Monitor only works for a few seconds after being turned on. Turning it off and on again brings another second or so.
  • 983 Answers
Check whether the CPU also goes off with the monitor or what ....
if the smps is gone means the both CPU & monitor will goes off after some seconds ....
if only monitor is only getting turned off then some of the components inside the monitor will be dead or it is getting over heated ....
those some components may be like capacitors etc ....
try inserting the monitor with other CPU & check it is it working correctly or not ...
if it is correctly working then there will be some problem in the CPU ...
(if the video adapter IC (intergrated circuit) is getting over heated means also you will face the problem like this ...)
if the monitor is working just like previous i.e it is getting off after some seconds means it s confirm that some of the capacitor is out inside the monitor ...
have a check with these .......
any doubts you can reply me
thank you
bye
Posted on Jul 16, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Jul 16, 2008
    and also check the power supply cable of the monitor .....
    Genius:
  • 2,035 Answers
Try to plug to different power supply and see also check the
monitor on different to check if its computer or monitor problem if the problem exists then the inverter circuit is defective you need replace the board you can get it done local computer service center ,, if the computer monitor still under warranty you can get it done by the company...
Good luck..
    Brigadier General:
  • 3,614 Answers
May i know the monitor monitor model, and the OS that you are using...
THANKS
  • micromaster
    micromaster Jul 16, 2008
    and also a complete explanation & info on the problem, where the specific spot or booting process does the monitor shuts off.
Lg flatron w2353vp
make sure the 'VGA' lead is plugged in properly. if still dark turn up the brightness on the monitor. if still dark after that, go onto the computer settings and turn up the brightness on the display settings.
Hope this helps!!!
Feb 21, 2014 | Computers & Internet
HP 1940 goes blank After 3 Seconds. after turning on this monitor it goes blank if i turn it off then on again it will display the comptuer output again but then turn off after a few seconds. any hints?...
Run a monitor aelf test.... Remove the monitor cable from the back of the tower... and see if it run self test.... also a install the driver for the monitor
Aug 03, 2009 | Computers & Internet
ACER 22" monitor flashes on at PC startup, then goes black
Your monitor has a bad INVERTER, look on eBay.
Jun 27, 2009 | Computers & Internet
Monitor goes blank after first few seconds of turning it on...
There's an internal electronic part/s of your monitor that are cold soldered / defective. I suggest to bring the unit to an authorized service to properly diagnosed & fix the problem. best regards
May 25, 2009 | Proview PT 15.1" LCD Monitor
Gateway monitor FPD1975W won't display
Same problem - unplug both computer and monitor - hold power button for monitor for 15-30 seconds...then power it back on and then power on the computer. Seems from other sites there is a power issue with the monitor - this worked for me.
May 23, 2009 | Gateway FPD1975W 19" LCD Monitor
Monitor show picture for a few seconds, then turns black
It sounds like the power supply board on your monitor is failing. If it's still under warranty you might be able to get a replacement from the manufacturer - if not, you might be able to have it repaired at a computer or TV repair shop.
May 14, 2008 | E-Machines E17T4 LCD Monitor
Monitor goes blank less than a second after turning on.
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Monitor turns off
If the picture is Reddish either at top or bottom It could be the backlight failing.If you are technically able you maybe able to Replace the CCFL backlight.
Samir
Feb 21, 2008 | LG Flatron L1710B 17" LCD Monitor
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
