I have bought an old B&O beogram rx2 turntable and am having difficulty playing any records. When I press play the needle will sit on the edge of the record but when it moves in to the grooves it seems to slip off back to the beginning. I have never had a record player before so it could simply be because the needle is worn out and it isn't sitting in the grooves properly. Thanks
  • 151 Answers
If you cannot see a small tip on the needle then yes it is worn out,but you can check by rubbing your finger over the tip when the system is on,if you hear sound through the speakers then it should play the album,make sure that the weight at the back of the arm is set to keep the needle in the groove as this may be set to far back,move it forward to keep weight on the needle.
hope this helps.
CABLE GUY.
Posted on Jul 16, 2008
Needle jumps on all new vinyl, but plays old records fine. New vinyl plays on other turntables without a problem. Do you have any suggestions?
Adjust the balance force up. This is a counterweight on the back of the arm. For most needles it is 1-2 grams.
Jul 06, 2014 | Crosley Audio Players & Recorders
I have a Bang&Olufsen Beogram
Similar to most Beogram 1800, the RX 2 featured record sizing by weight. When Play was selected, the centre part of the platter would raise gently, with only just enough force to lift a 45RPM single. An LP would be too heavy to lift, so the mechanism would set itself to 45RPM and 18cm if the record lifted, 33RPM and 30cm if it did not. The speed control keys could then be used to override the choice for non-standard records. The parts could also detect if a record was not present, and prevent the turntable being activated
Just put lp on and it should work
Jul 08, 2008 | Audio Players & Recorders
After sitting unused for many years, I just
Hi, Does the arm have a lever to lift the arm up, also called a cue. I had an arm where it did exactly the same thing and found it to be the lifting device. What turntable is it you have?
May 12, 2010 | Audio Players & Recorders
New Memorex 9285MMO, loud hissing + ring dig on record
Probably the needle, I work on them and many needles are bad from new. They were put on wrong in the first place. Try taking the red part off and make sure there is a needle part and that its straight.
Jan 16, 2010 | Memorex MX212 Turntable
Needle skipping & not pushing down
There should be an "anti-skate" adjustment to control the arm moving across the record. It is possible that lubrication has stiffened up as well. This unit may need a general overhaul/cleaning.
Dan
Jul 20, 2009 | Technics SL-1210MK5 Turntable
Turntable starts playing record middle 1st song
The tonearm lift is no longer level as it should be and the arm is sliding along it under gravity as the arm lowers to the record. Has it received a knock?
Have a close look to see whether it has been tilted slightly. That would be enough to give the problem.
Jan 24, 2009 | Kenwood KD-291RC Turntable
Pioneer PL-670 record rejects continually
Are the record size tabs sticking up through the turntable platter cover? They sense the size of the record being played and adjust the run out distance for either 45 or 33 rpm records.
Jan 04, 2009 | Audio Players & Recorders
Beogram 1800 wont play the record!!
possibly some kind of obstruction inside.
I had something similar with my turntable, and it had a dirt dauber nest inside it!
no kidding.
Dec 03, 2008 | Audio Players & Recorders
184 people viewed this question
 Grubhead
Grubhead
