Question about Intel DG31PR Motherboard
Over heat My Intel DG31PR main board BIOS indicates that tThe MB tempreture is 74C. What wrong with it? But its working well... Pls Help
  • 2 more comments
  • Rajitha Kumarage
    Rajitha Kumarage Jul 17, 2008
    Room Temp is around 25C here. There is a proper heat sink for prcessor. Processor temp is indicating around 45C. I tried to monitor the temp. as soon as the PC turn on in this morning. It started from 6C and went up to 67 in 5 minuts. Is there a problem.?
  • loharlaxya84 Jul 28, 2008
    I want to buy a pc so that i want to know DG31PR motherboard is good or not or which board i have to buy for my pc. can any one let me know please.??
  • Naumanafridi Aug 25, 2008
    I have INTEL DG31PR with 3.0ghz Processor on it. But when i turn it on in 3 minutes it near to 68. i dont no its normal or not, my room temprature is 18 c Please tell me the solution to control my motherboard temprature, One fan in my atx casing and other cpu fan have you any idea?
    Nauman afridi
    Problem Solver:
  • 5 Answers
According to DG31PR Technical Specificaton document (page 29):The minimum thermal reporting threshold for this motheboard is 66 °C. Thermal sensor will report 66 °C until the temperature rises above this point.
Posted on May 03, 2009
  • 1,031 Answers
Whats the room temperature ?the room temperature may effect the systems temperature,again the processor usage,or the particular heat sink attached to the processor if it dosnt dissipate much heat and instead circulate within can cause high temp so check that out
Posted on Jul 16, 2008
SIR I M BAYING YOUR COMPANY MOMHER BOARD DG31 DT-11.01.10 I NO FOUND VGA DRIVER SO PLS HELP ME
go here my friend
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+3+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DG31PR
and download this
Video: Intel® Graphics Media Accelerator Driver for 3 Series Chipset Based Intel Desktop Boards
Jan 11, 2010 | Intel DG31PR Motherboard
Help me
http://downloadcenter.intel.com/Default.aspx?lang=eng
chose: motherboards --> Intel 3 series chipset boards --> DG31PR
then pick your operating system and category 'Drivers' and you'll get listed all you need for your MB.
Dec 01, 2009 | Intel DG31PR Motherboard
Dude i too have same prob :(
check in your bios configuration if the on-board sound card is enabled,if not enable it.your board is equipped with built in realtek sound card, if your driver don't work try here http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2839&OSFullName=All+Operating+Systems&lang=eng&strOSs=All&submit=Go%21
hope this helps, pls do let me know
Aug 13, 2009 | Intel DG31PR Motherboard
Intel DG31PR Mother board BIOS menu
le quitas la bateria(pila) antes de encender, la enciendes y espera unos minutos. Luego colocas la bateria y actualizas la hora en el setup
entonces reinicia y problema resuelto
Jun 10, 2009 | Intel DG31PR Motherboard
Mac os x is not run imy pc
to install mac os is simple in dg31pr motherboard but if it does not support to u mean. u have to change in bios some setting it is change hardisk mode from ide to AHCI
Apr 14, 2009 | Intel DG31PR Motherboard
Current system is not an Intel(R) Desktop Board. -(A044412A)
Does'nt your MB CD have the drivers. Otherwise ask the supplier to provide you one....sodeep
Mar 18, 2009 | Intel DG31PR Motherboard
Ur board is not original intel board{board is intel dg31pr}
pls download drivers from here and everything will be ok
http://downloadcenter.intel.com/Filter_Results.aspx?strOSs=All&strTypes=All&ProductID=2839&lang=eng&OSFullName=All%20Operating%20Systems
pls rate me FIXYA for this if ur problem is solved
Feb 21, 2009 | Intel DG31PR Motherboard
Intel DG31PR not supporting 2 dimm each of 1gb
Memory for Intel motherboards require the memory to be compatible with, Serial Presence Detect (SPD). Its suggested when upgrading memory for Intel boards or increasing memory to do you're search for the total memory you wish & include the Intel mother board model. Example: http://www.google.com/search?hl=en&q=Memory+for+Intel+DG31PR&btnG=Google+Search
This first link shows what brands works with the DG31PR MB.
Intel Tested Memory for DG31PR MB link:
http://www.intel.com/support/motherboards/desktop/dg31pr/sb/cs-027918.htm
You're Intel board is well within the Intel warranty. If you find this information not helpful please call Intel tech support. It is possible you're board needs higher attention. Please check & install the latest bios. Intel's link for bios, manual & drivers link:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2839&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
If you are not using WinXP click this link & pick you're current operating system.
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839&lang=eng
Mike
Aug 08, 2008 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Logo
233 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
