Question about Philips GoGear SA178 MP3 Player
Mp3 not recognized
My computer does not recognize my Philips GoGear SA13335 MP3 as an MP3 player, or a removable device, and i've tried almost everything
a note at the bottom keeps popping up saying
Found New Hardware
MTP Device,
but it does not do anything
and when i go to my computer,
it does not show a removable device,
any help?
  • 8,596 Answers
Unplug mp3 player from computer. Go to Control Panel --> System --> Device Manager --> Uninstall MTP Device. Uninstall all Philips software. Reinstall Philips software from the CD or the Philips website. Replug mp3 player into computer. Good luck!
-Tha Mp3 Doctor
Posted on Jan 03, 2009
My gogear does not recognize by my computer what should i do
What should I do if my player is not recognized by my PC?
Reset it. Use a pen tip in the RESET hole on the side of the player.
Connect the player to the PC to see whether the player is recognized.
Faulty USB port, try connecting the player to another USB port (or try another computer).
Is your computer Mac or Windows? eg Mac OS 10.7.2 had issues recognising media players that could be fixed by resetting PRAM.
Install Philips Songbird software and try Repair mode. Note this will delete files on the player.
Philips GoGEAR MP3 player SA2RGA04KS RaGa 4GB with FullSound
Sep 19, 2012 | Philips Gogear SA2RGA04KS Mp3 Video Player
My philips go gear mp3 player 8gb SA52XX is frozen (stuck at the part where it says go gear) nd due to that my pc ownt recognize it and nd obviously i cant listen ot music, iv tried everythiing frm...
Hi Ayesha. Resetting the device should be able to fix minor problem with the unit. Since resetting the device had no effect, the problem you might encountering there is more of firmware problem. Try to reinstall/upgrade the firmware of your device. Philips has software that is called SONGBIRD. I think you have that one in the cd when you purchased the program You may download the progra,m by clicking here. Below is the procedure on how to perform the uprgade:
Download and install the Phillips Songbird program. Launch the Phillips Songbird software.
Connect the Phillips GoGear MP3 player to your computer using the supplied USB cable. Click the icon of your GoGear MP3 player on the left side of the Songbird interface.
Click the "Tools" tab. Click the "Check for updated firmware" button. If a new update is available for your device, it will be downloaded and applied. Do not disconnect the GoGear MP3 player until the Songbird program tells you that the installation is complete.
Hope this helps..
Jul 18, 2011 | Philips GoGear HDD1830 MP3 Player
My philips gogear 4gb mp3 player is nt startin what 2 do??
I'd suggest that you format your player or repair it using Philips songbird or device manager. Contents may be removed by using this function. So make sure to back up your contents.
Format:
On your computer desktop, double-click "My computer". Double-click on the MP3 player's icon. Right-click on the Internal Storage icon and then select "Format".
Repair using Device manager:
Launch Device Manager and click the Tool menu and select "Repair", then follow the instructions to perform the repair process. Make sure all other applications such as Philips Plug-in, Windows Media Player or Windows Explorer that access the device are closed or else Device Manager will not recognize the device.
Hope this works.
Mar 16, 2011 | Philips GOGEAR SA6045 MP3 Player
My computer is not recognizing the philips Go Gear MP3 Player.
Hi go to the philips web site, download required software
Apr 17, 2010 | Philips GoGear HDD075/17 MP3 Player
When i turn on the philips gogear it says philips,gogear,updating and then it jams
This player has an issue that the latest firmware fixes, re: constant freezing during updating. If you can just get the computer to recognize the player, and load the firmware update then you should be fine. The firmware update should load when you go to the "Update" button on the latest Device Manager (the version of the Device Manager from Philips' website, not from the install CD).
If the computer is not recognizing the player, then try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Jun 09, 2008 | Philips GOGEAR SA6045 MP3 Player
Player frozen..
You need to do two things - the first tactic will force the computer to recognize the GoGear - the second will fix the device:
Disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
After this is done, open the Philips Device Manager that came with the install CD, and run a "Repair" - the instructions will be remarkably similar to what we did before.
The do a "update" in the Philips Device Manager to be on the safe side.
-Tha Mp3 Doctor
Jun 05, 2008 | Philips GoGear HDD1830 MP3 Player
Not recognized by PC
First off.. Make sure your software and drivers are up to date...
Second, try re-installing Windows Media Player or if you have WMP 10 installed, try upgrading to WMP 11.
Also, if you plug in something else to your USB port, does the PC recognize it? Or, if you try your GoGear on another computer, does it work ok?
Apr 06, 2008 | Philips GoGear HDD6330 MP3 Player
Recognizing as MP3 player or removable device
Try reinstalling the software that came with the unit. Go into device manager & see if the unit shows there, & make sure there are no conflicts. Your owner's manual may also have a tech help number to call.
Feb 16, 2007 | Philips GoGear SA178 MP3 Player
Philips GoGear SA178 MP3 Player Logo
540 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
