Question about Pioneer DEH-1000 CD Changer
Speakers won't work
I bought an after-market harness adapter to wire my stereo to a 1991 Ford F-250 pick-up, the prior owner of the truck installed different speakers and now I have power going to the deck, but no sound from the eakers, what do I do?
  • 4 Answers
Are the wires connected to the same colour. e.g. green to green, and each specker should have two wires connected.
Posted on Jan 11, 2009
Trying to install an after market stereo on my 2000 town and country i get no sound
Did the AM stereo come with a wiring harness or adapter to match up with your T&C OEM stereo? If so, look for loose or poorly mated connectors. If not, double-check that the wire splices you installed are secure. Are you using the T&C's original speakers, or did you install aftermarket speakers, as well?
Oct 08, 2013 | Cars & Trucks
Please Help I Need A 1992 Mercury Capri XR2 color-coded Stereo Wire Harness Diagram
Go to your local auto store and get the Hanes auto manual for this care and they should have a wiring schematic for you to follow also you can look your new stereo up on the web and find out what each colored wire goes to what!!! Good luck
Jun 07, 2012 | Lincoln Cars & Trucks
I have an 02 ford explorer, the previous owner had a custom sound system installed. He took allof trhe custom speakers and amps out but left the stereo in,but it does'nt play. the stereo work ands powers...
sounds the like the vehicle had an oem amplifier that was removed, most after market stereo installers will trace the speakers wires individually by continuity to by pass the factory amplifier and wire the new head unit to the vehicles speakers, if the harness has been spliced or factory amp removed, you will need to check if the amplifier still exists (usually under passenger rear seat sometimes located in trunk area) and see if the harness has been bypassed. if so you will have to reconnect the harness by color code in order to use the factory head unit
Feb 18, 2011 | Ford Explorer Cars & Trucks
Whats the proper way to install the cd player into a 1992 chevy pick up truck and if u cud send a manuel
The proper way to install any aftermarket deck into a newer vehicle is to get a factory wiring harness adapter. This adapter will attach to the existing wiring harness for your factory stereo system. You can purchase these from various websites like this http://us.ebid.net/for-sale/1992-chevy-pickup-fullsize-radio-wire-harness-92-17373248.htm?from=googlebase
When you plug this in your factory speakers and power/ground will all be available to wire to your new deck without cutting or splicing any wires. The colors follow the E.I.A standard and should match your new stereo. I hope this is helpful and thanks for using FixYa.
Sep 17, 2010 | Car Audio & Video
I need wiring diagram for in dash stereo I need to rewire harnest for after market stereo
Check this...
1992 Chevrolet Cavalier Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope helps (remember comment and rated this).
Jul 16, 2010 | 1992 Chevrolet Cavalier
1991 Ford Tempo Stereo Wiring
you need a wire harness for your car you can buy them at most auto parts stores make sure and buy the one for your make and model they should have instructions and the wiring diagram most harnesses are color coded and pretty simple to install
May 15, 2009 | 1991 Ford Tempo 4 Door
New Car Radio, New Harness but no power, Nissan P/U '95
here is the factory harness wires and what they do, recheck thayt it all matches up.
1995 Nissan Pickup Truck Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Gray
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Mar 10, 2009 | 1995 Nissan Pickup
I have recently purchased an rx8, but the previous owner had fitted an after market stereo which he took with him. I have 2 problems, i have purchased a double din system which i tried to fit. I was able...
If the unit was installed professionally no wire's will have been cut from factory harness. Yes you would need an aftermarket adapting harness so your speakers will work . Vehicle may also be equipped with a stock amp. be sure to hook remote wire on harness to head unit.
Dec 03, 2008 | Car Audio & Video
Installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
Nov 21, 2008 | 2000 Pontiac Grand Prix
Pioneer DEH-1000 CD Changer Logo
150 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
