Question about Toshiba e-Studio162D Copier
Reset code i get a message that says maintenance requried call service tech
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Toshiba Master
  • 1,362 Answers
Not sure if this is good for your machine;
go to - Sys Admin Tools
goto - clear memory
select- maint counter then clear
Posted on Jul 17, 2008
Reset service message
use a code reader to reset this meaasgae
Apr 07, 2013 | Mercedes Cls-class Cls550 Cls63 Exterior...
Tip
It is not always requried to do this. The brew unit sometimes gets stuck. All...
Malfunction 8 is related to the brew unit typically. It is usually an indication of the brew unit motor having to work too hard to move the brew unit up and down. The mechanism for dumping grounds becomes stuck from coffee grounds not properly waste out. This is usually cured by disassembling, cleaning all the coffee remains behind group, replacing any o'rings that may be bad, and lubricating the unit, then reassembly.
Also some coffee might be on the opt sensor that senses the up/down position of the brewing unit which when it's switched on the mechanism is not synchronizing and it will go all up or all down and show Malfunction 8.
Here is how to fix it without completely dismantle the machine:
Unplug, remove the water tank, pull out the bucket and tray, and allow to cool if necessary. Now - smaller fingers are better - reach into the machine, palm up. Feel as far back as you can, then work your way forward, toward yourself.
As you move toward you will feel a flat area about an inch wide (measuring front to back). Just back of this (away from yourself), you'll feel a crack about 3/8" to 1/2" wide. Push your fingers up into this area and feel around. You will probably feel stuff that feels like light, chunky rocks these are dry “coffee ground”. Break these up and they should fall out.
Again, small fingers are better and if yours are not once you got an idea of what you are doing, you can described it to someone with small ones and can do it. There is a tendency to not feel far enough back in the machine, so be sure to find the flat place at the lowest point of the mechanism then go just past it and up to find the crack.
Pulled out all compressed coffee “coffee grounds” you can fill. You can also get about a foot of plumber's tape (the metal stuff with holes in it that's useful for just about everything) bent it with a 4" radius, and worked it up into the crack to break up any stuff you couldn't reach. Work at this until no more stuff is in there. Now, tilt the machine toward you and "pat" firmly all over to jog anything left into the crack area, and check for chucks again. You can use a vacuum cleaner with slim tube so you can remove as much as possible with it also.
When that's done, put everything back together, move the machine to where you can work from the top. Don't start it up. Get a flashlight and the vacuum cleaner with the slim tube. Open the top "pre-ground" door and S**K everything out.
Now start up the machine, watch how the mechanism works, now, and try to brew some coffee. While it's actually squeezing out the coffee, tap some more on the "closed" mechanism to free up any more stuck coffee. Do this whole procedure 3-4 times to be sure, I suggest don't drink any of the first coffee it brews. Anyway, the machine should run good as new.
Good luck and please comment as to whether it works for you and vote for it.
on Oct 31, 2010 | Jura Capresso Impressa F9 Espresso Machine
Konicaminolta 7216 M2 reset
Resetting the maintenance code display:
1.Entering the Tech.Rep.Mode
Procedure
a) Press the Utility key.
b)Touch Meter Count.
c)Press the following keys in this order : Stop - 0 - 0 -Stop - 0 - 1.
d)Select Tech.Rep.Mode.
2.Resetting the maintenance code:
M2 Waste toner box
Resetting procedure:
a)Enter the Tech.Rep.mode.
b)Select "Counter".
c)Select "Consumables".
d)Select the count of waste toner.
e)Press the clear key.
M3 Oil web roller.
Aug 14, 2012 | Office Equipment & Supplies
My 10 v old daughter decided to play w my phone she put some kind of code and she dont remember what she did when i try to use it . it says lock code requried what do i do
I'd try the last 4 digits of your phone number, 0000, or 1234.
If that doesn't work, you'll have to perform a master reset, which will remove all your settings, contacts and messages.
The master reset option is in your settings menu somewhere.
May 05, 2011 | Sanyo SCP-2700 Cell Phone
How to reset the maintenance requried light on a 1991 dodge d150 --318 engine
take the battery negative cable of the battery for about 10 minutes and then put it back on the battery post
Jun 12, 2010 | 1991 Dodge Ram 150
I have a Oki b6500. Replaced the fuser. How to reset the message exchange, "Maintenance." Please help!
The following procedure was provided by Oki Tech support when a web search did not provide an answer. Resetting the Fuser After Replacement - When Counter is NOT Reset First print out a MenuMap and note the fuser count, to later verify that the maintenance reset has taken affect. To reset the fuser counter, enter the diagnostics mode and go to Maintenance Mode Step-1 How to enter the maintenance mode. Hold the Menu & Right arrow button while powering on the printer. Hold the buttons down until the op panel displays “Initializing”. The op panel will display “Output Test” Step-2 Press the down arrow three times. The op panel will display “Maintenance Info” Step-3 Press the right arrow. The op panel will display “Reset Maint Reqd Execute” Step-4 Press the select button. A quick flash will come up on the op panel “Resetting Maintenance Reqd”. The op panel will then display “Reset Maint. Reqd. Execute” Step-5 Press the Cancel button to exit the Maintenance Mode and go back to “Online”. This completes the process, please print out the Menu and inspect the Fuser Count it should read ‘0.’
May 19, 2010 | OKI B6500 Led Printer
Panasonic DP-8020P Machine Maintenance count reached.
yep. as long as the print quality is good and stable, and the toner consumption is good (8K to 10K of pages per bottle) you can just reset the maintennace count at f7-03 on service mode. probably your machine count reached at 120k. :)
Nov 02, 2009 | Panasonic DP-8020E Black and White Copier
Lexmark T642
There is a great video that shows step by step how to install the fuser, transfer roller, charge roller, pick up tires and then reset the 80 Scheduled maintenance message
Apr 03, 2009 | Lexmark T642 Laser Printer
Toshiba e-Studio162D Copier Logo
181 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
