Computers & Internet Logo
Posted on Jan 21, 2011
I just bought a Smead Viewables starter kit, but their software doesn't work on my MacBook Pro? Are there templates or other software I can use???
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jan 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
3257
Points
So sorry about the mixup - at this time the Smead software isn't MAC compatible. For basic lablels you could check out 3M, Avery or use a Dymo lable machine.
1helpful
Hi! My computer (Macbook pro) doesn't seem to recognize my Nikon Coolscan IV software and I get the following message
You've not said what the message is but I suspect that the software is too old to be used on the macbook if it is running OS X 10.7 (Lion) or if you are running snow leopard, it may be a non-intel version of the software. It may be asking you to instal rosetta which would be on your snow leopard instal disk.
If the Nikon website does not have updated software you could try vuescan which according to this page http://www.hamrick.com/vuescan/nikon_coolscan_iv_ed.html does work with the film scanner and you can download a demo version which you can trial before you buy. Hope this helps.
I just upgraded to the new software version for Viewables, now when I click on the Viewables program the welcome screen opens and freezes. I have removed/installed three versions(CD, web download, tech...
There may be a conflict with the new software and your hardware. Check the compatibility of the new software with your current hardware. Contact technical support for the software.
Unable to print from Windows 7
  • It sounds like you need to download your printer's driver.
  • You can go to the brand's support page on their website. There, search the model name, and look for the "driver" (it may be under the downloads section in the support site). Once you download and install that, it will work fine.
  • Please reply if you have any more questions. Good Luck! Please give 4 thumbs up if I helped, I am two votes away to becoming an expert!
7helpful
Smead Viewables will not print. I have a windows 7 operating system, is there any way to fix this?
We are sorry for the inconvenience that this has caused however, we do have a fix for the Window 7 64bit issue. Please use this link that I have provided to solve the printing issue.
http://www.smead.com/viewablesupgrade/download_viewables_40.asp
If you still have issues you can contact Customer Service either via email [email protected] or via phone 651-480-5624.
Thank you,
Joan
Technical Support Rep
When attempting ton print using windows 7 the system shuts down
I uninstalled version 4 and installed version 3 and it worked great on a WIN 7 64 bit machine.
Can i place a 4g and 2g stick in my macbook pro
Hello! The MacBook Pro you have mentioned can only support 4GB's total. 2GB's in the first slot, and 2GB's on the second slot.
What you may have seen by accident was that you can purchase either a 4GB kit, or a 2GB kit. Meaning a 4GB kit with 2 2GB sticks, or a 2GB kit with 2 1GB sticks.
Your best bet is to go with a 2GB stick in each slot to max out your MacBook Pro. 2GB's is the largest each slot can read.
For more information, check out the website below which has very detailed information on memory for various systems.
MacBook Pro Memory Information
5helpful
2answers
Smead Viewables for Macs?
I can run v3 of the viewables software using Win XP under parallels on my MacBook without any problem. v3 only supports a limited set of colors. Since I cannot download the current v4, I cannot test it. If someone of you can provide me with the v4 installer, I'll test this version too.
2answers
Visual Basic 6.0
1. IDE is Integrated Development Environment
2.With VB 6, one can develop applications with feature rich GUIs (Graphical User Interface). Many varieties of general purpose software can be created with little effort, including, but not limited to, image editing software, text editor and database applications.
3.Windows Application Template
Used to create Windows-based applications that run locally on users' machines. You can build anything from a simple single-window tool like Windows Calculator to a complete application with multiple windows and advanced capabilities.
Class Library Template
Used to create reusable classes or components that can be shared with other projects.
Console Application Template
Used to create command-line applications, programs that run from a Windows command prompt and have no visual interface.
My Movie Collection Starter Kit Template
Used to create the pre-built My Movie Collection sample application, which you can customize to meet your own needs. For more information, see Starter Kits: Getting Up and Running Quickly.
Screen Saver Starter Kit Template
Used to create the pre-built Screen Saver sample application, which you can customize to meet your own needs. For more information, see Starter Kits: Getting Up and Running Quickly.
4.FormShaper lets you change the shape that windows draws your forms. You can have rectangles, rounded rectangles, ellipses, polygons and any combination of the above! Even save the shapes to a file for use in other projects! See readme.txt in the zip file for more details
5.Description
Used at script level to force explicit declaration of all variables in that script.
Syntax
Option Explicit
Remarks
If used, the Option Explicit statement must appear in a script before any procedures.
When you use the Option Explicit statement, you must explicitly declare all variables using the Dim, Private, Public, or ReDim statements. If you attempt to use an undeclared variable name, an error occurs.
Use Option Explicit to avoid incorrectly typing the name of an existing variable or to avoid confusion in code where the scope of the variable is not clear.
Grand Canyon Tech
Grand Canyon Tech
