Question about Intel D845GLLY Motherboard
Problem upgrading RAM to Intel D845GLLY
HI,
I get a beep sound and nothing happens when i added new RAM SDRAM 512 Mb.
Pls help
  • surajloves Jul 16, 2008
    Thank you,
    i checked may web sites and asked other professionals and was told should be compatible
    Currrent which i bought has below labelling
    PC 1300U - 133MHz
    HY57V568HCT-H
    512 MB SD RAM
    Your given site tell me "Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts " AND "Serial Presence Detect (SPD) DIMMs only"
    IS my current RAM fulfills above statment.
    Thank you in advance
  • 87 Answers
Please check ur new memory
memory is working change memory slot
Posted on Jul 16, 2008
  • 1,031 Answers
The Intel Intel Motherboards D845GLLY uses PC-133 type memory and supports up to 2GB of RAM,the memory may not be compatable with your motherboard so check the memory type and make sure you place it starting from slot 0 on your motherboard. i hope this solves your problem
    Scholar:
  • 101 Answers
Most likely the memory is incompatible or in the wrong configuration. Check here to see the proper configuration for this motherboard.
I have Intel Desktop D845GLLY motherboard, recently it has no display and when power is on it gives three beep. I have a intel board that was running find until i upgraded memory and changed the dvd...
The three beeps tells you that something inside the system is not properly installed. Check all hardware installations and position properly all hardware not properly installed. If nothing is improperly installed, try cleaning the RAM with a piece of clean cloth and install properly.
Feb 20, 2011 | Intel Computers & Internet
Helo, i want to upgrade memory on my ASUS CUBX-L motherboard. Manual says it recive max 4 x 256 MB of SDRAM. Is it possible to put 512 MB or bigger RAM modules?
yes you can put 512 mb of ram even 2 of it because the capacity of your board is up to 1024 mb of ram but make sure that it is an sdram and it has the same specification on whar is your manual indicate besides on the ram size.
Oct 14, 2010 | ASUS Intel 440BX Chipset CUBX-L...
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Intel 82845G/GL motherboard running on 256+128 (384) RAM. I want to upgrade RAM to 1 GB (2*512) but it is unable todetect and give 3 beep sound.
One or both of the new RAM modules is incompatible, defective or not inserted properly. Try one at a time also verify your board supports 1GB and the type of RAM you are using.
Feb 17, 2009 | Intel D845GLLY Motherboard
Regarding upgradation of SDRAM
hi dear
there is always speed mismatch problem occur when we use low processor & high ram
so try to use 256 ram
also try to use 1 slot of 256 ram & 2 slots of 128 ram diffrently
& compare the speed
hope it will help to u
Jul 08, 2008 | ASUS SiS Chipset CUSI-FX Motherboard
RAM Installation.
your new ram fsb speed not support your mobo
845glly mobo support 266 fsb 133 mhz sdram
Feb 29, 2008 | Intel D845GLLY Motherboard
Intel D845GLLY Motherboard Logo
151 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
