Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Hitachi Yes you will need two Convergence ICs they are both STK392-110 and you will also need the 6 feed resistors that feed them which are (2) 2.2 ohm 1watt resistors, (2) 1.5 ohm 1watt resistors and (1) 3.3 ohm 1watt resistor and also (1) 1.8 ohm 1watt resistor. You can get the replacement ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself, they also have free online tech support incase you need additional help. Heres the link. http://servicemanuals.vstore.ca/ Thank you - the site above offers everything except the 1.5 ohm 1 watt resistors. Any other resource you might suggest?
  • 10,594 Answers
But becareful, TV has high voltage inside.
Posted on Jul 16, 2008
  • Hitachi Master
  • 8,617 Answers
They have it, they just list it as a 1-4 watt resistor, just order two of the 1-4 watt resistors and they will send a order confirmation inquireing which rating you need for those two items within minutes of your order.
I changed my two IC chips and three resistances on my Hitachi TV to fix color alignments. Now the problems is that yellow and blue double image are seen at the bottom of my screen with no much effect on...
Ur tv still have dead resistors parts,test all 12 resistors parts around the 2 STK convergence ICS and changes some more dead resistors parts or changes all 12 resistors parts for sure.If tv still have the same problems after tested and replaces more resistors parts or all 12 resistors parts.Than some how when u handling and replacing the 2 STK convergence ICS and resoldering the 2 STK covergence ICS u short it out the 2 STK convergence ICS by resoldering without proper grounding ur self not to allow for static electricity to kill the 2 STK convergence ICS or u using a soldering iron to high of a wattage for doing soldering ICS work.
Apr 23, 2011 | Hitachi 43FDX01B TV
Hitachi Model# 43FDX01B is doing a double image.
You have a convergence problem, you will need to change the convergence IC's STK392-110, there is also 12 6.8 1w resistors that need to be changed, there is also 2 fusilbe resistors that may be open. You can probably Google the IC's as a kit and find them all in one kit.
You can fix this yourself and save about $300-$400 in repair bills.
Feb 23, 2010 | Hitachi 43FDX01B TV
BLUE BULB CONVERGENCE
Replace the convergence ICs and feed resistors. You can get replacement ICs and resistors at the following link with installation instructions. If you leave them a email with your model number they will tell you the correct ICs and resistors for your model set. Heres the link.
Nov 26, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Help please,....
Did your replace the convcergence feed resistors along with the ICs? As Hitachi recomend replacing the six feed resistors along with the ICs as often the old resistors will blow or increase in tolerances when the old ICs go out.
Nov 22, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi rear projecton tv
your model uses two STK392-110 Convergence ICs. Hitachi also recomends replacing the feed resistors which are two 2.2 ohm 1watt, two 1.5 ohm 1watt, one 3.3 ohm 1watt and one 1.8 ohm 1watt resistor. You can get repolacement ICs and resistors at the following link and they provide step by step installation instructions with pictures. Heres the link.
Sep 30, 2008 | Hitachi 53FDX01B 53" Rear Projection...
Picture loss
sounds like the convergence ICs and resistors due to the double image. You need two convergence ICs both STK392-110 ICs and the following six resistors. (2) 3.3 ohms 1watt resistors, (2) 1.8 ohm 1watt resistors. (1) 1.8 ohm 1watt resistors. (1) 3.9 ohm1watt resistor. You can get replacemnet ICs and resistors at the following link and they provide free instalation instructions so you can do the repair yourself. Heres the link.
Aug 06, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Blue ghosting
yes you will need to replace the two convergence ICs stk392-110 you can getreplacement ICs at the following link with free installation instructions. You will also need six convergence resistors. Leave them a email with your model number and they will tell you which resistors are needed for your model.
Here is the link.
Jul 16, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Red arched ghost
But be careful as TV has high voltage inside.
Jul 16, 2008 | Hitachi 57F500 57" Rear Projection...
Blue won't line up at the top in digital array
you need to replace both convergence ICs and the six 1 watt feed resistors. The ICs are both STK392-110 and the resistors you need one of each RK42 3.3 ohm 1watt, RK46 1.8 ohm 1watt, RK50 2.7 ohm 1watt, RK54 1.5 ohm 1watt, RK58 3.9 ohm 1watt and RK62 2.2 ohm 1 watt.
You can get replacement ICs and resistors at the following link with free instalation instructions.
Jul 15, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Green drooper.
that is a convergence fail. yes you will need to replace the 2 convergence ICs as well as any burnt resistor off the blue vertical convergence yoke. which will be a connector most likely with a blue mark on it. the convergence ICs will located on the right hand side of the chassis screwed into the 2 large heat sinks.
Jan 28, 2008 | Hitachi 50UX57B 50" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
