Question about Amana Dishwashers
Tub water dirty
After finishing cycle remaining water in washer is dirty
Removed 2 separate filters that were heavily clogged and cleaned them.
Posted on Jul 17, 2008
Does this machine have a lint filter? I am getting bits of yuk on my washing after the wash is finished
No lint filter. The tumbling wash action generates very little lint, which washes down the drain.
To get rid of the "yuk":
Open the access panel on the lower left corner on front of the washer.
Use small hose to drain the remaining water from machine.
Remove the pump filter next to the hose, clean it out, and replace it.
Run the washer with a commercial washer cleaner such as Affresh, washer magic, or whirlaway hot tub cleaner, no clothes, hottest longest cycle possible. Use the tub clean cycle if your model has it.
Resume washing, using one tablespoon of HE detergent per cycle. Use only 1 teaspoon of fabric softener if you use that. These machines use much less water than the old top loader ones, and thus you must use much less detergent.
Feb 24, 2011 | LG Washing Machines
Washer has water remaining in the tub after it finishes, happens intermitantly. Some times, after washer is off, you can hear water trickling & when you open the door, water is trickling down from the...
Sounds like you may have a bad water valve. Go to http://www.partselect.com/MultiModels.aspx?ModelNum=mah6500&searchTerm=img_54050&RefineSearch=0&imgMfg=Maytag&Page=2 and the water valve will be #14. You can check to see if this is the problem by running a load. After the machine is finnished adding water in the rince cycle, turn the water off to the machine. Let it finnish spinning. Then look to see if the water is still coming in. When a water valve goes bad it can act funny in many differant ways. Your sonds like it may have trash in it that allows it to leak water some of the time. Good luck
Dec 15, 2009 | Maytag Neptune MAH6500A Front Load Washer
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
Dec 03, 2009 | Kenmore Washing Machines
Water remains in tub after spin cycle
Have you tried to clean the drain hose on the back of the washer? It may have build up inside that you are loosening up by using bleach.
Sep 06, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Water remains standing in the tub
take off the filter and there is a screw under the filter remove that screw to see if there is anything in there.that might be a blockage causeing not all the water to drain.
Dec 30, 2008 | Bosch 23 in. SHU3307UC Built-in Dishwasher
Hi, i have front load washer AMW5080,near to the end of its cycle it doesnt take the softner it remains full when the cycle is finished. i cleaned the filter at the bottom. Thankyou Christine
hi christine,
you could have a problem with the solenoid that dispense the softener. it wont open up to let water flow to that cavity in order to go out to the tub.
tnx 4 using fixya,
drcool
Nov 05, 2008 | Whirlpool Washing Machines
Dishwashers Logo
324 people viewed this question
Top Amana Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
