Question about Denon AVR-3802 Receiver
How to vary the Multi zone levels at the receiver
This is encouraging: I have EXACTLY the same problem! I've had the unit for a few years and never had this, but a couple months ago it occurred and the operating instructions do not provide a clue how to adjust the volume for other rooms (Multi function). There is a brief section "Setting the multi vol. level", but nowhere is there a hint how to vary the levels (extremely high volumes in all Multi locations). One would assume from the description that "Variable" is the correct option (and, of course, I've tried all 3 options), but neither that nor the other 2 options appear to be adjustable at the receiver. For the "Variable" option it states: "The level can be adjusted freely using the buttons on the remote control unit." IT DOES NOT STATE HOW!!! Frustrating.
  • 151 Answers
Try putting amp to zone 2 go to set up menu for "variable" volume adjust and turn down the volume with the remote control volume buttons or use the volume control on the amp,this should work,i had the same problem with a YAMAHA amp and this worked.
hope this helps.
CABLE GUY.
Posted on Jul 16, 2008
The receiver will not turn on, there is a red led that continuously blinks on far left corner of display
The unit is in protect mode. Try holding the advanced surround and power buttons for around 5 seconds. the unit should turn back on. If it turns back off after a few seconds, then you most likely have a problem in the amplifier that will need to be repaired.
May 28, 2015 | Pioneer VSX-1123-K 7.2 Channel HD...
Warning levels
Hello
The (+ve) & (--ve) poles of the connection wires have neen reversed is the meaning. Just interchange the wires of each either at speaker box or at the output terminals of the amp. If these connection are reversed, the sound effect will vary in intesity. OK.
Jan 10, 2012 | Yamaha HTR-6130 Receiver
Unit only stays on for 4 seconds then turns itself off.
This is a short or unstable ohm load. Remove all speaker wire connections to see if the amp will stay on.
If the problem goes away when disconnecting the speaker wires try this:
1) Check volume level on zone one and zone 2 if connected. If it is too high the amp will go into protect mode and shut off exactly as you described.
2) Make sure no wires are touching any other wire or the metal surface of the amp. This will cause a short and send the amp into protect mode.
Nov 21, 2009 | Denon AVR-1705 Receiver
Subwoofer amplifier
Here's how I'd do it... connect the subwoofer pre-out to one of the unused analog inputs (CD or CD-R perhaps?). Turn on Zone 2 by pressing the MULTI-ZONE ON/OFF button. The MULTI-ZONE indicator will light.
Press CONTROL. (Zone 2 should display) Use the INPUT SELECTOR dial to select the source for the zone you have selected. In my example, CD or CD-R.
Of course, you'll need the sub hooked up to the Surround back speaker terminals.
Here's a link to the manual online:
Pioneer VSX-1018 Manual
Things to keep in mind:
The Surround Back setting must be set to ZONE 2. See page 41 of the manual.
The volume level going to the sub will probably need some tweaking. Check out page 7 to see how to manually adjust volume levels, or get it close by adjusting the Master Volume while in Zone 2 control.
I'm not sure if the auto setup function (with the included microphone) will work properly with this setup. And, of course, this is not a "suggested" setup by Pioneer, so please use caution when hooking everything up.
Apr 21, 2009 | Audio Players & Recorders
Denon AVR-4802R automatically shuts off in multi-zone mode
i had the volume of the multi-zone tuned too high and was attenuating it in an external control box. Once i took the multi-zone volume down to -25db, the problem went way. My main zone was operating around -35db so did not have the problem.
Nov 23, 2008 | Denon AVR-4802 Receiver
Multi-zone volume levels --not adjustable (too high!)
Press the reciever button on tyhe remote until it say Multi in the display. You can now adjust the multi zone volume level.
Jul 18, 2008 | Denon AVR-3802 Receiver
Multi Room / Multi zone problems
As you may see from my posted response to a posting that correctly ID'd the solution, the answer to your problem is found on p. 47 of the manual (regarding how to adjust the multi volume levels as stated on p. 26).
Jun 20, 2008 | Denon AVR-3802 Receiver
It keeps shutting off
If you have zone 2 active with the level turned up too much it will cut out the whole unit. Try disconnecting zone 2 speakers, then turn the volume level way down on zone 2 and it should stay on if that is the problem.
Jan 02, 2008 | Onkyo TX-SR803 Receiver
Onkyo 805 zone 2 problem
I just figured out what I was doing wrong last night. On the 806 at least, when zone 2 is not powered (receiver is set to act) there is a separate volume control 'level' that is on the receiver a couple buttons right of the zone 2 button. By default this level appeared to be set to -50db. As soon as I turned up this level sound came out of my zone two.
Denon AVR-3802 Receiver Logo
144 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
