Question about Yamaha HTR-5830 Receiver
Power problem every times i power up the receiver , it is not stay on
  • 151 Answers
Make sure that your speaker cables are not touching each other or the case of the amp,also check cables at the speakers as this will cause the amp to switch off.
hope this helps.
CABLE GUY.
Posted on Jul 16, 2008
My harman kardon avr 120 powers off by itself in about 2-3 seconds, i press the power button again and goes off again in the same amount of time, what can i do about it?
What we are doing, in this case is looking for a shorted out speaker system, or wiring to speakers, or cables or components that are connected to the receiver that have a short circuit. This is what I would do if I were called to your house to debug your sound system.
Follow this procedure and see what happens:
Disconnect one set of speakers at the back of the receiver and turn the power button on again. See if it stays on.
If not, remove the next speaker and keep repeating the test.
If it still stays off, disconnect all of the equipment connected to the unit, one piece at at time.
Somewhere along the line, the receiver may not shut down. If that is the case
identify the the offending cable(or component)and replace or service it.
I hope this solves it for you. If not your receiver will need professional servicing,
Best Regards,
Mark
Jan 20, 2011 | Harman Kardon AVR 120 Receiver
Marantx SR4600 Receiver
Some indication of power supply issue. if it is 6 months old. It should be still under warranty. Should it not?
Sep 07, 2007 | Marantz SR4600
On/standby Red light blinking can't turn on system
It's in protection. Disconnect all your speaker wires at the receiver then power it up. If it stays on, the receiver is ok and you need to check all wires and speakers for shorts. The easiest way is to reconnect one speaker at a time and test power until it shuts down, then disconnect the speaker wire at the speaker and test again. If it stays on, meter the speaker for shorts or bad voice coil. if it still shuts off, check your wire or replace. If the receiver's power still flashes with all speakers disconnected, it needs service or replaced. Before reconnecting your receiver after repair or replacement, check all wires and speakers 90% of the time, that's the cause. Hope this helps. If you still need help, post a comment and I can help you troubleshoot further.
Oct 17, 2009 | Denon AVR-2807 Receiver
I have receiver VSX-D509S. Have had it for
Check for a bad ground on the input circuit board. you will need to re-solder them. Remove top cover and rear panel (many screws on rear panel) The input board can easily be accessed and resoldered. you should also check for a bad ground on the speaker jacks. If it is not repaired, sooner or later you will probably need an output IC. good luck.
Oct 16, 2009 | Pioneer VSX-D509S Receiver
Yamaha HTR-6130 Receiver will not stay on! Shuts
One last try with everything disconnected!
Other than that I suspect internal surge damage.
Aug 04, 2009 | Yamaha HTR-6130 Receiver
Lightning Last Night Nocked The Receiver Out.
leave unpluged overnight. usually capacitors hold charge and will release slowly. try that if doesnt work powersupply is bad.
Jun 03, 2009 | Yamaha RX-V861 Receiver
AV-S17 - Clock Display won't stay on?
Check the internal memory battery if there is one, then reset the sleep setting? Check the manual regarding memory back up.
Sonic Doctor
Mar 27, 2009 | Aiwa AV-S17 Receiver
Power won't stay on for Pioneer Receiver Model VSX 3900S
not a permanent solution but this is how i got it working... keep pressing the power button different ways (ie. hard, soft, etc) and when you do get it, dont touch it for a decent period of time, like 15 minutes. Then turn it off and on, it should turn on this time wo a problem and if it does then it souldnt be frozen anymore. Otherwise, if i didnt wait 15 minutes, it would be frozen and if a certain button was pressed or the receiver is moved, it will just shut off. ANother piece of advice, once you get it working, leave it on!
Aug 08, 2008 | Audio Players & Recorders
Won't stay powered on
There is a relay right next to the fuses on the inside dg1u it says on the top. I cleaned it and pressed down firmly on it and it seem to have fixed it. It fired up for the first time.. The relay might need to be replaced if this doesnt work for ya.
I found a solution at: http://www.diyforums.net/forums/domestic-electronics/11098-yamaha-rxv795-receiver-shuts-itself-down-after-some-time.html
Dec 23, 2007 | Yamaha RX-V795 Receiver
Yamaha RX-V596 Receive turns off after pressing Power
Sometimes the receivers turn off if the speakers are shorted in order to protect the AMP circuit. So try this - 1. Disconnect all cables (speakers), inputs from Tape Deck, VCR and other input devices), sub-woofers, rear speakers all. Except the AC power cord. Then turn it ON and see if it stays on. If it still has the same problem, then most probably your power circuit inside the receiver has a problem - like a shorted Capacitor or diode etc. Based on how technical you can be and what resources and time you want to spend, this is repairable. But based on the price of a receivers these days, it is not worth. Good Luck!
Aug 30, 2007 | Yamaha RX-V596 Receiver
Yamaha HTR-5830 Receiver Logo
53 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
