Back to:
Tags:
Scanners
Generic problem for all Scanners
Problems with Starting Up HP ScanJet 3300C with...
posted by epthom on Jul 16, 2008
Problems with Starting Up HP ScanJet 3300C with Vista 86x
I need your help, cause I haven´t got a Driver HP ScanJet 3300C with Vista 86x. In Vista, I´ve already installed driver hp 3300C XP, with previlege Administrator. In Painel Control--> Scanners and Camera, I´ve already been tested. Vista recongnize ScanJet 3300C and test( USB it´s OK) . But when I starting up pgm Win Fax and Scan and I Scan documents in HP, the message Error ( No scanners were detected ). Where´re I can get a driver ScanJet 3300C to Vista.
Thanks
Edu.
The Lord is Jesus.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Scanners problems?
Creo CreoScitex EverSmart Jazz+ Flatbed...
When I scan an item (line, color or grayscale) I get the...
Canon CanoScan LiDE 90 Flatbed Scanner
I have a CanoScan Lide 90 and the scanner bed is jamed and...
Canon CanoScan LiDE 70 Flatbed Scanner
J. R. WESTFALL jrwestfall@cox.net
Kodak i260 Duplex Color Scanner
The scanner mechanically scans without problem, but no...
Canon DR 3080C Path-Through Scanner
is there a way to remove the pre scan window?
Loading problems.
Repair Service
Find Scanner Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
