Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
Lambda lexicon sound problems: is vista the cause?
I bought a lambda lexicon in april and used it on my old PC, which was theoratically barely sufficient. However it worked fine on that and still does.
However, I recently purchased a new PC (hp pavilion a6000) and now I can't properly use the lambda because there's a cracking noise (like blown up speakers) in the output, both on headphones and via audio out. '
When I change the device setup from Lambda Asio to Full Duplex driver I do get a clear sound, but only via PC output. Any suggestions???
  • 2 more comments
  • jwooop Aug 20, 2008
    When i connect my headphone to the headphone jack usinga 1/8 trs connector, no sounds can be heard when adjusting the output level control. Does anyone know how i can resolve this issue so i can use my headphone when recording?
  • BigBrodeur Aug 20, 2008
    I have the same problem, on my laptop, the card suddenly send a big ''white noise burst like'' sound for a brief moment. I am using it in with my desktop with no problem so the card is working fine. Seems to be a compatibility issue. The laptop is a brand new Compaq Presario A900 with 4 gig of RAM onboard. USB2 of course. Anyone have a clue
  • Anonymous Nov 23, 2008
    I have the same problem. I get a pop through my speakers whenever I do anything that might need .01% of my processor. The new driver didn't help either.
  • Anonymous Nov 28, 2008
    I have tried everything. It happens through every output on my Lambda.
I have had the same problems with the lambda driver ...they just posted a new installer on the lexicon website which fixed me up...try it.
Posted on Jul 26, 2008
I have the exact same problem with vista in my hp pavillion dv5... anyone found a workaround better than throwing away the device?
Posted on Nov 15, 2009
I am totally lost!! All I have is the lambda lexicon and cubase LE4 on my desktop.Apparently it is not set up correctly. I want to record guitar and voice I have sound on lambda through mike and guitar but...
All it needs is a USB connection. You'll need to go into Cubase device setup and make sure your lambda drivers are selected. Then create the audio channels in cubase with the inputs set as the inputs you're using for guitar and mic. There is a monitor button right next to the record enable button that needs to be enabled if you want to hear playback from your computer.
Feb 20, 2010 | Lexicon Lambda Usb Desktop Recording...
I had a lexicon lambda installed on my old laptop. I lost my installer cd and now can't use my box in my new computer . how do I get the driver ?
Hi here is a link to the drivers for you Lambda.>
http://www.lexiconpro.com/product.php?id=8#downloads
Thank you for using Fixya.com
Feb 10, 2010 | Lexicon Lambda Usb Desktop Recording...
No Power to the lambda
Make sure the usb socket is working ,the lamda takes current from your computer.Don't use a usb hub.Make sure you are using xp service pack 2 or higher.Try another usb socket.
Jul 14, 2009 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lambda on Mac
Hi, I just bought one today and am using a condenser mic through the lamdba. I booted up apple logic - plugged in the device and it found it as a usb audio device. You need to use the headphone jack on the lamdba. good luck
Dec 26, 2008 | Lexicon Lambda Usb Desktop Recording...
Lexicon Omega will not play any sound on Windows XP
one of several install steps (the steps seem to vary depending on which manual you can find) mention checking your sound device setup in control panel. ON one machine I installed the sound devices were not affeted. On a 2nd PC they were changed from drivers installed with PC to the Lambda driver
Win XP settings->control panel->Sounds and Audio Devices then select Audio tab. Make sure the three areas are set up to use your PC's default drivers and not lambda's.
You may need to verify this again when reconnecting the Lambda USB cable. Sort of new but ran into this "issue" as well.
Found info in Lambda Studio Software Installation Guide I downloaded, step B following driver install.
Nov 21, 2008 | Lexicon Lambda Usb Desktop Recording...
Sometimes power comes on and sometimes it does not.
Are you running Vista? Lexicon is working on some firmware and software updates to fix the problem. The only workaround is to unplug and replug your USB cable when it stops working. As long as you are actually using the Lambda, it should work.
Oct 30, 2008 | Lexicon Lambda Usb Desktop Recording...
Distortion
It's because when you recording your get sound from Lambda!!! But PC can't reproduce that quality! Try to download driver or update which will allow you to achieve what you want.
Jan 21, 2008 | Lexicon Lambda Usb Desktop Recording...
My Lexicon Lambda is not working
Go to your devices tab click on the ASIO driver Lambda and when you get that message click reset and try again it should work.
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
1,029 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
Alun Cox
JonSnell Electronic
JonSnell Electronic
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
