Hp 2600n printer error 55.1 still persist after putting the printer off and on
Please give the solution for erroe 55.1
Posted on Oct 16, 2008
  • betlu Oct 16, 2008
    even after of and then on the printer facing same problem that is error 55.1 for hp 2600n
    Genius:
  • 2,035 Answers
55.1 is a DC controller error. You want to make sure the printer is pluged into a good power source with no surge protector. The manual says to upgrade the firmware on the dc controller and if that doesn't work the dc controller would need to be replaced. You can get the dc controller firmware upgrade at www.hp.com. then click on software and driver downloads. then model type and operating system. Then look for DC controller firmware upgrade. Download and follow the instructions in the read me file in order for more instructions to load into the printer.
Posted on Jul 16, 2008
Our printer is displaying 55.1 error. Is there any solution?
Thanks
Posted on Sep 19, 2008
    Master:
  • 623 Answers
You may have bent some pins when connecting the new tray unit or the wires in the connector itself are not making a proper connection. Try removing the connector from the tray 1 unit that connects to the dc controller and verify connectivity from the connector to the end of the cable within the paper feed unit. Make sure the
connector is plugged into the correct socket on the dc controller and that the cable di not get crushed between the chasis and the paper feed unit when you screwed it in as this could short the cable and also cause the error.
Posted on Nov 03, 2009
What is the good power scurce
Posted on Aug 12, 2008
3 Suggested Answers
  • 304 Answers
SOURCE: GOOD AFTERNOON, AFTER THE EXCHANGE'S BLACK AND
55.1 Error DC controller error.
The device has experienced an internal hardware error.
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
If a surge protector is being used, remove it.
Plug the device directly into the wall socket. Use the power switch to turn the device on.
Check the engine (DCC) firmware version.
Update if needed. Replace the DCC if a firmware upgrade does not resolve the issue.
Posted on Jul 13, 2011
Adi_Taticu
  • 71 Answers
SOURCE: HP 2600n
50.2 Fuser Error Turn off then on Description 50.2 Slow fuser error. The device has experienced an internal hardware error. Action
  1. Turn off the device, wait at least 25 minutes, and then turn on the device.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.
if no result,
Fix this with a new FUSER Assembly for HP Colour Laserjet 2600/n (200/240v) Part Number: RM1-1821-240CN or Fusing Assembly – RM1-1820(110/120v )
Posted on Oct 08, 2009
How to fix sensor error on hp color laserjet 2600
54.06
Error message
54.06
Description
Color density sensor error
Action
  1. Power cycle the printer.
  2. Calibrate the printer. Click here to view the document "HP Color LaserJet 2600n - Calibrating the printer" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314525).
  3. Change the Print Density settings through the HP Toolbox. Click here to view the document " HP Color LaserJet 2600n Printer - Change Device Print Settings in HP Toolbox" available on the HP Web site at (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00310627).
  4. If the problem continues, contact HP Customer Support Center for technical assistance athttp://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Apr 02, 2014 | HP Color LaserJet 2600n Printer
Error 55.1
Hello ,
you have open the printer itself, the connection between formatter & dc controller is not proper pls reseat them if further problem persists then replace the dc controler pca,this problem may be genrated by high voltage.
Regards
jm
Oct 28, 2011 | HP Color LaserJet 2600n Printer
Engine comm. error in hp2600n printer. i have changed my power cable and switch on and off to the printer
It's an Internal Communications Error. It is a warning message and shouldn't affect your printing. That being said, if it persists, you should call a tech to check it out.
Aug 14, 2011 | HP Color LaserJet 2600n Printer
GOOD AFTERNOON, AFTER THE EXCHANGE'S BLACK AND MAGENTA TONER PRINTER HP COLOR LASERJET 2600N 55.1 HAS THE ERROR AND EVEN BACK TO THE ORIGINAL CARTRIDGES and update the firmware the error persists.
Jul 13, 2011 | HP Color LaserJet 2600n Printer
10.103 Supply error
Yellow cartridge is bad, needs to be replaced.
1st try reinstalling the cartridge and power cycling the printer.
If error persists, then replace the cartridge.
Jun 27, 2011 | HP Color LaserJet 2600n Printer
My color Jaser jet 2600n does not recognize the new yellow print cartridge. I have tried two and they are right out of the box
If they are not genuine HP cartridges, they may be and are likely defective.....even two of them. I have seen it a millon times. Try putting the old one back in and see if the problem persists if it does not they are defective cartridges. Replace with genuine HP cartridge.
Jan 10, 2011 | HP Color LaserJet 2600n Printer
Right hand printer cartridge light is flashing - have taken it out and reinserted it, no luck, so put a new one in, still no luck. Only way I can get it to work is to take the right hand cartridge out and...
A Non-HP Toner Cartridge installed error message occurs in the following situations:
  • Non-HP cartridge is installed
  • HP cartridge is not installed correctly
  • False error
  • Sensor issue (hardware)
SOLUTION: The Non-HP Toner Cartridge installed error message could be cleared completing the following steps: All HP toner cartridges carry the Hewlett-Packard logo, and meet HP's high quality standards. 1. Verify that you are using a legitimate HP toner cartridge by going to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage. Click here to go to the HP LaserJet and Color LaserJet Printers - Counterfeit Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl01270) . 2. Remove the toner cartridges, clean the metallic contacts by a dry linen cloth, and then reseat the toner cartridge, and check if the error occurs. To reseat the toner cartridge, see the instructions at the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage. Click here to view the HP Color LaserJet 2600n Printer - Changing Print Cartridges webpage (http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314345) . 3. If the issue persists, perform a firmware upgrade from the Download drivers and software page at www.hp.com. 4. Restore the factory defaults in order to restore the default settings: a. Use the left arrow or the right arrow button to select Service , and then press SELECT . b. Use the left arrow or the right arrow button to select Restore defaults , and then press SELECT . If the issue still persists, even after completing the troubleshooting steps provided, then use one of the following support options so that HP can work with you to resolve the issue, because it may be related to printer hardware where it needs a live interaction
Oct 26, 2010 | HP Deskjet 460c InkJet Printer
Ihave hp 2600n printer error 55.1 & i turn it off and open with out soved pls help me thank
DescriptionDC controller error. The device has experienced an internal hardware error. Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information. 55.xx PRINTER ERROR alternates with CYCLE POWER TO CONTINUE An internal communications error occurred. The page containing the error will automatically be reprinted. 1. Check the power at the customer’s location. 2. Replace the formatter and/or firmware DIMM. 4. Replace the engine controller board. 5. Replace the formatter board. On the 5si, 8000, 8100 this could be a fuser problem. Try replacing the fuser.
Apr 11, 2010 | HP Color LaserJet 2600n Printer
Error 55
Error 55 (internal communication problem)
  • On the HP 2 series you have to replace both the dc controller and formatter boards. On all other printers it can be several things: DC controller, formatter, main motor
Jan 18, 2009 | HP LaserJet IIIp Printer
Sensor error, turn off then on
Check the level of your toner or TOP errors. If the problem persists, let me know
Nov 12, 2008 | HP Color LaserJet 2600n Printer
2,089 people viewed this question
jasbo
jasbo
