Question about Dryers
Frigidaire Gas Dryer not heating Mode # FG975ESI
  • 254 Answers
Check your ignitor, if the ignitor glows you may have bad coils, located on the gas valve.
Posted on Jul 16, 2008
Dry will run for 5min then shut down but will run ok in timer mode
Consider a temperature switch that cuts in(turns off) if the dryer gets too hot. Does Timer Mode run with the heat on. Your dryer vent may be plugged causing the dryer to overheat.
Jan 27, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
I have a Frigidaire Dryer Model#FEQ1442ES0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Frigidaire Electric Dryer
Frigidaire dryer model fern7800ds0 doesn't heat
heatman101
Jul 14, 2011 | Frigidaire Electric Dryer
Frigidaire dryer will not heat
heatman101][
Jun 23, 2011 | Frigidaire GLER642A Electric Dryer
My Frigidaire Crown electric dryer isn't heating. The drum turns but no heat! HELP!
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 26, 2011 | Frigidaire GLER341A Electric Dryer
Frigidaire Gas Dryer, won't heat to dry clothes, we have cleaned the vents , were full, now clear, why won't it heat up. Gas turns on drum turns.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 10, 2010 | Frigidaire AGQ6000ES Gas Dryer
Hello i have a Frigidaire Gas Dryer model # CGR3600A53 it is not heating at all. how much is the heating element for this model and is the repair that tough?
heatman101
Jun 25, 2010 | Frigidaire FGQ332ES Gas Dryer
Frigidaire dryer no longer heats...
heatman101
Jun 08, 2010 | Frigidaire GLGQ332A Gas Dryer
Frigidaire AGQB6400FS not hot
heatman101
May 30, 2010 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
My frigidaire electric dryer wont heat up, only
heatman101
May 11, 2010 | Dryers
Dryers Logo
264 people viewed this question
Top Dryers Experts
