Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Stove I have a GE stove that I want to convert it from gas pipe line to propane gas tank. I have bought the two nozzle or regulator to change but I don't know how to. Please help
  • 2 more comments
  • zinetmore Jul 16, 2008
  • Anonymous Jul 18, 2008
    I have bought the the two jets, I just don't know where the jets are located to replace them with the new one.If you know please let me know. Thanks
  • Anonymous Aug 08, 2008
    I have the same problem, I have the nozzles, I just need the directions, can you help
  • GE Master
  • 5,568 Answers
Because of the difference in energy between the two gases, the regulator is not all that needs changing.
I'm not sure which 'nozzles' you have but essentially all of the jets' one at each burner, at least one in the oven; probably two if your have a broiler element, need to be replaced.
It isn't a hard job but I suggest you speak to the manufacturer about re-jetting and where to order the parts you need.
Posted on Jul 18, 2008
The oven temperature on my GE XL44 propane range is inconsistent. I set it at 350, and then I'll check the inside thermometer a half hour later and it will read 450. Drives my wife crazy. Some days it...
Hello. One question has your range burner jets been changed to LP (liquid propane). If you are using natural gas jets for the burners and ovens this make the heat and flam fluctuate in temperature and the same for the oven. Natural gas jets are larger. One more thing here! There is a control valve spring with cap in the stove gas regulator that has to be taken out and turn around.
Search the operation manual on how to changes jets from natural gas to LP. In back of the stove behind one of the panels is a small cloth bag contain these LP jest and also there should be set of instruction in a bunch of languages.
If you are going to do this yourself--- DIY. Read those instruction ever carefully. There a bass ball valve that hook to the gas line before the flex stainless line behind you stove. Turn the nob to where it perpendicular to the gas line. Open the windows in the house and turn off all electric equipment such as, fans, toasters, don't be clicking the light switches off and on. Just a precaution for you and your family safety.
Check with your city zoning ordnance about home owner changing their gas jets in the range. Some cities and states won't allow you to due this. Then you will need a technician to preform this operation. I wish you and family well being and you safety first... GB you...stewbison
Aug 22, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Convert from Gas to Propane - I had this grill converted by a plumber from propane to gas (I believe he changed the nozzles and added a gas line instead of the propane line). I've had to move the...
The "nozzles", as you called them are actually the burner orifice. If you remove the burners and look back into the control panel, you should see the orifices that the plumber installed. They unscrew with a nut driver to be removed. Do this one at a time, installing the LP Gas Orifice immediately after removing the Natural Gas one. Be careful not to mix them up and reinstall the Natural Gas ones.
You will also need a LP Gas Regulator/Hose Assembly to connect to the grill tank, that you will be using. You can pick one up at any hardware store or home improvement center that sell grills & accessories. It runs about $30.00.
Below is a link to the Owner's Manual. But, I'm not sure it will be of help in changing the orifices. But, it's good to have for future reference. You can download and print it.
http://www.charbroil.com/bps/char-broil/char-broil/knowledge/80003061.pdf
I hope this helped you and Happy Grilling!! Thanks for choosing FixYa.
Aug 08, 2011 | Char-Broil 463254405 All-in-One Grill /...
How do I convert a Whirlpool super capacity 465 cook stove from natural gas to LP propane?
you have to change the little nozzles at each burner to smaller ones and then switch the plastic orfice around in the gas regulator thats on the stove where the gas hooks up.whirlpool should offer the kit to convert this stove.this must be done to insure it work properly.
Oct 28, 2009 | Whirlpool RF378LXKS Electric Kitchen Range
Hooking up a pool heater to propane.
A pressure regulator and pipe or hose. Whoever is selling you the tank/propane should be able to help you size everything based on the tank hook-up and tank pressure. The heater nameplate will tell you the proper inlet gas pressure that the regulator will need to reduce the tank pressure to.
Sep 07, 2009 | Hayward H Series
Ge propane kitchen range changed to natural gas.can't get the ove
Hi, Did you flip the cap on top of the regulator? As far as adjusting the bake/broil orfices, all you will nee to do is turn them 2 full turns counter clockwise. Start the oven and watch the flame. It should have blue tips as much as possible.
You might have to raise or lower the orfice adjustment as needed.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore gas stove Gas leak
I had this problem with my stove and had the regulator changed coming off the PROPANE tank.
Apr 04, 2017 | Kenmore Kitchen Ranges
Changing from natural gas to propane
You will need to contact the manufacturer for replacement burner nozzles. As Propane is at a higher pressure, the nozzles need to be smaller in diameter.
You will also need a tank fitting for Propane with a regulator attatched - and a large spanner to attatch it.
Make sure any pipe connector to this is fitted with an approved hose crimp, as "jubilee" type clamps are not recommended.
If you just fit the regulator, the burners can flare dangerously on the high settings - unless it has been designed to be dual fuel originally, and have replacement nozzles.
Jan 01, 2009 | Barbeques Galore Turbo Elite 4-Burner with...
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
How to check to see if gas stove has been converted to propane
The only thing you can do is look for a little (usually gold) nozzle connected to the orfice
propane burns blue and natural gas has the yellow tint to it
May 01, 2008 | Ovens
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
167 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
