Question about Fuji FinePix S5000 Digital Camera
Install S5200 I have s5200..got a new computer that has windows vista..need help installing...put cd in player and nothing happens...do no see MY compueter on vista....could use come assistance
  • rdh9 Nov 26, 2008
    same problem
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Posted on Dec 26, 2012
SOURCE: focus
I had a similar problem, and found I had set focus mode for C-AF or continuas focus. I set for S-AF single point focus, and I can focus on the foreground or backgroung. Remember it will focus on a high contrast feature in the focus zone, so tree limbs in the foreground can cause an error.
Posted on Mar 25, 2008
  • 4 Answers
SOURCE: my daughter has a fuji
According to the manual, you should turn the camera on again, taking care not to touch the lens. It also says to turn the camera off and on again. If the message still appears, it says to contact your Fuji dealer. I'm sure you've already tried turning it off and on. Hope this helps maybe. Good luck.
Posted on Jan 04, 2009
  • 5 Answers
SOURCE: focus error
You will have to disassemble the unit. 2 screws on 1 side and 1 on the other and 2 on the bottom, pop the back off, being careful of the 2 ribbon cables attached to the rear and unock these cables and remove. 3 screws holding the top circuit board (remove the eye piece first and unplug the 2 cables attached to it) carefully unplug all cables attached to this top board and unscrew and remove (there is one on the bottom of the board that you must flip to unlatch. After you remove that board there is the power board... BE CAREFUL!!! The flash capacitor (the black tube looking unit on the bottom of this board) stores chrge and you WILL feel it if you touch the terminals... it they touch metal you will see fireworks so be careful. unplug the single red and black wire plug and unscrew the 3 screws here You do not have to remove the white plug with the 4 or 5 wires because you can just flip the board over out of the uni.. BE CAREFUL!!. unscrew the 2 silver screws securing the metal plate underneath and remove this plate. now remove the single screw left and pull out the lens assem. Here check 2 places... 1 is he zoom screw (it is behind the long silver panel) and also the focus screw (behind the shorter metal panel. Do one at a time. remove the screws from one of them and carefully lift off the motor plate. for he zoom line to metal ring on the screw into the groove of the lens (Shaped like a V) carefully screw the screws back in bu d ni tighten to tight, leave a LITTLE slack. (1/8 turn from tight). Now for the focus screw, remove the cover and align the ring to encase the top of the V The ring is shaped like < the lens is a > so just allow the rinng on the screw to "pinch" the top of the lens groove. secure like you did the other plate (dont forget to back out 1/8 of a turn) reassemble the opposite of disassembly and you are done... it look hard but it is actually pretty easy... any uestions email me at worldin1@gmail.com
Posted on Feb 21, 2009
  • 73 Answers
SOURCE: Fuji S5200 view finder reads Frame No. Full
Go into setup menu by pressing menu, scroll to >set< then scroll to >frame number< and change the default 'cont' to 'renew' Save the new setting and leave the set-up menu. That should solve your problem.
Posted on Jul 25, 2010
lock123
  • 6831 Answers
SOURCE: My fujifilm finepix S5200 camera
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 21, 2010
Can you trace a stolen toshiba satellite c655d-s5200
Not that I know of.
You can install a tracking software in the computer, for in case it's stolen, but this has to be BEFORE it is stolen.
Rest assured whomever stole it will get their just reward.
Karma, you know.
Regards,
joecoolvette
Jan 20, 2013 | Computers & Internet
I forgot my samsung s5200 security password ...how can i creat new one password
here all hard reset of samsung mobile phone . but your samsung reset all data..
*2767*3855# - FULL E2P RESET
*2767*2878# - CUSTOM E2P RESET
#*7337# - UNLOCK
*2767*688# - UNLOCK
*#0523# - CONTRAST
*#9998*523# - CONTRAST
Mar 03, 2011 | Samsung Cell Phones
What is the default password for samsung S5200 mobile phone? i want to put a phone lock but it is asking for a password.
Jul 01, 2010 | Cell Phones
Cannot Install
It might not run on vista. Vista in incredibly picky and most games needs patches. Best bet is to go to the sims website and see if they have the patch for vista.
Oct 05, 2008 | Maxis Sim Isle
S5200 does not correct for light conditions anymore.
You should reset to default the camera settings if you're not really sure what to change...but I thing the exposure has to do with the lighting conditions and also the picture mode(indoor, cloudy, night, sunny etc.) See if any of these will help you.
Sep 02, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
S5200 Black Screen
The CCD is dead (most likely). Nothing the user can do to correct. Must be serviced. Get an estimate. Approx $100 US, unless covered by warranty.
May 25, 2008 | Fuji FinePix S5200 / S5600 Digital Camera
Lost installation CD
if you have Vista you wont need any software, but if your on XP you may need the driver cd, click below, but to get any software you have to be registered with fuji. http://www.fujifilm.co.uk/digital/cameras/s5600/index.php?page=drivers&flash=9
Sep 02, 2007 | Fuji FinePix S5200 / S5600 Digital Camera
Fuji FinePix S5000 Digital Camera Logo
43 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
