Question about LG WM1814CW Front Load Washer
LG washer leaking problem
Some leakage under (not with every load) annoying-also fab/bleach dispensers have water in them most of the time. didn't notice any leak til warranty expired. don't use toooo much detergent and hoses are not leaking. evidently I'm not the only one who has these LG problems. Thanks for any help
  • jlschmidt6 Sep 25, 2008
    There is leakage ( not every load ) seeming to come from the dispenser drawer. The bleach and fabric softener cups are full of water when the drawer is opened, but then drain when the drawer is pulled out. I have repeatedly removed the drawer to check for clogs, but it is perfectly clean. What's up ?
    This began happening when the washer was 6 months old.
  • 489 Answers
You may be using too much detergent.  Use only 2 tablespoons of detergent in your wash.  Using too much will oversud the machine causing the suds to go out the back vent and on to the floor giving the sense of a leak.
On the dispenser, make sure that the containers are clean and free of any debris.
Posted on Jul 23, 2008
WATER & SOME OF THE BLEACH DOES NOT DRAIN FROM THE BLEACH COMPARTMENT AFTER EACH WASH? HAVING TO PULL DRAWER OUT & EMPTY REMAINING BLEACH & WATER EACH TIME BEFORE NEXT USE. WHAT CAN BE DONE?
Your washer is designed to purge the bleach dispenser between loads. For example, if changing from bleach to no bleach. The residue is normal.
Apr 27, 2016 | LG WM2487H Front Load Washer
I have LG wm-2277HW Front Load Washer, when I pour bleach into the bleach dispenser I see it disappearing as fast as I pour it in,and I see it coming out the front bottom the washer (the same side) where...
Remove the screws on the back of the top and lift the top off. Pour water into the bleach dispenser and watch to see where the leak is coming from. Post back your findings.
Dec 07, 2012 | LG WM-2277HW Front Load Washer
The bleach dispenser keeps filling up with water (I am not using it) and I don't know how to empty it - and why is it filling up?
You have a leaking water valve that dispenses water into the bleach cup. You will need to replace the water valve to stop this problem.
Good luck
Jul 08, 2011 | LG WM2487H Front Load Washer
Whirlpool bleach dispenser not dispensing properly
It sounds like the bleach dispenser is clogged or has a crack in it. What we do, is when we bleach our clothes and I know that this is extra work, but we wait until the washing machine is full of water, then add the bleach directly to the wash.
Jan 18, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
LG Tromm Not Dispensing Bleach
My wife has been complaining that the bleach and fabric softener dispenser still had water in it after washing. After removing the top to the washer I found that there are 4 components to the dispenser. 1. the solenoid (part of a 3 solenoid bundle) for the cold water, 2 the controller to the solenoid 3. The hose from the solenoid to the dispenser, and 4. The dispenser. After checking that there were no kinks in the hoses. I checked the solenoid found it had power at the right time but the flow was low. I shut off all the water and disconnected the lines going into the back of the washer I found that the cold water filters were clogged. After cleaning them (there were 2 for each hot and cold) The washer worked correctly.
Nov 24, 2008 | LG WM-2277HW Front Load Washer
Dispenser problems
Open dispenser drawer and push down on center plastic tab at back of dispenser to allow you to take dispenser out of machine. Take the plastic pieces off and clean them. (they need to be clean in order to siphon the bleach, softener, etc out. If there is water left in them, the water fill valve is OK. Cleaning should fix your problem. If you are using concentrated additives, try diluting them a bit with warm water when you add them to the dispenser. Remember, only one tablespoon (max) detergent, one teaspoon (max) fabric softener per load.
Oct 18, 2008 | LG WM-2277HW Front Load Washer
Bleach dispener always full of water
call for service, they will probably order the dispenser assembly (includes new drawer.)
Apr 23, 2008 | LG WM2455 Front Load Washer
Lg washer
make sure your machine is lavel and just a little higher in the front about 1/16 in and do not fill all the way to line just under line
Oct 22, 2007 | LG WM-2277HW Front Load Washer
LG TROMM WM2487 Bleach not getting fully removed after cycle
Keeping in mind that the bleach gets dispensed into your wash on the second to last rinse cycle and that most all rinse cycles are in cold water.  Is your cold water valve screen plugged causing your washer to rinse poorley?  Are you using the HE detergent?  If not maybe the washer is sudsing up to much and haveing a hard time rinsing all the suds and bleach out.
Fill the washer up with no clothes in it on a cold/cold wash setting does it take a long time to fill the washer up?  Also when it is full and agitating is there suds in the washer?
Last suggestion is if the drain is hose is alot higher than the top of the washer it might have a hard time draining out all of the bleach water before the next load
Aug 26, 2007 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG WM1814CW Front Load Washer Logo
554 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
