Question about Sony KSP-30 U Matic Tape (10-Pack)
U-matic tape mechanism doesn't wind/rewind/play
Old u-matic videotapes fail to fast-forward, rewind or play. Some tapes wind very slowly and then stop the machine, and I have to eject to get it started again.
However, some tapes work just fine, so it isn't the tape deck. How do I loosent the mechanism to get it to move more freely?
IFYI, the video is still good on these 25 year-old tapes. I only need them to work once to copy them to current digital format.
@guest: You posted "I didn't understand a word you said!!!!" Now, why the **** do you post this personal incompetence declaration as a solution? I'm looking for solutions, not for idiot comments.
Posted on Jun 05, 2009
Posted on Jul 16, 2008
Stop Paying .. ????
if the take up side gets stuck it could feed excess tape and stop the mechanism. Look to see if both reels are turning when you push play. Remove cassette door for a better view if possible.
Make sure your tapes have NO slack in them. Fast forward and rewind one cassette all the way, then try again looking to see if both sides are turning. If not, you may have a belt that is old, stretched and slipping or it's split apart or just fallen off
Sep 11, 2015 | Yamaha Audio Players & Recorders
Panasonic RR-930 does not backspace with or without pedal. It engages the mechanism but appears stuck when tape is inserted. Runs fine without tape in deck.
The ancient tape is junk. Buy a new one. You might also try slamming the old tape against a wall or desk to loosen up the tape layers. Then FF and RW all the way.
Apr 20, 2015 | Panasonic RR-930 Desktop Cassette...
My tape plays but it rewinds and fast forwards extremely slowly or sometimes not at all. Could it be a drive belt problem if it plays tapes?
tapes themselves sometimes get tight. also...a weak belt could cause this. I have sometimes taken tapes apart and rewound them by hand, but tapping the tape fast and gently can loosen them but you'll have to open the tape protective cover or the reels wont turn
Nov 09, 2011 | Televison & Video
Video tapes only paly for about 2 seconds then stops
The heads need cleaning and/or the tapes are old and dirtying up the playing heads.
Run a wet tape head cleaner through an see if this improves.
May 23, 2009 | Televison & Video
Erasing recorded tapes
While holding the 'Erase' button down, press the 'Rewind' or "Fast Forward' button. It will erase the tape while it rewinds or fast forwards.
Apr 20, 2009 | Philips Desktop 720-T Desktop Cassette...
GE VG4056 will not rewind
The photo sensor that senses the tape end has blown or dry soldered.It is on the right side of the mechanical deck and senses the transparent end of the tape through the square hole in the video cassette.
Apr 27, 2008 | GE VG4056 VHS VCR
Mitsubishi vcr HS-U770
More likley it's not the little white thingy but the belt that drives it. Take the bottom off and get that broken belt out and runn down to the VCR / Tv repair shop and see if they have a new belt
Mar 07, 2008 | Mitsubishi HS-U770 S-VHS VCR
VHS tape won't play or rewind
I work at the History Channel and have  a VHS that had the same troubles. I need it desperately for the show I am working on. I tapped it on a table fast forwarded it and presto! Tape fixed, crisis averted. Thank you, Thank you, thank you.
Feb 28, 2008 | Televison & Video
VHS tape was playing . After stoping does not play. Other tape will play
The idler wheel (that only drives the tape in play or scan modes) is slipping too much (very common problem). Try verify this by putting the tape in play then immediately press the fast fwd or rewind buttons to scan the tape. On older machines, the idlers used rubber friction tires - on newer ones, a clutch. Either replace the tire or increase the spring tension on the clutch.
Hope Ya Fix It.
Jan 20, 2008 | Televison & Video
Video tape gets eaten on rewind
Does the machine play tapes well? Clear steady picture and all? No tracking bars? wavering sound? Tape chewing is generally a problem with a bad Capstan Pinch Roller, Associated symptoms are as above. Please do recheck or confirm if any of the above problems are also present.
Aug 30, 2006 | JVC HR-VP650 VHS VCR
Sony KSP-30 U Matic Tape (10-Pack) Logo
259 people viewed this question
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
