Question about LG Flatron Ez T710BH 17" CRT Monitor
Problem signal cable
  • 45 Answers
Hmm,
Exact message could Find a Closest solution.
anyways, what you might be getting is a message like,
No Input signal,Check Video Cable.
it means that the Connection from the Monitor to PC is Loose,
Connect them Secure and tight to FIx it.
Posted on Jul 17, 2008
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
When connected to cable, get a no signal indicator
You need to go into the TV menu, locate where choices for choosing incoming signals are, and choose the cable option, so the TV knows that it is receiving a cable signal, VS an antenna signal.
Nov 16, 2014 | Vizio 32" E320I-A0 LED-LCD Smart TV, Black
Sanyo gxba
u cant.......the antenna gets only over the air signals while the cable are actually wire transmitted signals meaning if its cable transmission u want u will have to consult the broadcast provider to hook u up with there particular signal cable to your tv thats what is called cable tv a reason ya antenna cant receive cable signals is compartibility
Jul 19, 2013 | Televison & Video
How do i get stronger signal
If you are referring to a cable signal on your tv set, then there are several ways, but first off, how do you know the signal is weak? Analog cable signals typically run at 30 to 40 percent while HD signals on the same line can be as high as 90%.
If your cable connections are firm and have no fray with good cable runs, and is not longer than needed, I would suggest calling the cable company tech support line for troubleshooting. It could be their error in an outside line.
Mar 23, 2011 | Dynex DX-LCD37 TV
I have connected the cables....no display
disconnect the signal cable and power on then see the massege on monitors screen "NO SIGNAL CHECK THE SIGNAL CABLE"if it appears then monitor is ok if not then monitor is faulty check the signal cable and replace it if faulty problem will be solved
Jun 16, 2010 | Samsung SM943N 19" LCD Monitor
Cable picture is fuzzy
Call your cable company as there might be a problem with the drop line or aerial coming into your house. now another thing is if you have a signal splitter( ex: 2-way, 3-way, 4-way) before the cable box, that could be degrading the signal as each input may drop the signal significantly. remeber, don't use too many splitters as they will make the signal faded/fuzzy. also, make sure all the connectors are clean and are not badly bent or the ends frayed. If you can see wire insulation from the cable line then it's no good.
Apr 05, 2010 | Insignia 42" LCD Flat-Panel HDTV
Losing signal intermittently every 1-5 minutes
This problem is probably due to weak signal strength from the cable to the television. Buy a signal amplifier for you cable line in and use another cable out of the amplifier output to your Television input signal source, This should bring up the signal strength for you.You could also have your cable company check the input signal strength to you house or apartment and see if the cable itself needs repairing or replacing.If this does not help with your problem , then you need to have your television tuners signal input circuit tested it may have weakened from age. This may be adjustable in the tuner box, but this is something for a service technician to determine. customer service number for Insignia is 1-877467-4289. Hope this helps you with your problem
Apr 20, 2009 | Insignia 37" LCD Flat-Panel HDTV
Visco LCD TV VSC-32V3 32
After connecting the cable to the TV, you should scan for channels. With the built-in cable QAM tuner, you should be fine with a scan for channels.
Try another TV to make sure that cable broadcasting is coming in...is there a set-top cable box involved?
Apr 07, 2008 | Insignia IS-LCDTV32 32 in. Television
Poor cable tv reception.
Problem is direct "ingress" of the terrestrial signal from the TV station (off-air) on to the cable along with the signal from the cable company. Typically caused by faulty/bad/cheap connectors and cables. If you are certain that the signal is clean from the cable company, then the best solution is to replace the cable in your home with good quad shielded cable, with good tight connections made. You could start by checking all "F" connectors top see that they are snug. An amp may increase the signal enough to overcome the ingress and help a bit, but it usually just amplifys the same signal.
Apr 05, 2008 | Sansui DTV2760 27" TV
"No signal"
It could be a bad barrel at he TV and at the wall. Your cables and connector could be of poor quality. You may also have a signal issue. Has anyone fron the cable company be out to take a signal reading?
Nov 09, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
LG Flatron Ez T710BH 17" CRT Monitor Logo
143 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
