CANON PC735 COPIER, PAPER JAM LIGHT KEEPS COMING ON BUT THERE ISNT ANY PAPER OR ANYTHING BLOCKING THE MACHINE, TRIED RESETTING IT NOTHING WORKS PLEASE HELP.
  • txncmr Sep 08, 2008
    i have the same problem. the paper jam light kept comming while no jammed paper could be found.
  • jamesgray2 Jan 04, 2009
    I have the same issue. I've blasted a ton of compressed air in the thing, but there's absolutely nothing in there. I'm afraid it might be a mechanical malfunction with the scanner causing the system to lock up and give a paper jam warning in error. I hope that's not it.
For the problem with the personal copier pc735 paper jam, I had the same problem. I was told the problem might be fixed by downloading the drivers and reload them. The PC735 I have does not have drivers nor a scan. My problem was a spring fell off on the idler gear and had to be reattached. I then cleaned the interior and this fixed the copier. You might look to see if a spring came loose on the back side of the bottom frame. I'm no machanic so I had a canon rep fix it for me. This fixed my problem. No more paper jam light.
Bob At DottyW4658@aol.com
Posted on Oct 15, 2009
How do you clean sensor on canon pc735
Find the sensor and make sure no paper particles are blocking it.
Oct 18, 2016 | Canon 730i Laser Printer
I'm at work, and the fax printer copier and scanner we have here is a canon IR2030i. A piece of paper was jammed, which I have removed, but the printer still registers as having a paper jam. I have looked...
Please NEVER turn upside down machines like thit one. Lots of shits can happened!!!!
When you open left cover you will have to find paper sensors (little black pawls) and try to shake it a little(maybe someone is stacked). And please keep looking for piece of paper somewhere(look in all paper trays too)
pifonski
Feb 25, 2011 | Canon iR 2030i All-In-One Laser Printer
Constant paper jam on Canon PC735 copier. Tried all the usual steps to removing or preventing as paper jam, and they are not helping. The problem started after the cartridge was removed and rocked back...
If the machine did not show a paper jam until the toner cartridge was removed and then reinstalled, I would remove the cartridge and check the paper path for the paper switch, it normally is a small black lever. Make sure it isn't stuck in the down position. If the switch is OK, check the cartridge to be sure there isn't any damage that may cause the paper switch to be actuated when the cartridge is installed into the machine. Sometimes there is a protective cover on the cartridge that moves when installed, this cover can be knocked out of place.
Jul 19, 2017 | Canon Office Equipment & Supplies
Canon PIXMA MP2the paper jamming light is staying on. there is no
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 26, 2010 | Office Equipment & Supplies
Canon PC735 copier, paper jam light keeps coming on but there isnt any paper or anything blocking the machine. Tried resetting but nothing has worked. What can I do?
My canon copier pc735 says we have a paper jam- but it does not. We just replaced the cartridge and it wont work. I had them send me a new cartridge, but its the same thing- paper jam. Help!
Oct 10, 2009 | Office Equipment & Supplies
Paper jams but doesn't go anywhere!
Hello there
Jul 03, 2009 | Canon PIXMA iP1600 Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Paper jam
Hello there Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
May 10, 2009 | Canon MultiPASS MP730 All-In-One InkJet...
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper won't feed
Hello there
Aug 21, 2008 | Canon PIXMA iP1600 Printer
Printer
Aug 08, 2008 | Canon PIXMA MP510 All-In-One InkJet...
1,108 people viewed this question
jasbo
jasbo
