Question about HP OfficeJet 7310 All-In-One InkJet Printer
Copies super slow (as in best mode) even when i set it to "fast"
I set the copier to "fast" and attempt to copy some pages. The first one will come out super quick but the second or third will revert to the "best" mode and be sooooo slow and super detailed. This occurs all the time and drives me crazy on large print jobs. It slows us down and uses all our ink. We've had it for 2 1/2 years and this is the first year it acts this way.
  • Anonymous Aug 06, 2008
    Yes I have the same problem.
    Now the printer will only print in the "best" mode and NOT AT ALL in the ordinary and fast modes.
    I've restarted both the computer and printer and confirmed settings on the printer, however NO results.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
You may need a fresh set of drivers on this..
www.hp.com
Posted on Aug 20, 2008
Printing multiple double sided copies doesn't break between copies
Select the simplex/duplex mode.
1 sided - 1 sided
1 sided - 2 sided
2 sided - 2 sided
When using 1 sided to 2 sided the originals must be even
Jan 30, 2013 | Konica Minolta Bizhub C364 Color Copier /...
My printer prints multiple pages even though number of copies in setting shows 1
Try looking here: open your printers fax folder. Your printer should be listed here, right click on it and select properties. Now click on the advance tab. There should be a printer defaults button, click on it. Make sure your copies number is set to 1. Then click ok on each window and close.
Hope this helps
Feb 13, 2012 | Dell 1320c Laser Printer
Ux355l copyer , when i press copy button to make a copy it say press wrong key, can u help me.
I tend to think that you are pressing wrongly. Place the document to be copied facing down on the fax document side and then press COPY/HELP key1 Load the document(s) face down.
(Maximum of 10 pages.)
The display will show:
READY TO SEND
• Set the resolution and/or contrast if RECEPTION
MODE
desired. (The default setting for
copying is SUPER FINE.).
2 Press the COPY/HELP key.
COPY/HELP
COPY MODE
START KEY: SINGLE
COPY KEY: MULTI
? If you are only making one copy of the original (or of each original)
and don't want to make a reduction or enlargement setting, press the
START/MEMORY key twice. Copying will begin.
and want to make an enlargement or reduction setting, press the
START/MEMORY key and go to Step 5.
3 Press the COPY key (MULTI ) if you
want to make multiple copies of each COPY/HELP
original.
ENTER # (01-99)
4 Enter the number of copies per
original (if the number is less than 10, 0 3
enter a "0" before the number).
Example: Three
copies per original
COPY RATIO
Originals
BC
A
MULTI COPY
AA BB CC
A B C
You can get its manual here.
Jan 08, 2011 | Sharp Office Equipment & Supplies
Hp photosmart 8200
HP updates are a good idea periodically. I had the same problem and i did a windows update then an HP update and voila!
Sep 22, 2009 | Office Equipment & Supplies
How do you print from dark to darker using HP officejet 5610 printer ? When I am photo copying, the result of a copy, is hard to be read.
there is a setting on the control panel for "Best Normal or fast"select best for high quality, Normal for normal and fast for draft copies.
Jul 29, 2009 | HP Officejet 5610 All-In-One InkJet...
Ricoh FT 4015 too dark
Depends how many copies are in it. The PCU goes at about 60,000 prints its ordered as a supply. This is the heart of the machine. Lastly would be the fuser. -Carl
Jul 10, 2009 | Ricoh Office Equipment & Supplies
Similar problem with a 6020
use pcl 5c L1 (please note it's very fast driver but only for single set print because this driver have some fault if you select 2 copies for print it print 4 copies so for single set it is the best and for many set try pcl 6 driver)
Jun 15, 2009 | Canon imageRUNNER 5020 Copier
MP830 prints lightly about every 2 cm down a page from computer.
Sounds like it's in draft mode...
On the MP830 locate the "settings" button (top right of the cursor circle and left of the 1 key).
Press "settings"
This should give you the "Print Quality" settings page on the LED
Locate the 3rd field down which probably says "Fast", change this to "Standard"
Press the "settings" button again to register the change.
Also possible that your contrast is causing problems... Check to see where the red bar is in the gradient (white to black line) under the "Copies" field on the LED in copy mode. If it's way over to the left that would also explain some of the problem.
Pressing the right arrow key on the circle controller will increase contrast although I'm not sure if it will retain this setting.
Hope that helps.
Jan 29, 2009 | Canon PIXMA MP830 All-In-One InkJet...
4 sets of copy counter numbers on canon imagerunner 2200
101:Total black copies and printed pages
103:Total A3 black copies and printed pages
201:Total A4 black copies
203:Total A3 black copies
Oct 31, 2008 | Canon imageRUNNER 2200
Copy settings
its normal in hp printers.it is not a fault.still u can delete the old drivers and reload the printer drivers again.as it will delete all the old setting which is making it slow and will work properly.
Oct 20, 2008 | HP PSC 2410 All-In-One InkJet Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
166 people viewed this question
Seeker5211
Seeker5211
