Question about Intel DG31PR Motherboard
Main board tempreture is indicating very high
My DG31PR MB bios indicating the main board tempreture is 74C. What is the normal tempreture? What should I do?
  • 1 more comment
  • Rajitha Kumarage
    Rajitha Kumarage Jul 18, 2008
    Is there any relationship between Processor cooler and Main board tempreture. I cant even touch the south bridge chip. It is very hot.!
  • Anonymous Dec 24, 2008
    I put heatsink on SBridge and temp came down to 64c. After starting pc it rises from 54 to 65c amnd stays there. What to do now?
  • koushik chattopadhyay Dec 28, 2008
    i have also the same problem my motherboard temperature is very hot and it shows 74 c in bios what should i do?
  • 22 Answers
Fiend your solution direct from intel. Here is your solution....
http://www.intel.com/motherboard/prob676ijt65/solution
137
Posted on Mar 13, 2009
Update to the latest bios.. change the cmos battery.. update to the latest drivers..
Posted on Dec 29, 2008
  • 1,031 Answers
It depends on the room temperature which is 25C,or the processor work load,the heat sink attached .the temperature should be alittle bit above 50C OR BELOW
Posted on Jul 16, 2008
I put a hit sink on the south bridge and put a small fan above it and the temperature is 44 c
Posted on Jan 12, 2009
I have LG 42LN5300 which is reading 230VDC at led + plug and no back lights. All other voltages going to main board are OK, I changed main board because of flickering on and off screen, so is it MB
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jan 20, 2017 | LG Televison & Video
I wanna know that is XFX 9800gt supported on intel DG31PR motherboard or any PCI express motherboard ? I also wanna know that is it a good combination of 9800gt DDR3 1gb and DDR2 RAM 2gb?? Please reply me...
nVidea 9800gt is a good card... probably not a question of if the MB will support it as much as if your power supply will. It needs a secondary 6 pin power connection.
Any MB with 16x PCI slow will run the board. The different RAM types on the MB and Video card will nto matter as much as the throughput of the PCI bus...
2GB ram on you main board, hope you are not running anything serious.... I do a fair amount of video with a 9500GT. Quad Core 2.66, 6 GB ram and am looking to upgrade to an I7 with 12GB and a nVidia 250 or better....
Mar 07, 2010 | Pine Technology XFX XFX GeForce 9800 GT...
No display
If RAM's are ok then the voltage surge has fried VGA Chip & its not worth repairing. If under warranty, try your luck, otherwise replace the MB after ensuring that your processor is OK.....sodeep
Mar 19, 2009 | ASUS Computers & Internet
Gas gas 450 fse 2005 lcd spedo turning off when cold outside
I have encountered this on more than one occasion. My experience has been a solder joint on the internal circuit board that is non conducive to cold weather. It has something to do with shrinkage on the board. Although I have only been able to track the exact problem one time, (a small crack in the panel board), all other times I have had to replace the actual unit.
Dec 15, 2008 | 2006 Gas Gas EC 450 FSE
Part # for aspire 5043 motherboard
There are a few motherboard this series:
MB.AA101.001RF - Refurbished Main Board AB2 V128 w/MDM&Cable
MB.AA101.002RF - Refurbished Main Board AB2 V64 w/MDM&Cable
MB.ADX01.001RF - Refurbished Main Board AB2.UMA w/MDM/Cable/RTC
MB.ADX01.001 - Main Board Ab2 UMA w/Mdm/Cable/Rtc - Repair Flow Only (repair flow. send failty motherboard in advance)
MB.AA101.001 - Main Board Ab2 V128 w/Mdm&Cable LF - Repair Flow Only (repair flow. send failty motherboard in advance)
MB.AA101.002 - Main Board Ab2 V64 w/Mdm&Cable LF - Repair Flow Only (repair flow. send failty motherboard in advance)
www.acerparts.com
other guy asked for aspire 5100 motherboard, look here
http://www.zandparts.com/acer/index.php?cPath=40886_40887_40929_41356
Nov 22, 2008 | Acer Aspire 5100 Notebook
New graphics card needed
If your looking for a fast graphics card u will be limited to mostly 256 mb nvidia chipsets.
lots to choose from. go to www.tigerdirect.com
Oct 05, 2008 | Graphics BV200 BizView 128MB (128 MB) PCI...
CPU incompatibil
Do you get to the boot screen if so press the key to enter BIOS and set BIOS to default then from there set up to suit CPU and memory
Also check the M/board battery is OK
Sep 22, 2008 | Intel D845GVSR Motherboard
Motherboard won't boot
u can go to ur mb bios nd check ur processor setting.may be 845gvsr not support intel crl processor.u can give load bios default from ur bios press F6 or F7,
Sep 19, 2008 | Intel D845GVSR Motherboard
Intel DG31PR not supporting 2 dimm each of 1gb
Memory for Intel motherboards require the memory to be compatible with, Serial Presence Detect (SPD). Its suggested when upgrading memory for Intel boards or increasing memory to do you're search for the total memory you wish & include the Intel mother board model. Example: http://www.google.com/search?hl=en&q=Memory+for+Intel+DG31PR&btnG=Google+Search
This first link shows what brands works with the DG31PR MB.
Intel Tested Memory for DG31PR MB link:
http://www.intel.com/support/motherboards/desktop/dg31pr/sb/cs-027918.htm
You're Intel board is well within the Intel warranty. If you find this information not helpful please call Intel tech support. It is possible you're board needs higher attention. Please check & install the latest bios. Intel's link for bios, manual & drivers link:
http://downloadcenter.intel.com/filter_results.aspx?strTypes=all&ProductID=2839&OSFullName=Windows*+XP+Professional&lang=eng&strOSs=44&submit=Go%21
If you are not using WinXP click this link & pick you're current operating system.
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2839&lang=eng
Mike
Aug 08, 2008 | Intel DG31PR Motherboard
Over heat
whats the room temperature ?the room temperature may effect the systems temperature,again the processor usage,or the particular heat sink attached to the processor if it dosnt dissipate much heat and instead circulate within can cause high temp so check that out
Jul 16, 2008 | Intel DG31PR Motherboard
Intel DG31PR Motherboard Logo
186 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
