Question about Kitchen Ranges
Admiral gas range 68-2543-80.oven doesnt light.dont know where to light pilot
I have the same range. It does not have a pilot. It uses an electronic ignitor which generates an electrical spark that lights the burner. The ignitor is located at the back of the burner and should make a popping noise and the spark will be visible to the eye. If none of your burners are working have a professional take a look. This is a potentially explosive device and the gas line should not be tampered with unless you are experienced.
Ex-Sears Tech
Posted on Apr 07, 2009
Electric oven without pilot light. how to wire a pilot light electric oven
first off ,,,electric ovens dont have pilot lights ,,,its electric..the burner is electric....now ,,on a gas oven thats different..first remover the old one,,,then replace with new following reverse directions from removing the old one ....
Mar 10, 2014 | KitchenAid Kitchen Ranges
How do I light a pilot in a gas oven
On a pilot type system you typical hold an ignition source (lighter) to the pilot while holding down the thermostat (push the oven temp knob in) and hold for approx 20 seconds make sure you have the lighter directly on the pilot assemble in oven while you are doing this once it's lite continue to hold for the 20 seconds if you are not sure you are doing it right or if you smell gas vent your house and seek a knowledgable tech
Dec 24, 2011 | Kitchen Ranges
How do i adjust oven pilot light on vulcan range
hi, there is an orfice for the oven located on the gas valve. If you are using LP gas, the orfice should be turn down all the way (counter clockwise). If you are using natural gas, the orfice should be turned out about 2-1/2 turns. Was this oven set up to be used with one gas and noe is being used with another? If so, you will need to do more then adjust orfices. Please let me know if I can assist you further.
Thaks
Vic
May 13, 2009 | Kitchen Ranges
Hi, we have a dcs 366 gas range. the pilot light for the oven went out and we can't seem to locate the pilot to re-light. the manual doesn't really go into detail for the oven...only the stove top. is this...
You don't give the model number of your DCS range, but it probably doesn't have a pilot light.
More likely it uses and electronic igniter. Internet search on "gas oven ignitor". I think this
might help you with your problem.
Mar 15, 2009 | DCS Kitchen Ranges
Pilot Light - Frigidaire Model FGF326ASF
Hello jaronwayne
Welcome,
That range does have sealed burners.
Are you sure it has a pilot light and not Electronic ignition?
Where I live , if we call public service they will come out for free and light it for you!
I'm checking that model and I'll get back to you!
Huuum
Oct 16, 2008 | Frigidaire FGB24S5A Gas Single Oven
Tappan Stove 5 burner with Oven
does the pilot seem low?you can remove the pilot then clean it out,let me know.
Nov 10, 2007 | Tappan TGF320 Gas Kitchen Range
OVEN NOT WORKING
is this a gas stove if so and the bake burner doesnt light then you need a new ignitor and remember just because it glows doesnt mean its ok it has to draw 3 amps to open the gas valve let me know how you make out please
Sep 13, 2007 | Ovens
GE GAS RANGE OVEN PROBLEM
two options.first does the pilot flame look good (a nice blue flame)?if so you will see a metal probe next to the pilot,use some sandpaper and clean that probe up.if that solves your problem so be it.second if the first thing doesnt work its probably the ignitor board not sensing the flame.the way to definitly tell the one or the other use a small torch and heat up the probe like i said and turn the oven on.if the main burner comes on then you know its the probe which is called a thermocouple and is cheap.hope this helps.
Aug 08, 2007 | GE JGBC20 Gas Kitchen Range
Kitchen Ranges Logo
354 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
