Question about Whirlpool 24 in. ADP5740 Free-standing Dishwasher
Whirlpool adp 5540 dishwasher
Hi
my dishwasher has got me stumped, it will fill with water, water gets hot. it will drain properly, but it will not push water around the inside, i have taken out the pump (larger one) and taken apert the impellor housing and found that the impellor was loose on the magnetic shaft, i found this to be a sealed unit with no access to get the impellor itself out and figured that this was the cause of the water not circulating, due to free spinning on the shaft. i drilled a hole in the end of the impellor and filled it with locktite glue which held the impellor in place properly as i felt resistance when i put the magnetic end back into the coil housing, but again no luck, it will fill to the required amount, the heater is working it will go through the cycle but no water pushing through any of the jets. (they have been cleaned and are not blocked) even without the arms connected still very little water coming out with no pressure. when i pulled the motor out is was hot, so i can only assume it its tying to work by powering up, i put the test meter on ohms and was showing resistance, so can only assume the windings are intact.
i have had very little satisfaction with whirlpool as they don't sell spare pasrts to the public, i got onto one person who will sell me a motor but costs $210aus with no guarantee that is the problem it is doing my head in, i don't like failures when fixing things and would hate to think it is something else simple, maybe even something to do with the control panel on the front for all i know, i don't want to throw it out as it is only purchased 4-5 years ago and would like to think i would get a bit more use out of it than what i have. any help would be appreciated.
thanks
Billy
    Problem Solver:
  • 10 Answers
Try stareast sales in Sydney, they have generic pumps that should work
Posted on Jun 20, 2009
Billy
We have the same problem how did you go?
Graham Bendigo VIC
Posted on Nov 26, 2009
    Problem Solver:
Graham Bendigo VIC
did you have any luck?
i have the same problem
Posted on May 13, 2010
Whirlpool dishwasher adps 5540 i get f6 e1 error?? how can i fix this?
First find out the significance of the code and then knowing what the issue may be you can attempt to fix it.
Sep 21, 2017 | Whirlpool Dishwashers
Dishwasher slowly fills after cycle
If water slowly fills in the tub when not in use.
a) Most likely your machine inlet water valve not seating properly and closing. Change the machine water valve.
b) May be sink drain water back flowing to the tub. But you have checked that.
So it has to be the machine inlet water valve.
Apr 11, 2015 | Whirlpool Dishwashers
We have an ADP 262 dishwasher and won't release some of the water
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 28, 2010 | Whirlpool Dishwashers
Will not fill with water during cycle on my whirlpool adp 262 dishwasher
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Sep 22, 2010 | Whirlpool Dishwashers
Whirlpool adp 5550
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
heatman101
Aug 29, 2010 | Dishwashers
Dishwasher not working
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
May 13, 2010 | Whirlpool 24 in. ADP5740 Free-standing...
I have a whirlpool dishwasher ADP 5540 and the top 2 blades dont seem to go round...Any ideas?
check botton sprayarm for crack, hole clog up an make sure the tower is under upper sprayarm
Apr 25, 2010 | Whirlpool 24 in. DU915PWP Built-in...
Whirlpool adp 5540
My dishwasher isnt working anymore after i cleaned the filters? i took out and cleaned the filters in it and now it doesnt seem to be working properly. it goes thru the cycle but its not cleaning. the dishwashing tablet falls to the bottom and isnt even dissolved completetly after the cycle has finished. is it possible that its blocked somewhere?
It is a Whirlpool ADP 5540
thanks for your help
**** the walls are still dirty after the cycle but there is steam in there as if its done its normal cycle
May 13, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Dishwashwer not cleaning properly
You can try one of the cleaners sold for this purpose like glisten, dishwasher magic or jetdry dishwasher cleaner. It may not be getting enough water due to the fill valve clogging up. You can check this by small amounts of water slowly with a cup in the wash cycle and quickly opening the door to see if the upper sprayarm is turning. If more water helps you need to replace the valve.
Apr 18, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool adp 8540 - 7 flashes
replace the control board in the console
Apr 10, 2008 | Dishwashers
Whirlpool 24 in. ADP5740 Free-standing Dishwasher Logo
819 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
