Question about Onkyo TX-NR801 Receiver
DVD no signal HDMI
I have my HDMI DVD hooked up to the receiver and it has been working for several months. Now, the receiver does not recognize the DVD by reporting NO SIGNAL. I check the digital inputs assignment and checked for loose cords. Any ideas. I even checked my DVD to make sure it is set up for HDMI. I worry my cats may have touched something on the front of the receiver. Also the receiver recognizes the satellite, tv, etc. Please help.
  • 2,071 Answers
Loose or crack or cold solder joint holding the socket of HDMI.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the TV turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If this solution help you understand the problem :rate as fixya..
Good luck;
Posted on Jul 16, 2008
Dvdr5520h DVD player HDMI connector problem
Hi S MArr
There are several input HDMI connectors and most often only one out put ---connector. Make sure you have connected your output HDMI to the TV/Projector and the DVD to one of the inputs and chose that input on your AV receiver ! Do not forget to turn on the DVD too. and give the Receiver and the TV some time to recognize and setup themselves to the signal.
Best of luck!
XyFinx
Jan 06, 2014 | Philips DVDR520H DVD Player/HDD
When i hook up my Bell 4100 Sat receiver to the Aux 1 in, i receive the sound but no video. I have tried using all sorts of combos, s-video and yellow video cable. The tv is hooked up witrh HDMI from the...
Thanks for clarifying that for me. The simple answer is the Denon home theater isn't able to convert the signal from your Bell receiver into an HDMI compatible format. You'll need to use either S-Video or the regular yellow cable to connect your Home theater to the television. The HDMI out provided would only work for the internal DVD player. This is a limitation of HDMI, not a problem with your home theater. You need HDMI in (or DVI in) to get HDMI out.
May 02, 2010 | Denon S-301
Digital projector is shutting down as soon as dvd
Hi make sure that in the projector menu it doesn't have an option to cancel "control" as many tv's with hdmi have the capability to receive command signals through the hdmi cable.
Also make sure that your receiver is set for hdmi signal you must designate which input you are using on the receiver and then tell it what type of signal you want it to use.
you may have just pushed a button that changed these settings somewhere along the way.
hope that helps
Dec 30, 2009 | Denon AVR 3808Ci Receiver
Receiver taking a long time to transmit reciever
I assume that the HDMI works fine if you go directly from the dish receiver to the TV with either HDMI cable. And try it with a different source (DVD or x-box) in the same input port.
Take it to a Radio Shack there service centers can repair Onkyo in warranty. Most Onkyo receivers carry a two year warranty.
Nov 18, 2009 | Audio Players & Recorders
I have a Onkyo HT-S6100 sound system which has the HT-R667 receiver. I have a DirecTV dvr hooked up with hdmi, a PS4 hooked up with hdmi, and a Wii hooked up through component cables. The receiver is...
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Sep 26, 2009 | Audio Players & Recorders
HDMI problem
u must go to the inputs and tell it you have an hdmi on the yamaha
Feb 03, 2009 | Yamaha RX-V663 Receiver
Dvd hdmi cable into receiver
unhook and reconnect a few times, try with power on and off, (they have to communicate with each other) if not, return receiver and get a new one.. I had this happen with my yamaha...
Jan 26, 2009 | Onkyo HT-S5100 Theater System
Sony str-dg820. having a problem getting video on tv
Hook up Composite / Component Monitor Out wire from receiver to TV video input because receiver will not change analog input into HDMI
You need to connect receiver and TV through analog video terminals as above.
Actually you are expecting that receiver will convert DVD player and Xbox analog video input into digital HDMI signal for TV and This is incorrect.
Jan 04, 2009 | Sony STR-DG820 Receiver
No picture, but sound
I had the same problem and I managed to solve it. It was because the HDMI was set to 1080i and my TV isn't HD. Default HDMI is 480p. You can check your current HDMI setting on the front panel of your DVD. There should be a button with the words "HDMI select". Next to it there should be 3 values. If the current one (a green light shows which one is selected) is not 480p, change it. To change it, make sure your sd-5000 is on, but not reading a DVD. The press the "HDMI select" button on the front panel until the selected one is 480p. This worked for me.
(I had the same same problem without the reading slowly part. On one TV, the sound and video weren't working, and only the video wasn't working on another TV)
Hope it helps.
Dec 28, 2007 | Toshiba SD-5000
Onkyo TX-NR801 Receiver Logo
334 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
