Question about Hitachi 57F500 57" Rear Projection HDTV-Ready Television
Red arched ghost
Thats not a valid Hitachi model number the sp4400 are audio speakers, but hitachi doesnt have model numbers for tV with sp can you please respond to this post with your model number and I will help you. SP43H is more like a Samsung model number.
You're right. My wife gave me the model # for the base it sits on. The Hitachi TV model number is 43FDX01B the screen is 35x26. Is there a place I can buy the correct IC online? Will they provide instructions? Again the issue is a red shadow and a red arc at the bottom of the TV.
  • gfridenstine Sep 11, 2008
    Well I believe I have the same problem. Mine has a red shadowing effect and when there are words on the screen you can see the red shadowed below while the blue and green are fine?
  • ssexton Sep 24, 2008
    i have the same problem with the 43fdx01b. what are the exact components i need and where do i get a manual
  • 10,594 Answers
But be careful as TV has high voltage inside.
Posted on Jul 16, 2008
  • Hitachi Master
  • 8,617 Answers
Yes you will need two Convergence ICs they are both STK392-110 and you will also need the 6 feed resistors that feed them which are (2) 2.2 ohm 1watt resistors, (2) 1.5 ohm 1watt resistors and (1) 3.3 ohm 1watt resistor and also (1) 1.8 ohm 1watt resistor. You can get the replacement ICs and resistors at the following link and they will provide free instalation instructions with pictures so you can do the repair yourself, they also have free online tech support incase you need additional help. Heres the link.
http://servicemanuals.vstore.ca/
1998 hitachi projection tv
The red light should be on solid---when set is turned on with back off you should see a number of green lights also----what is the model number?
Apr 30, 2012 | Mitsubishi Televison & Video
Has ghosting red and blue.
hello my name is rico i work on tvs sometimes, your problem with tv is bad convergance, that mean ics in your tv blew out, thats why your colors wont aling. if you need more help fixing your tv let know feel free to call me at anytime, i live i mesa az my phone number is 602-810-7149
Dec 29, 2010 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi model CMT-2928 Serian Number GIK 000287 after turn on the television around 5 second screen become flicker like have thunder.please help for this issue to solve thank
do you smell something at the back of your tv. if yes and still hearing the continues cricking sound its your flyback transformer it has a leak a high voltage current is arching try to replace the flyback transformer.
Oct 15, 2010 | Hitachi CMT-2195 21" TV
Bright blue concave archs accross top of the screen with some yellowish ghosts on any lettering accross bottom of screen. This is a hitachi model 53fdx01b rear projection tv that normally has an excellant...
Sounds like a convergence failure, here is a tutorial I made:
http://www.fixya.com/support/r5001731-convergence_diagnosing_convergence
Let me know if I can be of further assistance.
Sep 09, 2010 | Hitachi 53FDX01B 53" Rear Projection...
Red green and blue arched horizontal lines on the tv
Hi, you`ve got a bad convergence circuit, involves un-soldering either 2 or 3 large IC`s (you didn`t post a model number) possibly 2-3 burnt resistors and possibly a chemical fuse. A lot of times it`s just the 2 or 3 IC`s, definitely worth fixing (I personally own a 53" Hitachi) If you try this yourself be sure you get original IC`s for the set, theres a lot of bogus chinese IC`s on the internet, acme-sales.net in Orlando Fl. is where I get mine, gl, video-tek
Jul 03, 2009 | Hitachi Televison & Video
Hitachi 61udx10b
Replace Both of your STK ICs they are your convergence ics they are big black ICs will have Part# on them for example STK392-110, if they are 110s use 180s, if 020s use 040s other wise replace with exact same number. To get Parts call Electronix 1-800-223-3205
Dec 30, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Red arched ghost
Jul 15, 2008 | Hitachi 57F500 57" Rear Projection...
60ux58b hitachi
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Apr 29, 2008 | Hitachi 60UX58B 60" Rear Projection...
Hitachi 57F500 57" Rear Projection HDTV-Ready Television Logo
93 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
