Question about NetGear WGT624 Wireless Router
My router is not working - NetGear WGT624 Wireless Router
  • 3 Answers
More info please? Which lights are on on the router? What kind of Internet service do you have? Can you connect to Internet when you bypass the router and plug the Ethernet directly into your computer?
Posted on Jul 19, 2008
Router stopped working, isp had me bypass router and net worked
If your computer is able to go online through the
modem, that means the modem is working fine.
You will need to connect the computer to the
router and the modem to the router.
open the set up page of the router and change the
settings of the router according to the ISP.
Click Here for more information about the routers
and network
Feb 27, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My router was working fine until I upgraded from Vista to Windows 7 and then tried 192.168.1.1 to check my router settings and I went to a google search page and not the router configuration so i used the...
HI Friend
please follow the steps
1. Turn on the router and connect the desktop to router
2. push and press the reset button,which is at the back of router, for 30 seconds and after that turn off the router for 30 seconds and turn it on after 30 seconds.
3. Now open 192.168.1.1 and check your router settings.
4. If the internet does not works then in the router setup page click basic settings, click MAC address clone
5. Select the enable button and click the Clone tab. Click save settings and turn off the router for 30 seconds.
Enjoy
Regards
Chiranjeet
Dec 27, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
How do I access my Belkin Router F5D7234 so I can find my WEP Key
Router set up.
Router is not working.
NO CD.
How to set up router.
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 12, 2009 | Belkin F5D7234-4 Router
Router settings
Router set up.
NO CD.
It is very easy.
Dec 11, 2009 | D-Link DIR-615 Wireless Router
Bought this Belkin wireless router on 09/01/08 from PC World for £59.99. It stopped working completely on 21/11/09-with no warning. I have now bought a new one. Is this the normal life span for a...
there is no specific life span for the router. As long as the settings on the router are working then the router will work.
If the settings are not correct then the router will not work.
Your old router might be still working. You just need to check the settings of the router.
I believe you can set up the router properly.
It is very easy.
Click Here for more info about router set up.
Nov 23, 2009 | Belkin (F5D7231-4) Wireless Router
Our internet from our ISP works perfectly fine, but when i try to directly connect the ethernet cord directly from the back of my cpu to the router the internetll not work. What can I do to fix this? this...
Who is your Internet service provider ? If you connect the computer to the modem it works . that means the modem is working but the router is not. You will need to check the settings of the router and set up the router again. Before that press the reset button on the router for 30 seconds. unplug the power to the router and plug it back In. Then open the router set up to check the settings. WRT160N is one of the good router Click Here for step by step solutions
Nov 17, 2009 | Linksys WRT160N Wireless Router
No internet signal from router
To isolate the concern, it would be better to test the non working computer to the modem. If it works, that means there is a problem with the router and if it isn't then it is a problem with the pc..
If the computer works fine on the modem, you can try the following to check if the router works fine:
1. The modem should be connected to the router's WAN/Internet port.
2. The computers should be hard wired to the router's numbered port
3. On the router's setup page, go to the Status tab and check if the Internet IP address and the DNS are populated. If not, that means the router is not functioning correctly.
4. Go to the wireless tab and make sure that the SSID is customized. Make sure that the wireless computer is connecting to the said SSID.
If those had been checked and it still does not work, you can try updating the firmware of the router, reset and reconfigure it.
However, if the computer does not work on the modem. You may need to have it checked.
Sep 05, 2008 | Linksys WRT300N Wireless Router
Router burnt out
If you reset both the computer and the router at exactly the same time it should work but if it doesn't you most likely need a new router. Hope this helped =)
Feb 26, 2008 | Linksys Wireless-G WRT54GS Router...
NetGear WGT624 Wireless Router Logo
59 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Brian Sullivan
Brian Sullivan
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
