At times black smoke from the exhaust pipe. runs rough. then dissappears and runs smoothly. sometimes runs with hiccups.also disappears for a long time.
signs of a bad fuel pressure regulator-- the vehicle will run rough, the engine will not start ( usually in the mornings,) many times engine starts but stalls shortly after starting. a bad regulator can result in fouled plugs. replacement is only cure. 1- black soot on plugs-2-black smoke from tailpipe-3- running rough-4- stalling, good-day! repost if need be.
Take it to an Autozone or O'Reillys and they will test the computer for you. It should have set a code, but you don't know if the code light works so its your best bet. Sounds like it is running rich and the crankshaft module is not advancing the timing.
