Question about HP Desktop Computers - Hewlett-Packard 3.0GHz Intel Celeron D 160GB Desktop Computer with DVD+/-R/RW/CD... (A1110NPX743AA)
DVD DRIVE WORKS, BUT CD DRIVE DEAD
MY DVD DRIVE WORKS, BUT MY CD DRIVE DOES NOT. IT IS AS IF IT IS NOT EVEN THERE. IT DOES NOT SHOW UP IN "MY COMPUTER", WILL NOT OPEN WHEN I PUSH BUTTON OR TRY TO OPEN FROM COMPUTER SCREEN. IT IS AN HP MEDIA CENTER USING WINDOWS XP.
  • kmeyer Jul 16, 2008
    THANK YOU. I'LL TRY THAT TONIGHT. I LIKE YOUR PICTURE.
  • Anonymous Sep 09, 2008
    My DVD Rom drive is not reflected in my MYCOMPUTER interface. I cannot hear sounds again from my HP desktop computer.
    Please help. I am using Windows XP
  • 137 Answers
Try using the manual eject that is as small as a pinhole just below or beside the CD drive. Once you find out that you can manually eject you may be able to insert a cleaning cd to clean the device.
If that doesn't work check device manager to see if it has the proper driver or if it's recognized that it's installed in the system.
Posted on Jul 16, 2008
My T3104 came with a cd burner. I upgraded it to a DVD burner. I have NEVER had a problem with it. I have several mvies and such I have made over the years. I thought OK...It's DEAD. I replaced it with...
If they were both working on separate machines, the answer must lie in how you have configured them on your PC.
Remember that your dvd/or cd drive would be the SECONDARY MASTER. If you have both cd drive and dvd drive set as master,this may cause your PC to not recognise them.
Look on the back of the cd drive and the dvd drive - at the small jumper switches, which fit onto pins. There will also be a diagram on the drive somewhere. Look for CSM C= cable select (let the computer choose which is which. M= Master, which means you set that particular drive as the secondary master. S- slave. You set whichever drive as the slave.
The drive on the end of the cable (furthest away from the motherboard) should be set as MASTER. Any other drive on that same cable should be set as slave.
Aug 30, 2013 | E-Machines (T3104) PC Desktop
Tip
Dell vostros 220 cd/dvd drive not working
my cd/dvd drive quit working device manager showed the triangle and ! mark, properties showed code 10. shut power off, took side case off, unpluged both cd/dvd's, from the board, restarted machine let it reboot, shut power off again,plugged both cd/dvd's back in, restarted machine, both were reinstalled and now working. hopes this is some help to somebody else. thanks jim.
on Jun 22, 2011 | Dell Vostro 220 Desktop Computer
What shall i do?
ALEN CHECK YOUR ELECTRICAL CORD TO THE CD-DRIVE.
THE WIDE ONE THE OTHER ONE IS SATA (DATA)
Apr 15, 2013 | Computers & Internet
CD/DVD SEEMS TO HAVE STOPPED WORKING
If you have a CD or DVD in the drive and it still doesn't show up or work then yes it's dead. Luckily they are cheap and easy to replace.
May 20, 2012 | Dell Inspiron One 2305 Desktop Computer...
Last week my HP Pavillion a810N running Windows XP stopped showing my internal (IDE) CD and DVD drives. I went into system settings at boot time and the devices are no longer showing (only my floppy and...
No, the southbridge simply is no longer working properly - the PATA controller to which the optical drives are connected has failed. The motherboard is dead, you must replace it.
Sep 11, 2011 | HP Pavilion a810n (PP164AA) PC Desktop
I have a Systemax Venture Microsoft Windows XP Pro Version 2002 Service Pack 3. The system will not longer play dvd's or cd's and cannot burn cd's as well. I'm not sure if something has...
Well the fact that when you put in a cd it does not see it indicates that either the CD Drive is not being detected or the drive has gone faulty and needs replacing.
First Look in the bios of the computer to see if it is seen the drives section. If it is there then look in windows under control panel , system, device manager. Now look under DVD/CD Roms drives (this may differ slightly in XP) to see if in there with no error against it. If not and not in the bios either then the drive has failed. If however it shows in DVD/CD Roms with no error then try a different make of cd/DVD. If this works then the Bios of the drive will need updating. This info is on the manufacturers website. Good luck.
May 10, 2011 | Systemax Venture PC Desktop
When I open Dell 24000 I get an error sign primary drive 0 not found It tells me to hit f2-- but when I do I get no response. A colleague told me it was a loose cable so i have opened the tower but I do...
the hard drive IDE cables are flat, ribbon cables, usually grey and about 3 inches wide. do not confuse this with the floppy drive cable, which will look identical, except that it is 2 inches wide.
the cable could be loose on either the motherboard IDE controller end or the hard drive end, so wiggle it in tighter, or unplug and then re-plug it at both ends, and then try to boot. if that does not work, then replace the cable.
if a new cable does not fix it, then the hard drive itself may have failed. install the hard drive in a DIFFERENT working computer as a secondary (slave drive) by installing it to the middle connector of the IDE cable (IDE cables have a connector for the "master" or only drive at the end, and a plug for a "slave" drive in the middle of the cable), and see if you can access it. it will probably show up as the "E" drive under "computer" or "my computer". if it does not show up, check and see if it shows up under "administrative tools>computer management>disk management". if the drive is not showing up, then it is dead. if the drive works in the second computer, then the IDE CONTROLLER is the culprit.
if the motherboard's integrated IDE controller is dead, you may want to try the OTHER IDE controller socket. most computers from that era have 2 IDE controller sockets, and usually attach the hard drive(s) to one, and the cd/dvd rom(s) to the other. since the hard drive cables have plugs for 2 devices, you can attach both the hard drive and a single cd/dvd drive to the 2nd ide controller socket, in cases where the 1st ide controller soocet no longer works. attach the hard drive to the end of the IDE cable, and the cd/dvd drive to the middle of the IDE cable, as the "master" or boot device should always be attached to the end of the IDE cable.
you can also purchase an add-in, pci card ATA/IDE controller card, and use this instead of the motherboard's integrated IDE controller sockets.
Nov 06, 2010 | Computers & Internet
My dimension 5150 does not burn cd's any more
CD/DVD drives are even less reliable than the cheap power supplies generally used in packaged PCs. Of two new, brand-name drives by Lite-On, one was DOA and the second ran for 2 days.
You can try removing (deleting) the drive from the Device Manager list, then rebooting. If the drive is at all usable, Windows should 'find' it and reinstall the driver needed.
If this doesn't work, the drive is likely dead.
Aug 14, 2010 | Dell Dimension 5150 (DIM515MIN) PC Desktop
CD Drive not working at all
If its the only CD Drive on that IDE cable it wouldn't be set as slave, would be on Master.
Yes you can go to http://www.driverguide.com you can download updated drivers for IDE and SATA on your PC.I checked on Acer support but there website isnt't working correctly for me.
Try updating the drivers, and try both drives again one at a time.
Jan 07, 2009 | Acer Aspire™ T180 PC Desktop
Compac Presario V2000 DVD CD read problem
ok sir witch company your DVD - RW first telme ?
ok any one open dvd drive clean lenss with cottin net fit same dvd use the dvd & cd data check data cable. open carefully ok you don't know contact H/W Eng : if Any Problam My email id : uday_uday2004@rediffmail.com
Apr 02, 2008 | Computers & Internet
HP Desktop Computers - Hewlett-Packard 3.0GHz Intel Celeron D 160GB Desktop Computer with DVD+/-R/RW/CD... (A1110NPX743AA) Logo
Top HP Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
