSH25JSTSS Stainless Steel Side by Side Refrigerator
Freezer door handle loose
The freezer door handle is loose and pulling from the door on the bottom. Can I fix this and how do I fix it, or do I need to buy the parts? Please advise - thanks!
  • Anonymous Aug 22, 2008
    ZFSB23DRG SS
    Side by side refrigerator handle has loosened. Had to call an expensive (!) technician to tighten a few screws...should have stuck with a cheap Maytag.
Use a 3/32 Allen wrench to tighten the screw on the side of the door handle
Posted on Jul 19, 2011
GB2FHGXB01
Are you sure of the model number? I don't see a Whirlpool GB2FHGXB01 ; I do see a model GB2FHDXWB01.
For this model, there are several different door handles. One has a Philips head screw hidden under a trim piece. To expose the screw firmly push the trim away from the center of the handle. (This is for a standard Whirlpool fridge door handle.)
The French door style refrigerators have slightly different door handles. One uses Allen screws as set screws to secure the handle. (This screw needs a 3/32" Allen screw (hex key) and you can access it through a small hole in the underside of the handle on the loose side.) Be careful not to overtighten the screw or you may strip the threads and have to replace parts.
The other option has the handle mounted on brackets on the door. To access the bracket, grasp the freezer handle and pull it to the left. Then pull the handle away from the refrigerator.
For pictures of the handles, see pages 9 and 10 of the manual. It's available here: https://www.whirlpool.com/digitalassets/MLPDF/User%20Instructions%20-%20W10366204.pdf .
I hope this helps. If you do have the GB2FHGXB01, check if any of these directions help. Most refrigerators use one of the above door handle designs.
Apr 28, 2012 | Whirlpool GB2SHDXP Bottom Freezer...
Bottom freezer pull out door handle is loose. How do I tighten it?
if there are no visible hanlde screws( sometimes tiny allen wrenches under handle VERY SMALL).. if not the the handly merely pulls off to the left, and then the mounting hardware can be tightendd ad refit by sliding back to the right
Oct 13, 2010 | Amana ABD2533DEW / ABD2533DEB / ABD2533DEQ...
u could always set the handle in place where it needs to be and use caulk or super glue to go around the handle and that should help it stay in place if that doesnt work the website www.amana.com to see if it has warranty for the broken handle good luck
May 26, 2009 | Amana ABD2233DES Bottom Freezer...
Amana, model # AFD2535DES, bottom drawer freezer handle loose
sure , if you look underthe handle is there perahps a small screwhole in which you can tighten handle??this may be prior year in which case if there are no screw holes present you need to grab hold of handle and with a "brisk" pull to the right it will come off hiddenclips, the clips can be t ightened and resecure by snapping back the oppisite way the handle pullled off
Feb 12, 2009 | Amana AFD2535DES French Door Refrigerator
Bottom freezer door handle loose
There is a plastic card that you are supposed to slide under the right side of the handle. Once you have done this correctly the whole handle should slide off to the left.
Nov 14, 2008 | Amana ABB1927DE Bottom Freezer...
Bottom freezer handle
At both ends and actually inside the ends of the handle, are small metal brackets that are attached to the door face by a single screw.
You access the screws by pulling the plastic plugs, using a very small and thin flat bladed screw driver.
My handle was loose but hadn't come off on it's own. But I couldn't get the handle to fully tighten.
My fix was to wrap each end bracket with a couple layers of electrical tape (not covering the screw hole) and reattached the handle.
It is now very tight, as it should be.
Jul 17, 2008 | Amana ABB2227DE Bottom Freezer...
Loose handle on fridge freezer door.
that handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
Mar 08, 2008 | Amana AFD2535DES French Door Refrigerator
Loose handle on door
grab hold and pull straight up!! itll be tight but just pressured on, theres an mounting screw under there, then just pull back down and on
Feb 25, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Loose freezer door handle
Maytag uses two types of door handle mounts. first look at the bottom side of door handle to see if there are tiny set screws. If there is you might just have to tighten them with an allen wrench. If it doesn't you need to grasp the handle firmly and pull it towards your left, sometimes they can be a little stubburn and require a light wrap with a rubber mallet. This will remove the handle. In this case there will be a clip inside the handle end, check to see if it is bent or if the handle itself is cracked, although I have seen some where the handle mount has become loose and that can be tighted by turning clockwise.
Jul 04, 2007 | Maytag MBF2556HEW / MBF2556HEB /...
GE GSH25JSTSS Stainless Steel Side by Side Refrigerator Logo
284 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
