Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
Posted on Jul 16, 2008
Hobart lxih everytime i add soap i get a service code e4 and the machine stops shut the machine off and it restarts just fine add soap and shuts down i use a powered saop made for under the counter dishwashers even when i run a delime agent thru the machine it the does the same what to do thanks for help david
Anonymous
Level 1:
  • Contributor 38 Answers
  • Posted on Aug 20, 2008
Anonymous
Contributor
Level 1:
Answers
38
Questions
Helped
28732
Points
55
E4 indicates water level has not reached top water sensor. Check for proper flow-water pressure to machine (15-25psi) and clean sensor in wash tank
Hobart lxih heating water to 212 degrees and showing so on display
i would contact main office #937-332-3000 or Service Office 1-888-446-2278 .
Aug 02, 2013 • Dishwashers
How to fix door on hobart lxih dishwasher?
Check the door hinges.. if a hinge is broke or the door came off the hinge it won't shut.... now if the door won't stay closed then the tension bar that is on the door, connecting to the hinges is broke and you will have to replace it
1helpful
I have a PD code on a Hobart LXI dishwasher. What does that mean
PD is not an error code. It shows that when it draining water out shortly after power-up and when shutting down. If it seems to be showing "PD" longer than usual, it means the dishwasher's control circuitry believes there is still water in the tank, due to a faulty water level probe, most like the one under the lift-out screen. It has a plastic body with a metal probe coming out the center.
There is also a dual probe at the rear of the machine, but I believe the dishwasher uses the front probe to determine when to stop draining the machine during "PD" - most likely meaning "Power Drain" or "Power Draining".
If you are not seeing any E- codes (E1, E2, E3, etc.) then these water level probes are likely just fine and the "PD" is appearing normally, as it should during draining conditions.
Hobart LXIH dishwasher
You can add a small amount commercial dish soap to the wash chamber before pressing the wash button.
1helpful
When we push the Off button the machine won't drain and shut down? this is a Hobart LXIH machine. thanks,
Try disconnecting power from the unit either at the plug or the breaker if hard wired. Reconnect the power and turn it on. If the water drains, refills and operates as usual, your problem is likely a bad off button on the membrane switch. Let us know
4helpful
E4 error after attempting to fill and get to temp
This is what I found for the E4 code...hope this helps...and thanks for rating my effort...The Fang.
Machine won't fill or won't fill high enough(LX18, LX30 display shows "E0," "E2," "E3," or "E4")
1.Low water pressure — check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2.Make sure probes are clean.
3.No water pressure — main water supply valves may not be working.
4.Drain valve open - turn machine off to drain machine, then on. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the
OFF-ON procedure.
5. Delime machine.
3helpful
Hobart LX30 error code wrench & E5
What error code is displayed?e1,e2,e3,e4?I'm a hobart tech let me know.
Apr 10, 2009 • Dishwashers
5helpful
Dishwasher says delime on screen, how do i do this?.
Hold the delime button in and hit the on button for 5 seconds.It will then do a partial fill then it will say add delime,add delime shut the door and press the wash button.Let the machine do the rest it will turn itself off when finished.
2helpful
3answers
Hobart LX 30 P2 Error and unit overflowing!
Hi drogers77,
I'm not a Hobart technician, but here what I founded in my manual for the LX30 error message:
LX18 / LX30 display shows E0, E2, E3 or E4
1. Low water pressure - check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be working
4. Drain valve open - turn machine OFF to drain machine, then ON. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the OFF-ON procedure. If problem persists, call your local Hobart Service Office.
5. Delime machine.
Hope it will help you.
pepsicrazy
5helpful
2answers
E-5 error code and no draining or rinse cycle machine less than 3 months old
E5 is a drain error - machine is not draining - check drain hoses - pull out machine if needed - check air gap. hope this helps. jimmy.
Top Hobart Dishwashers Experts
vince
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
