Question about Dell OptiPlex SX270 PC Desktop
Does not detect module bay cd drive
Hello, my dell Optiplex SX270 is having problems with the CD drive in it's module bay. the diag lights on the back insist it's a failure in the machine and not the drive. I got this thing at a redistribution center so it has no warranty what-so-ever, is there anything i can do to it? Oh and it came with the HDD WIPED CLEAN. so no operating system is on it.
  • Anonymous Oct 25, 2008
    AUDIO
Well I decided to buy a new drive after a run of the dell diagnostic partition. (How it survived the wipe, I don't know.) and it came to a conclusion that the drive is dead. And that the POST (not diagnostic) lights on the back meant I had forgot to connect the keyboard AND mouse. I only had a keyboard for it then.
Posted on Jul 17, 2008
Cd rom detection problem on optiplex gx110
have you checked to see if the cd drive is showing up in MY COMPUTER?
if it's not the it's possible that the cd drive needs to be replaced
Apr 04, 2012 | Dell OptiPlex GX110 PC Desktop
Optiplex SX270 LED light code
Hello
The LED code you described indicates a memory failure. Remove and re-install all of your memory. If this does not fix the issue, remove all memory and insert one stick at a time until the unit turns on. Replace faulty memory.
Here is the LED Code guide from Dell...
http://support.dell.com/support/edocs/systems/opgx270/en/ug/solve.htm#1235408
May 01, 2010 | Dell OptiPlex SX270 PC Desktop
Its just stuck on the Dell screen at the begining energy starpage
if the system doesn't boot past the Dell Screen, the most likely issue is the hard drive.
See if you can bring up the F12 menu at boot and run HDD diags.
If you can't do that and have the dell resource cd, you can try booting to that CD, and run diags there
Apr 09, 2010 | Dell OptiPlex 330 Desktop Desktop Computer...
Windows XP CD cannot be detected in Dell Optiplex gx260
Your optical drive might be dirty or bad. Try an official Dell disk to see if it will read it, especially a Dell drivers and Utilities disk. Also try a boot flash drive or boot floppy(since your system is a older) to get the system up. If your system comes up any of those ways, I would try a disk cleaner. If that doesn't help, then you probably have a bad cd drive. You could also look in bios setup to make sure the bios is showing your cd drive. It should list it there somewhere. Probably on the first page.
Feb 08, 2010 | Dell OptiPlex GX260 PC Desktop
Trying to fit new 1gb memory stick in dell optiplex sx 270 but the system will not acccept it and not boot up error codes of ab yellow but cd green all it does is beep when fitted yet i refit the 256mb...
Hello.
Memory is not interchangeable. Depends on your system, as to what memory to use. An error is telling you the memory is not correct for that PC.
Your Dell Optiplex sx 270 uses DDR PC2700 and DDR PC3200 memory.
Hope this helps.
Dec 20, 2009 | Dell OptiPlex SX270 PC Desktop
I have a dell sx270 desktop when I plug it in only the fan works
First of all, keep the front button pressed until the system shuts off. It might be one of several causes:
1) Memory module damaged (or dirty)
2) The processor is damaged, or
3) The motherboard parted off.
Remove the memory modules and test them one by one. Or if you can test them in another PC (assuming both PCs use the same kind of modules).
May 01, 2009 | Dell OptiPlex SX270 PC Desktop
Opening case
Hi
Check here for an illustration / guide to open OptiPlex SX270 cover.
If you still have problems get back to me
Mike
Jul 25, 2008 | Dell OptiPlex SX270 PC Desktop
Insructions needed open cover on specifically sx270 optiplex
Lay the unit DVDRoM face down, and then slide the green 'thingy' (technical jargon) on the back of the unit in the only direction that it will go (should be a diagram on the case itself, to show how...) and at the same time slide the upper casing forward. I have one of these suckers, and it ain't as easy as it could be, but it will move!
Phil
Jul 18, 2008 | Dell OptiPlex SX270 PC Desktop
Dell OptiPlex SX270 PC Desktop Logo
100 people viewed this question
Alun Cox
