Question about Dryers
The dryer isnt working it hasd no power..n i checked all the switches n they all have electricity but the dryer still dosent work
  • 254 Answers
Did you check the thermal fuse? it's usually located on the blower housing depending on the brand of dryer.
Posted on Jul 16, 2008
Tip
Electric dryer will not work at all?
If the electric dryer does not work at all then there are some possibilities that have to be checked to confirm the fault.
1) Check whether you are getting power to the dryer from electric out let to which the dryer is connected. The power problem can also occur if the fuse is blown or the circuit breaker is got tripped.
2) Other possibility for dryer not working is the blown thermal fuse. The thermal fuse is located to the exhaust duct inside the back cover panel. This fuse blows out if the dryer gets overheated or any short circuit occurs in the house when dryer is in working.
3) One more reason for dryer not working at all is the fault in the door switch. The dryer will not start working till the door is closed. But if the door switch or the door-switch actuator is got cracked or worn out or loose then door will not get closed properly and dryer will not work. In this case check the door switch/actuator and replace it if required.
4) But if all the above mentioned possibilities checks out OK, and still the same problem, then there is a fault in the wiring. Check the main power cord of the dryer which you connect in the electric out let. If the power wire is got internally burned out or got cut in between the dryer will not get power and will not work.
This will help. Thanks.
on Mar 23, 2010 | Dryers
Dosent get hot, says cooling down.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 15, 2010 | Frigidaire FEQ1442ES Electric Dryer
Dryer dosent heat
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Sep 14, 2010 | Dryers
Dryer dosent allways produce heat to dry the load
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 16, 2010 | Whirlpool LGQ8000JQ Gas Dryer
Electric dryer not drying clothes
The electric dryer requires 220 volts to dry clothes but only 110 volts to turn the drum .reset your circuit breaker even if it looks ok ,if that dosent work, unplug from the wall and check where the plug wire goes into the back of the dryer and look for loose or broken wires.
Apr 26, 2009 | Estate TEDX640JQ Electric Dryer
Dryer doesn't work,electric has been checked I
You dont need to check motor first. start from door switch. check the continuity of the switch if not making a peep sound when you press the button replace the switch button.
Apr 02, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Whirlpool LER3624JQ
check the breakers,check the belt, check the heating element,and check door switch majke sure it isnt loose or broke or something.All dryers are fairly uncomplicated.Last check wiring and motor.
Oct 16, 2008 | Whirlpool LER3624JQ Electric Dryer
Dryers Logo
62 people viewed this question
Top Dryers Experts
