Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WS model 55613
Our tv is 4 years old and the Picture is wavy
in the past after the set "warmed up" the picture would correct itself, now it is wavy all the time some more than others but it does not correct itself.
What is the problem??
  • 1 more comment
  • jeffrilo46 Jul 16, 2008
    no magnetic items near the set.. try something else, please.
    already tried that, did not fix the problem.
    try again.....
    thanks..
    PiP has the same problem.
    thank you!
  • 304 Answers
This is a picture of the DM Board in your TV. The wavy lines are tell tale signs of a failed capacitor. The capacitors are the cylindrical components on the board. One or more of them have failed. There is also a FMT Board with capacitors that could be causing this also so test them all. The DM board alone is 1000 bucks so it would be well worth it to invest in 50 bucks worth of capacitors and change them all out. Your boards would be fresh and good for another 4 years.
Your other option is to call a TV repair man and he would come pick up your boards and bring them back to his shop and test out the bad 3 dollar capacitor and swap it out and hand you a bill for 500 bucks.
Hope this helps you out.
George
Posted on Jul 16, 2008
  • 4,234 Answers
Normally a wavy picture or lines/bars that roll up or down are caused by defective capacitors in the power supply. This defect allows 60 cycle hum to progress through the signal paths and will show up that way. These "bad caps" can often recover sufficiently so it looks like everything works OK. This should not be an expensive repair. If you can solder, you should be able to repair this yourself. Let us know and additional details can be posted.
Dan
  • ABRsvcs Jul 16, 2008
    By the way, there is no "reset" that will fix this problem. This is definately one or more defective parts inside the set.
    Dan
    Genius:
  • 1,447 Answers
Hi-
Try checking the cables from the back as wel, try unplugging and replugging it.
Keep up posted for any progress, thanks!
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Jul 16, 2008
    Try the system reset
    Press the SYSTEM RESET button on the front panel with a pointed item such as the point of a ball point pen or end tip of a paperclip.
    The TV will turn off and the green led will flash quickly for about one minute. When the green led stops flashing, you may turn on the TV again. The changes you made while the TV was most recently on, before you used the SYSTEM RESET button may lost, however, the changes you made previously are not lost. Only those changes since the last power On may be lost when the system reset button is pressed. All other settings are retained.
    Make sure as well that V-Chip lock is off.
    here check the manual in here under CRT TV under 2004
    http://www.mitsubishi-tv.com/j/i/18344?t...
    Guru:
  • 1,894 Answers
Wavy picture can be a problem due to magnetic interference near the units.
please have a check at it
  • 2 more comments
  • dewan nafees ahmed Jul 16, 2008
    what about the picture in PIP? is it fine or does that also show the same problem?
    you dint reply my question? is PIP ok or you get waves even in that?
  • dewan nafees ahmed Jul 17, 2008
    Bad hyper board =bad caps on board need replacement
    You have problems with your power supply filters. I'd suggest you to
    change the main filter, that is the capacitor just after the ac
    rectifier and the b+ filter, that is the capacitor at the output of the
    smps, and then vertical filter and video filter. These are all
    capacitors with higher micro farad ratings, if you are not much
    comfortable, it's better to get some help from someone who is familiar
    with these. Pay attention not to reverse the polarity when changing the
    capacitors.
    both the chroma and the luma circuits pass signal through the same tuner - through the PIP - and onto the large signal board.
    so if capacitors dont help the problem to get solved then only the tuner replacement can help you i think.
    thank you
    please keep us informed about your proceedings.
    thank you
Mitsubishi WS-55613 55in.
1. "wavy" may mean a signal problem inside the set--are you seeing colors out of position or skewed around letters etc?
2. Does it do it when a DVD is played? (this will rule out certain things).
SD TECH
Apr 21, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-55613 55 in. rear projection HDTV has no picture but does give blue screen and menus. What is the problem and how can i fix it
The set has three hidden menus, one of which is the option menu--with the Mitsubishi remote and a four digit code in that you can do a hard reset of the entire set---if a glitch has occurred I have seen this fix no sound, bad video, missing inputs, you name it.
It cannot hurt and may help and it is model specific as far as the 4 digit code.
Apr 12, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Model # ws-55613, a short time after the tv turns on there are wavy vertical lines that wont go away. if i turn off the tv and restart it will work for a short time and wavy lines will reappear.
The WS Mitsubishi has a known problem with the Power Supply electrolytic capacitors and the electrolytic caps on the DM board. See my tip at http://www.fixya.com/support/r7065906-mitsubishi_turn_flashing_power_timer for more detailed information. The problem you are describing would be the first part of the known problem. There are several repair/replacement choices listed in my tip.
Thanks for using FixYa and for the great rating.
haradrocko
Jun 16, 2011 | Mitsubishi WS-55613 55" Rear Projection...
Ws55613.picture is wavy, sometimes it happens as soon as you turn the tv on and sometimes it takes hours. the wavy lines eventually become purple and pink. still able to see picture, but very annoying and...
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 24, 2011 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi model WS-55613 screen goes off and on
there is a 9 mvolt regulator on the signal board right behind the input board. that could need resoldering or maybe replacing it should be the IC9A05
May 04, 2010 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi Medallion - The green convergence
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 15, 2010 | Mitsubishi WS-55613 55" Rear Projection...
Wavy horizontal lines running through the screen
Ur tv convergence is dead.U must know how to solders?The 2 STK convergence ICS.and some or all it resistors must change.Tries websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Mar 17, 2010 | Mitsubishi WS-55613 55" Rear Projection...
Distorted picture on a mitsubishi ws-55613 tv
Their is no more you can do.
Seen this before.
You need a professional.
Stop using the TV until it is repaired.
Continue to use the TV and your problems WILL multiply.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Wavy picture
It looks like you have a convergence problem here, probably a defective convergence IC.
Mar 06, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
161 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
