Question about Zanussi Z57 / 3 Bottom Freezer Refrigerator
My integral fridge has a small built in freezer at the top. The freezer door handle broke and the door would not shut properly. An engineer came out but brought the wrong part. He returned three weeks later, replaced the freezer door and advised that we defrosted the fridge as ice had formed - no doubt due to the fridge having freezer cold air leaking into it for several weeks. However after defrosting , when we switched the appliance on again the fridge no longer works. The engineer returned today and claims that there is no gas in the fridge and that any leak is purely coincidental and nothing to do with the malfunctioning door and fluctuating internal temperatures. If the thermostat was running constantly to try to regulate the fridge temperature, could this have damaged the compressor and caused the gas to escape? The engineer says not - but he would say that wouldn't he! I'm hoping someone could advise before I just accept that it was a coincidence and buy a new fridge. Thanks
    Problem Solver:
  • 15 Answers
It is possible that in defrosting the built up ice on the freezer that you accidentally punctured a coil and that allowed the gas to escape. If you check the area you defrosted you may find a small nick. As the tech said, it should have nothing to do with the prior repair unless he was poking around in that area with something sharp. As for the long running that would not cause it to lose gas.
Posted on Jan 21, 2011
SOURCE:
Ge monogram 48 built in refrigerator
If the seal to the top freezer is not sealing properly, this could be a matter of door adjustment. This a common refrigerator/freezer problem. The correction consists of loosening the door hinges and adjusting the seal for eveneness then retightening the hinges
Jun 27, 2013 | Refrigerators
HI! I broke the handle on the door at the freezer. Can that be fixed? If not where can I buy a new door? The model of my fridge is: Kuppersbusch Integrated Fridge- Freezer Modell: IKE 318-6. Thank...
We were able to purchase a replacement handle for our freezer from RepairClinic.com . You'll need the model #, Serial #, and date of manufacture.
Jan 18, 2011 | Refrigerators
Door seal comes loose, shut the freezer door and the fridge door opens. What is a possible problem?
Most likely the seal is worn, however have you wiped all the build up of any mold and debris from the seal and frige frame that seal closes to?
Sometimes just a good cleaning with hot water and mild (not harsh sprays) soap like dish soap can bring the cling back.
Otherwise its replace the seal.
If your broke you can latch the door shut by making a Velcro handle on the outside.
Dec 19, 2010 | Haier HTQ21JAAWW Top Freezer Refrigerator
Handle pin broke
this happened to mine while still under warranty, eventually the repair man brought a small replacement part which took 5 minutes to fix, but not before a previous engineer had ordered a complete new door. you should be able to get the part ordered, and it would be easy to replace yourself. Now my FP oven has broken down again
Aug 19, 2009 | Fisher and Paykel E522BRXFD Stainless...
There is water dripping filling up the bottom under the salad container. The model is a LRTN22311TT.
Remove contents of fridge and check the drain line running down the top back of the back of fridge and follow to lower section of fridge (usually a back ledge or under the crisper sections) and locate a small round drain hole. Also, check to see that the drain collector (funnel looking thing at top back of fridge section) is located under the freezer defrost drain opening, to allow water to flow through the fridge into the drain pan under the fridge.
If something has obstructed the drain funnel, path, tube, or lower drain hole, remove the blockage to allow water to drain into underneath of fridge into drain pan for proper evaporation of water produced from the usual daily defrost cycle of fridge/freezer.
If that is not the problem, it could be that you have a leaking water supply line for your ice maker and you'll need to see if the freezer is allowing excessive water to flow out of the ice maker into the fridge section.
Another simple check/solution is that the fridge is not properly leveled, meaning that the front of the fridge should be slightly higher than the rear to allow for proper drainage and self closing of the front doors. This will help keep the water flowing in the built in channels and drains.
A perfectly level fridge isn't the right way to install most moveable refridgerators, while built in fridges (Sub Zero, etc.) are designed for plumb and level installations for proper functioning and use.
Apr 09, 2009 | LG LRTBC1825T Top Freezer Refrigerator
I have the top mount refrigerator - 4years old. Ice maker was installed then removed because it broke about 2 years ago. Suddenly I am getting a huge amount of water in the crisper drawer but no other...
  1. Checking/changing a common light switch
  2. Common frost free fridge parts learn "what" is called "what" before starting your repair
  3. Compressor won't run or it is "clicking' on and off
  4. Cleaning the condenser coils
  5. Can my fridge be moved on it's side?
  6. Defrost drain freezes and then overflows
  7. Freezer door pops open when I shut the fresh food door
  8. GE Arctica repair tips...frost free trouble, freezing food, ect new25.gif
  9. How refrigerators work
  10. How a common defrost cycle works
  11. How to change a common condenser fan motor
  12. How to reverse the refrigerator doors on your refrigerator
  13. Help for storing an appliance
  14. How to change a common Whirlpool evaporator fan motor
  15. How to install or remove common shelf supports
  16. How long can I store food in my frost free refrigerator freezer and how?
  17. I heard a sizzling noise inside my freezer section and it looked like something on fire when I opened the freezer door. What should I do?
  18. I feel heat or warmth around my refrigerator doors...help!
  19. Important Disclaimer
  20. My fridge is running but not cold enough  - with Frost free repair information as well
  21. My refrigerator is leaking water inside the fridge
  22. My fridge is leaking onto the floor
  23. My fridge is freezing things
  24. My fridge makes a bang noise when it shuts off
  25. My Frost free fridge will not run at all
  26. My fridge is making   screeching/squeak noises
  27. My GE SxS fridge door has dropped and/or won't open or close properly
  28. My water dispenser has white flecks in the water...what's up?
  29. Mending a crack in the refrigerator liner
  30. New adaptive defrost information
  31. Ohm meter testing a start capacitor
  32. Odor complaints with your fridge
  33. Replace a door gasket on a refrigerator
  34. Sample wiring diagrams
  35. Stainless Steel Cleaning
  36. Some help for an Amana refrigerator fan motor that will not run
  37. Will my freezer or refrigerator work ok in my garage?
  38. Whirlpool built refrigerator defrost timer installation help
  39. Water line "Y" hose for icemaker broken helps
Apr 01, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fitting an integrated fridge freezer!
Hi Gareth. I fitted a door to my Hotpoint hsz2321L today. I used self tapping screws through the brackets into the fridge door sides. Looking at the old fridge that came out showed that this was the method used previously. No seal is broken and so the fridge is working perfectly. I do have an issue re-fitting the door onto the new fridge though. The pivot hinge on my fridge doesnt give enough clearance and so it catches on the unit at the side of it. The old fridge (a Bosch) cad cabinet hinges that would sort of concertina out to give clearence. Anyway, good luck.
Nov 23, 2008 | GE Profile GCG1700LII 15" Built-In Trash...
Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Nov 07, 2008 | Refrigerators
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Door on Zanussi Fridge Freezer ZTX520w
what causes this is the cabinet has moved ( twited ) from not being leveled on first install. what we do is pack the hinge up with a washer.
Oct 31, 2007 | Zanussi ZTX520W Top Freezer Refrigerator
Zanussi Z57 / 3 Bottom Freezer Refrigerator Logo
189 people viewed this question
Top Zanussi Refrigerators Experts
Felizardo Erilla
Felizardo Erilla
Colin Stickland
Colin Stickland
Mark Bowens
Mark Bowens
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
