Question about Dell Dimension 2350 PC Desktop
Monitor Issue When I boot up the computer, the monitor will go through all of the start up procedures, but then there are flickers up and down the screen. Also, the screen will randomly turn off and on every few seconds. It gets worse when the mouse is moved. I tried another monitor and had the same results. Any ideas? Thanks!
  • 31 Answers
Your circutboard is fried. You need to have it replaced.
If this helps at all, please rate this as a FixYa. - Evolution
Posted on Jul 16, 2008
A few months ago my LG Flatron L1900R monitor started flickering when I boot up my computer. It has become worse, to the point where it now flickers constantly.
From the information desribed, this means that your CRT monitor is going dead. Unfortuntly, there is no way to stop the flickering unless the monitor was replaced. I hope this has helped
Jul 05, 2011 | LG 700M 17" CRT Monitor
Monitor won't start when I boot up - without a lot of fiddling!
First try to do monitor self test.Disconnected the blue cable VGA or white colour connector from monitor to the computer. Turn on the monitor and check if you are able to see colours or line on the monitor.Indicating self test monitor is working fine. If you are using Video card on computer connect monitor directly to onboard video and check. Good Luck.
Aug 19, 2009 | Computers & Internet
Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Aug 08, 2009 | Computers & Internet
Samsung 206bw Monitor Flashes/Flickers on and off
Set the Hrts to 60 in Display Properties in control panel
Jan 14, 2009 | Samsung 206BW Monitor
Is this a Software/Config/Hardware Problem ?
hmmm..sounds like a sleep or screen saver conflict...try booting up on Safe mode(F8) on turn on, and then see how that works. Set your screen saver for Never, and see what happens.
You may be hitting a thermal issue with your video circuitry.
Feb 18, 2008 | Dell Dimension 4600 PC Desktop
Monitor flickering and adjustment buttons locked
If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down ... This may also cause a flickering affect.
Distorted or skewed image on monitor. Issue: Distorted or skewed image on monitor.
Cause: This issue can occur from any of the below possibilities.
  1. Windows issue.
  2. Loose or defective cable.
  3. Refresh rate issue
  4. Interference.
  5. Bad monitor.
Solution: Windows Issue If your monitor has a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please see document CH000121 for software or setting related issues.
Loose or defective cable You may receive a distorted image when the cable is loose or defective. Disconnect the video cable going from the back of the computer and verify that no pins are bent, burnt or broken. Once verified re-connect the monitor cable.
Refresh rate issue If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down or across the monitor slowly or fast. This may also cause a flickering affect. Additional information about how to change the refresh rate can be found on document CH000558.
Interference A distorted image can be caused by magnetic or other types of interference. Verify no speakers, fans or other magnetic devices are close to the monitor.
Bad Monitor If the above possibilities have been checked it is likely that the monitor is bad. To verify this it is recommended that the monitor be temporarily disconnected and then connected to another computer. This can be a friends computer, a work computer, and/or a computer at a service center. You can also help verify a defective monitor by connecting another monitor to your computer. Note: Connecting your possibly defective monitor to another computer will in no way harm the other computer.
Good Luck/Please dont for get to Rate.Thank You.
Jan 17, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Monitor is failing to start although power is on
Sounds like you've got some blown capacitors on the internal hardware of the monitor.
Unless you are a seasoned computer hardware expert or electrical engineer I'd recommend you replace the monitor.
The capacitors that are blown are likely controlling the power aspect of your monitor, and aren't totally defective yet.
Most computer shops would not be able to repair your issue, due to lack of skills related to monitor repair. So you're going to find replacement the easiest / cheapest solution.
Of course you can try to ride out the problem as long as you can. But it will get worse over time.
Jan 08, 2008 | Xerox XA7-192i 19" LCD Monitor
Gateway lcd monitor
First, narrow down the problem to either the monitor, or to the computer itself. Either try the monitor on a spare or friend's computer, or try a known working monitor on your computer. I'd guess your computer is where the issue is at- it isn't booting the Operating System (MS XP or whatever O/S is present on the hard disk. if the computer is the issue, try booting from the CD which came with the computer, (assuming you have that CD). Or, you could see if some computer tech savvy person has a bootable floppy diskette. Basically a "no-boot" problem, can point to a number of problems: hardware issue (bad hard drive etc.), or an operating system problem.
Jul 10, 2007 | Gateway FPD1810 18.1" LCD Monitor
Flashing on and off
I would suggest trying another monitor to rule out your PC or monitor card. I would also check the video settings on the PC. Then assuming your cable/connector and video card are okay, it sounds like a lamp or lamp driver (a.k.a. ballast or inverter) issue. In other words, an internal issue that probably needs component-level troubleshooting.
Jan 08, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell Dimension 2350 PC Desktop Logo
108 people viewed this question
Alun Cox
