Question about Xerox Office Equipment & Supplies
Xerox Workcentre C2424 Error Code 39,003.40 - Xerox Office Equipment & Supplies
  • tpreissig Jul 20, 2008
    Called Xerox and they sent out a new scanner for it, no problems so far.
    President:
  • 2,072 Answers
That code it related to the document feeder or scanner.
What I would try is turn off the machine, then disconnect all the connectors from the scanner and document feeder, and espicialy the molex connector next to the power cord near the on off switch, that cable tends to work loose and is odd to tighten as it. Make sure you tighten that one well.
If it is scanner or document feeder related, there are almost no parts spared for those, the assemblies need to be replaced.
There is better then a 50 % chance the cables will fix the problem.
Posted on Jul 16, 2008
I have an error code 07,007.40:10320 any idea what the problem is please?
That is a process motor failure, replace the process motor camshaft kit, part number WCC2424-Z2. The printhead is unable to tilt.
http://www.iteminconline.com/wcc2424-z2_wcc2424-z2-xerox-workcentre-c2424-process-motor-camshaft-kit.htm
Sep 03, 2015 | Xerox WorkCentre C2424DN All-In-One Laser...
System error # 07,010.43:27456 on a xerox c2424 copier
The printhead is stuck in the tilt position, need to replace the process motor camshaft kit, part number WCC2424-Z2
Jul 07, 2015 | Xerox Office Equipment & Supplies
Error code 39,003,40;61256 on a xerox workcentre
Here is the easy solution to fix the issue :
Click on the link and follow instructions to fix the issue.
http://www.pchell.com/hardware/cd_drive_error_code_39.shtml
Dec 02, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox c2424 error code
the error code is "printhead stuck in the tilted position or not tilting properly over the CAM, due to problems with the process motor gearbox" the 6375 is your print count, are you under warranty still by xerox?
-Carl, please let me know if this helps.
Jun 20, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox workcentre c2424 error code
One of two things most likely.
1. The wiper blade is stuck to the print head,or 2, The print head blosk has a lot of spill over ink built up in it.
That code is caused by the inability of the print head to move properly. Either left to right or pivot front to back to get into the print position.
You have to remove the covers to access the stainless steel print block. It is located about 2/3 of the way back on the lower left side of the frame. It is a one inch by one inch square block that may have a lot of buildup of spill over ink in it. If the wiper is stuck you have to remove the ink loader , where you add the ink sticks , to access the area between the print head and drum, It is a pink blade the is between the drum and print head, it wold be stuck to the print head not allowing it to move. Just carefully unstick it from the print head
Mar 27, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
Xerox workcentre c2424 error 37,008.4x
Most likely yes. That contains the power supply for that heater.
Oct 27, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
Printer Problem
What model printer is this? The C2424 does not have a laser.
Are you 100 percent sure it is a model C2424?
There is no LSU status code for that machine.
May 14, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
215 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
