Question about Toshiba Satellite A45-S250 Notebook
Dell laptop charger
Today I was on laptop and everything was fine. I went outside in plugged charger into outside outlet and now it doesn't charge. It doesn't show its green light and it has a beeping noise.
  • 2 more comments
  • Anonymous Nov 16, 2008
    I have the same problem, the green light doesnt even go on, all that it does is make a beeping noise. Idk what i did to it. I need help in this ASAP please.
  • Anonymous Nov 19, 2008
    i also need this help ASAP but my brother had told me to fiddle with the wire that connencts to the laptop i have tried this several times but it still does not work
    im confused dot com lol
  • mads123 Nov 21, 2008
    I do have the same problem with my office laptop.
  • Nose Master Dec 26, 2008
    'Cept my wire is a little bit out of the charger ( the bumpy part of it, with grooves.)
    Some of the little metal lines on the wire are a little messed up, too.
    I pushed the wire back in, nothing working though.
  • 2,028 Answers
First try starting the machine without the battery, only the charger, Then check the charger with an ohm meter to see if it's working properly. The out put readings are listed on the charger. In case of a surge, the charger is designed to go out first before damaging the system. However, this is not always the case. If the charger checks good, then you should take it in for a professional diagnostic because the problem may be with the power management system on the motherboard. One thing to keep in mind for future reference is when moving to a different location with your laptop, when unplugging the charger, always unplug the charger from the laptop before unplugging from the wall socket, and when plugging in, always plug the charger into the wall socket before plugging into the laptop. This will keep from surging your system.
Posted on Jul 16, 2008
I have the same problem, the cause was that my puppy used to chew on cord. you have to see if something happened to the cord. if yes,
you could get the thing to work by twisting the wire a lot and clearing the short. or
you could the cord and separate the three layers of wire inside then use duck tape.
Posted on Dec 19, 2008
  • mssahota Apr 26, 2011
    Thanks, mine work! It was shortcrkt in wires, i clear the short crkt!
    Thanks, you save my $30.....
    Bless ya
  • bizzyd4u
    bizzyd4u Nov 11, 2012
    mine started making the beeping noise, and no green light had charge in the laptop so i googled it and came to this, i tried this solution and it worked i just got this cord about 5 months ago from the dell place that they had just replaced maybe that is what was wrong with the other one i have to dig it out and see. Thanks for the advice , I'll remember to straighten out the cord.....yeah no beeping..... :)
  • 846 Answers
If you charger is beeping that means it's shorted. It's a swiching powersupply and when they get overloaded the inductivities inside the circuit can start to vibrate and emit a sound. Don't plug this charger in anymore. It's best to get a replacement from a third party Laptop Shop.
Posted on Jul 26, 2010
  • amir mofakha Nov 28, 2010
    try to open cover of your charger, it needs to break some parts. inside of it there is a metal sheet,. open this sheet and let to blow air inside . after some minutes compact your charger and its ok now
My laptop is completely dead, fine yesterday. Today no lights, sounds nothing. I tried removing the battery , unplugging no response. Thanks,
Remove the battery for at least 3 minutes... Then put it back and then plug in the charger and switch on the charger. If the battery is completely drained, it would take a while for the charging to initiate. Please have patience and leave it on charging even though without the charging indication for at least an hour. After that still if the charging indicator doesn't lit, then its definitely your charger or laptop. You will need to take it to a service centre in that case.
Nov 03, 2011 | Compaq Presario 2170US Notebook
Charger tips to small for dell laptop
A Dell Mini net book is a small and very portable laptop. The compact size makes it a good candidate for travel or just simply using around the house. Outdoor aficionados can get the most computing life out of a Dell Mini by finding a way to charge the battery outside. One method works when you are near a building while the other can be used for more remote outdoor locales
Things You'll Need
  • Extension cord
  • Solar laptop charger
  • Dell Mini power adapter
    • 1 Plug an extension cord into an available power outlet. Run the extension cord to where you are outside. Many homes also have exterior outlets. Use an extension cord that is designed for outside use. Plug the Dell Mini power adapter into the extension cord to charge the battery.
    • 2 Purchase a laptop solar charger. Solar chargers are available from several different manufacturers and may come in the form of a roll or be built into a case that closes up for travel. Depending on the charger, you may also need to purchase a Dell Mini power adapter. Some chargers work with a Dell Mini cigarette lighter adapter that is designed to plug into a vehicle's power port.
    • 3 Place the solar laptop charger in a sunny location. Open up the case if the charger is in one and roll it out flat or unfold it to expose all of the solar cells.
    • 4 Connect the Dell Mini power adapter to the power port on the solar charger. Connect the other end to the netbook. The adapter will regulate the charge coming from the solar panel and recharge the battery in the Dell Mini.
  1. Tips & Warnings
  2. Solar chargers offer less power than a wall outlet. They can be used to extend the battery life of a Dell Mini or to recharge the battery when the netbook is off.
  3. Some solar laptop chargers are relatively heavy. Take the weight into consideration if you are going to be backpacking or otherwise carrying it on your person.
Oct 23, 2011 | Computers & Internet
My Dell Laptop was working fine in 220V country, when i moved and try to use it in US (110V) the charger LED is ON but once i plug it in the laptop it goes off and the laptop is not working. i even tried...
So two different devices, each with their own charger, don't work in different power outlets in different rooms? How about if you plug a light into the same outlet. Does the light work? Does it dim when you plug the charger into the laptop? If so you have a bad electrical system, either a loose wire or bad outlet.
Jul 15, 2017 | Dell XPS M1330 Notebook
My Inspiron 6000 won't charge the battery.
According to your problem, this may occurs for either the battery of your laptop or the charger is faulty. First check electric outlet where you have plugged your laptop charger is OK. Then check the power cord. If everything OK then you have to change the battery.
Jun 10, 2011 | Dell Inspiron 6000 Notebook
I have a dell 1720 that was working great. I went to plug in the power cord and the green light went out on the power box and nothing happened when I pushed the power switch on the computer. The power...
the charging port and or motherboard is grounding out
that is to say positive and negitive coming together
wont damage the charger
once you plug the charger out of thhe laptop and outlet then plug back to outlet the light will return
has to be look at by a technician
Jun 02, 2011 | Dell Inspiron 1720 PC Notebook
I have a Dell Latitude D630, and I have had it for less than a year, and my charger is broken. I have it plugged in and everything, and it is not working. I plug the adapter into the outlet, and the...
sorry, i have to say this-- make sure the outlet works-- or try out a different outlet. :-)
ok, then make sure the connection is tight between the 2 parts of your adapter, it may have come loose.
other than that, you have a dead adapter. laptop companies are very good about replacing them for free under warrantee. they dont want fires starting at someones home because of a 30 dollar part.
i just called my laptop company, hp, 1 week before my 1 year warrantee ran out, and they shipped me a new power adapter, free, overnight.
call dell, tell them, they'll ship you a new one with usually free shipping, and usually in a day or two tops to your door.
Jan 31, 2009 | Dell Latitude D600 Notebook
Dell laptop charger
If the charger is older and since you saw the light go on then off again, it could just be the charger wires. Assuming your charger has a black box attached to it, try pushing the cord in towards the black box (usually the end leading to your laptop) . If that doesn't work, wiggle the cord in that area. If this works, your problem is simply the wire is worn out. You can fix it by exposing the inside wire where the bad connection is, snip it, reconnect and cover with electrical tape. I just did this to my sister's last week.
Aug 22, 2008 | Dell Inspiron 6400 Notebook
Toshiba Satellite A45-S250 Notebook Logo
4,004 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
