Question about Sony FD Trinitron WEGA KV-36HS510 36" TV
Cost of a t.v tube
How much does a t.v tube cost? is it really expensive?
FROM $150 TO $250 DEPENDS ON MAKE AND MODEL
Posted on Oct 03, 2008
What are daylight fluorescent tubes?
Daylight tubes has improved rapidly into a much more natural, closer to sunlight, fluorescent light as a result of an improving phosphor formulation. These tube cost a bit more but they are not really expensive.
Aug 21, 2012 | Fish
Tip
My monitor powers up then screen goes white X2Gen MW22U Monitor
<span>It is most likley the cfl tubes - and - or - the inverter is bad. This will happen sooner or later with all lcd monitors that do not have the L.E.D. back lights. It is very frustrating and timely to replace the items yourself unles you absolutly know what you are doing. You should replace the inverter board with the tubes - it is recomended. I see this problem all the time. Samsung has the L.E.D. backlight and not cfl. The total cost of the DIY [ do it yourself ] will bee about $9.00 per tube [ most use 2 - some have 4 ] and about $15.00 for the inverter board - again - the inverter board could be higher if it uses 4 tubes and prices do not include a hefty shipping fee. Here is a sample link to read and a DIY document with tube sorce.<a href="http://store.lcdparts.net/">http://store.lcdparts.net/</a> . Now the prices at this site are expensive - they also cover LCD cfl BACKLIGHT TV's - you can search the web for the proper tube but again - the tubes are like a shop light floresent tube in a really small package and very - very fragile and eay to break. Here is the site and it will explain more for you and guide you along for a reference.<a href="http://store.lcdparts.net/">http://store.lcdparts.net/</a> . Once you have figured out a few things - try buying the items elswere . A standard 14" lcd monitor wit 2 tubes and an inverter will cost you a min. of about $50.00 + or - if you shop around. Hope this helped you a little and here is the LCD Backlight Link. <a href="http://store.lcdparts.net/">http://store.lcdparts.net/</a> Kevin </span>
on May 08, 2011 | Televison & Video
Tip
It is most likley the cfl tubes - and - or - the inverter is bad. This will happen sooner or later with all lcd monitors that do not have the L.E.D. back lights. It is very frustrating and timely to replace the items yourself unles you absolutly know what you are doing. You should replace the inverter board with the tubes - it is recomended. I see this problem all the time. Samsung has the L.E.D. backlight and not cfl. The total cost of the DIY [ do it yourself ] will bee about $9.00 per tube [ most use 2 - some have 4 ] and about $15.00 for the inverter board - again - the inverter board could be higher if it uses 4 tubes and prices do not include a hefty shipping fee. Here is a sample link to read and a DIY document with tube sorce.http://store.lcdparts.net/ . Now the prices at this site are expensive - they also cover LCD cfl BACKLIGHT TV's - you can search the web for the proper tube but again - the tubes are like a shop light floresent tube in a really small package and very - very fragile and eay to break. Here is the site and it will explain more for you and guide you along for a reference.http://store.lcdparts.net/ . Once you have figured out a few things - try buying the items elswere . A standard 14" lcd monitor wit 2 tubes and an inverter will cost you a min. of about $50.00 + or - if you shop around. Hope this helped you a little and here is the LCD Backlight Link. http://store.lcdparts.net/ Kevin
on May 26, 2010 | Televison & Video
Need picture tube replaced for rca television not
You have to get the exact type no. of the picture tube. Better buy a new TV. Picture tube will be expensive and no guarantee whether it will have sharp image l after replacement.
Apr 01, 2010 | Televison & Video
CRT Arch / Blue Tube, Now what do I do.
Replace Blue Tube and re-align - Big job and expensive Tube cost min $300 + installation. You can see the tube arching internally?
Sep 21, 2009 | Zenith R56W36 56" Rear Projection...
Sony Trinitron Picture Tube replacement
I think that you will find the picture tube to be more expensive than a replacement TV, if it is still available (unlikely). That being said, it is also unlikely that the tube itself is the problem, The more common problem is the horizontal output transistor or the flyback transformer. Either part should still be available for a reasonable cost. Check with a local servicer for the part numbers and costs. These are common parts.
Dan
May 19, 2009 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Picture has lines going across
No picture tube is cheap to replace. Especially a Sony tube. And besides the cost of the tube there's the labor cost to install it and some tedious adjusting needs to be done to set up the replacement. When a picture tube fails it's time to replace the set.
Now having said all that, there are different kinds of lines that can show on the screen. Some are because the tube is bad, but others can come from less expensive parts on the circuit board in the set. Without seeing the lines for myself I can't tell you about yours. If you are wanting to keep the set, I would suggest having a qualified shop check it. The can tell you for sure if it's the tube or not, and give you an estimate for the cost of repair.
Apr 18, 2009 | Zenith C27A24T 27" TV
My rode ntk needs a new tube
I'd check rodes site and see if you can buy one, or take it to a pro audio repair shop, tubes aren't very expensive and can be easily replaced.
Jun 02, 2008 | Rode NTK Professional Microphone
Sony FD Trinitron WEGA KV-36HS510 36" TV Logo
32 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
