Question about Sony CDX-CA600X CD Player
Bus control I have a Sony CDX-CA600X and I would like to install a 3.5mm jack socket for Mp3 alongside. when I connect the jack socket to audio in I cannot get the option from the source button to switch these audio in sockets on. I guess its something to do with the bus control socket. If you think so, what is the plug type and how should it be connected? Barry Dawson
  • Beedeeboats Jul 16, 2008
    I want to plug an audio signal into the 'audio in' sockets on the back of the unit,in the instructions it says that repeated presses of the 'source' button should bring up the CD changer as an option, but it just cycles between CD and radio. Maybe the other option only appears when something is plugged into the 'bus control' socket? Whatever, I'd just like to find out how to use the 'bus audio in' Which I would call 'line in' sockets.
  • 10,594 Answers
You need to provide Clock n Data signal to activate Bus Audio Source. Actually this Bus Control Socket is to attach Multi Disc Player of Sony. Here is 2 pictures attached of bus related area for info. I am sorry, its difficult to hear MP3 sound at Bus Audio input in this model. Have nice day.
Posted on Jul 16, 2008
  • 1 more comment
  • Shahid Electronics
    Shahid Electronics Jul 16, 2008
    Hello again,
    You need to arrange +5 volts at pin-6 of buscontrol socket as stated in picture. 5 volts will turn ON buscontrol Input which is hidden/ Off now in your CD system.
    Hope this will solve your problem.3
    Shahid Electronics Jul 20, 2008
    Hello beedeeboats,
    Hows your system working now? any update?
  • pkohler112 Dec 29, 2010
    Hi welcomejee
    please could you tell me how to apply 5 volts to that pin.
    where can i take voltage from the own system and transform it in to 5 volts
    or can i use an external device and connect it to that soccet??
    thanks a millon, ther´s no other logical answer nowhere
    Genius:
  • 1,665 Answers
You re welcome jee
    Master:
  • 497 Answers
Http://audio.manualsonline.com/manuals/mfg/sony/cdxca600x_cdxca600.html
i hope this link helps
Thanks for using Fixya
    Brigadier General:
  • 3,614 Answers
What is the specific jack did you use, and please tell us on the exact name on which terminal socket did you connect it.
  • 4,234 Answers
The reason you don't see the third option is that Sony did not want you to heve to skip over options that were not available. With the changer connected using the multipin cable, the feedback from the changer would esentially tell teh main system that it was available, thus placing the "changer" as the third option. Think of it as working similar to autoprogramming in a TV. Without the auto-program to get from channel 4 to 7, you would need to channel up through 5 and 6 before hitting 7. WIth auto-programming not detecting active channels for 5 or 6, the channel up would go directly from 4 to 7.
Hope this helps,
Dan
Loss all presets. after switch off. dont think perm live is connected. but dont know which it is.
most aftermarket stereos have a yellow wire that needs to be connected to 12volt constant power in order to "remember" the clock and radio presets. Use a volt meter at the car to determine correct wire to attach to.
Feb 28, 2010 | Sony CDX-CA600X CD Player
I have a sony cdx-f5000. i recently purchased
Block 3 in this diagram refers to a Source Selector XA-C30 and Buss Control signal from same device.
http://www.docs.sony.com/release/CDXF5000install.pdf
And here is a link to your Sony CDX-F5000 Operating Instructions.
http://www.docs.sony.com/release/CDXF5000.pdf
Dec 23, 2009 | Sony CDX-F5000 CD Player
Is sony cdx gt24 has an ability to connect in an amplifier? its has an auxiliary in front and its mp3 player... Max. output 4 x 45W...
From memory I believe you can, it should have the 2 connecting jacks and speaker jacks in the back, let me know how you go. Good luck
Nov 20, 2009 | Sony Xplod AM/FM CD Player w/ MP3 Playback...
CDX-CA600X Audio in sockets
Ok.. i got the post, please wait while i look into the details on the cd player that you have there...
Thanks
I will post in here again
micro
Jul 16, 2008 | Sony CDX-CA600X CD Player
Cannot play my portable audio device with Sony cdx c500x
It will only accept audio from the bus in conections when a multi changer is connected and selected.
This is how I connect my mp3 player to my sony.
Swap multichanger audio outputs at the rear of the stereo for my mp3 player, press source to select multichanger.
Remember as I said, if there is not a control cable connected to your multichanger it wont wotk!
Aug 17, 2007 | Sony CDX-C5000X
Audio in
Unfortunately, the "Bus audio in" jacks are only for use with Sony add-on components, like Sony CD changers. Without a Sony component connected to the Bus control jack, the audio input can't be selected. To add an auxiliary input to this head unit, you need to purchase an adapter: http://www.crutchfield.com/S-EMPSKmYtPsH/cgi-bin/ProdView.asp?search=sony+aux&i=127AUXONS
Jun 16, 2007 | Sony CDX-F5500 CD Player
Linking an i pod to a Sony CDX-MP40 using the bus input terminal
Some Sony head units let you use the Bus audio inputs as an auxiliary source input, but yours is not among them. To play your iPod through the head unit, you'll either need an iPod interface module: http://www.xplodsony.com/xplod/accessories/XA-110IP or an auxiliary input module: http://www.xplodsony.com/xplod/accessories/XA-300 The iPod interface will allow you to control and display the iPod directly through the head unit, while an auxiliary input adapter will allow the iPod to play through the head unit using the iPod's controls and display.
Jun 01, 2007 | Sony CDX-MP40 CD Player
MD/CD Changer Control Options
press source button repeatedly to select "CD" or "MD" be aware that in order to connecting Ipod to a car stereo you will need to use an extension cable with 3.5 mm stereo connectors on each end to connect iPod to your car stereo system's aux input, or use a cassette adapter if your car stereo doesn't have a sound input jack. Either of these items can be purchased at stores that sell car stereo accessories. good luck!
Nov 12, 2005 | Sony CDX-CA400 CD Player
Sony CDX-CA600X CD Player Logo
3,035 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
