Question about Cameras
I have a sony camcorder CCD TRV68 & door for tape is "stuck" with tape inside. How do I eject/fix?
    Genius:
  • 1,447 Answers
Hi-
can you still turn the unit on? Turn it off, remove the battery for a few minutes and reinstall it. then turn it on and try ejecting it.
Hope this help
Posted on Jul 16, 2008
My TRV68 ejected a tape half ways and stopped. I removed the power source and then the tape ejected fully upon reconnecting the battery. HOWEVER, now the tape loads and then will not stay in - the camera...
This is a common problem often caused by a problem with the head/motor assembly. This is not a DIY repair. It is possible that this can be repaired without any parts. Expect to pay in the $150 range for labor.
Dan
Mar 30, 2011 | Sony Handycam CCD-TRV68 Camcorder
When i put a tape in it beeps then would not eject
Ether the tape is cought inside the camera or the eject motor is not releasing the tape inside try the following
1. Take battery out
2, put it back in and press the eject but with the camera up to your ear.
If you hear it trying to eject the tape got ate inside the unit best thing here to do is take it to a camera shop have them extract the tape.
Hope this does help please do make sure you rate before you leave.
Aug 17, 2010 | Sony Handycam CCD-TRV68 Camcorder
I have an older camcorder that hasn't been used in a while. When I went to try to view the tapes made on the camera, I just get a blue screen with a white play arrow. The tape is moving inside though. It...
The video drum inside the tape mechanism consists of two sets of heads. One set for recording and one for playback. It's possible the playback heads are damaged, in which case the video drum will need to be replaced. It's also possible the video drum may simply be oxidized in and the camera only needs servicing and the drum deoxidized. I don't reccomend using "cleanning tapes" as they can sometimes do more harm thab good although you try. You might get lucky and this will solve your problem.
Aug 03, 2010 | Sony Handycam CCD-TRV68 Camcorder
I get an eject symbol and beep and error code c32:11, original issue was that it ate a tape
The error C 32:11 denotes for mechanical unsuitability, This problem appears when the improper insertion of the cassette been done, or lose cassette tape stuck,
In all these situations mechanical adjustment is required, You are suggested to please contact any expert for the mechanical adjustment.
Hope you will understand my sayings.
Thanks for using fixya.
Jul 11, 2009 | Sony Handycam CCD-TRV68 Camcorder
My tape is stuck and I get error code c32:20 on my sony trv68 help!
remove ur mechanisum from ur camer and clean all conector wich connect with bord and mechanisum then re fix it will work
Jul 08, 2009 | Sony Handycam CCD-TRV68 Camcorder
How to transfer hi-8 tape to cd or dvd pls teach me
You can set the date and time by following the steps in the instructions manual which can be found by following the link below.
http://www.retrevo.com/support/Sony-CCD-TRV68-Camcorders-manual/id/763dj989/t/2/
Hope it helps,
~regards,
Jegan
Jun 03, 2009 | Sony Handycam CCD-TRV68 Camcorder
CCD-TRV68 hi-8 cam
Unit may have damaged loader mechanism, have it checked
May 13, 2008 | Sony Handycam CCD-TRV68 Camcorder
No power and does not indicate charging Problem
Sony camcorders C:31:23 error
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
good luck
please mark the post with a fixya
Mar 17, 2008 | Sony Handycam CCD-TRV68 Camcorder
Handycam CCD-TRV68 control panel/tape door acting like it died.
In order to solve this problem please order the control switch block (control pad) pn: 147642411. If you need more info please advice.
Mar 28, 2007 | Sony Handycam CCD-TRV68 Camcorder
Cameras Logo
66 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
