Question about Black & Decker 9072CTN Cordless Screwdriver
How to open a B&D 9019 screwdriver. is it just knock out the pins ? Can the pins be used again or must new ones be used
    Champion:
  • 313 Answers
Push the 2 pin out & careful when u seperate.gear's are made of plastic
Posted on Jul 26, 2008
How to remove the calipers on a 1993 ford e150? there are no bolts
there are slide pins on it, you have to knck them out, i have used a punch before otherwise there is a special tool to knock them out, they go back in the same way they came out, one on the top side of caliper and one on bottom side
Oct 22, 2010 | 1993 Ford Econoline
My old black & decker power screw driver will not accept a charge. I cannot get it charged up.
Black & Decker stopped doing battery packs for the older screwdrivers, like the 9018, some time ago so you cannot get them.
However you can still buy replacement NiCad, Sub C, 1.2v, tagged batteries that will do the job on the older 2.4v models as NiCad batteries for use in power tools are exempt under the European ban on importing NiCad batteries where used in power tools (Specific Exemption).
When you open up the screwdriver look at the positioning of the batteries and the tags/connectors and solder them together the same way.
So all you need is a soldering iron to join the centre tags together and then trim the end tags, top and bottom, to the width of the live/negative connectors and you have got a new battery pack.
It doesn't have to be pretty but after a small investment and a little effort it sure beats paying out £30 to £50 for a new screwdriver. I have done this for my older Black & Decker and Bosch screwdrivers which all work like new again.
Apr 08, 2010 | Black & Decker Pivot Plus Cordless...
Handtools > DRILLS/SCREWDRIVERS
These generally have a 2 year warranty and I'm sure these are well out of warranty. Afraid that they really aren't a repairable item as you'll probably find it will be cheaper to replace them. But call the Customer Service line all the same and they can put you in contact with the Service Centre in your area - 1800 444 224
Nov 10, 2009 | Drills
I DO NOT KNOW OR EVEN BEGIN TO FIGURE OUT HOW TO
Invicta watches either have screws or push pins. The one I sized yesterday had screws; it was tricky because I had to hold a flat head screwdriver on one side of the pin and then another screwdriver on the either side to unscrew it (this kept it from just spinning without loosening). If it is a push pin (you will know by looking because either a screwdriver will fit in the head or not) then you will need to get a thin steel rod about the width of a paperclip, a hammer, and a block that you can support the watch on. Push pins are pressure set and you just have to tap them out with a hammer by hitting the pin pusher/ steel rod into the pin hole to knock it out. Knock out the pins to the links you want to remove and then use a pin to resecure your watch band together.
Oct 21, 2009 | Invicta 8937 Wrist Watch
How to remove watchband links from an Invicta watch
Oct 20, 2009 | Lucien Piccard 26024 Wrist Watch
Dryer will not start. The circuit breaker is intact and the door closes tightly.
Could be the door switch or door pin not making contact with pin. Open the door, set the timer to run, now use a small screwdriver to press the door lock switch. If machine doesn't run then suspect switch, if it runs then check the pin on the door as something may have snapped. If all seems fine with the pin and handle and machine works with screwdriver then the switch may be loose and been knocked out of place. Door could still close tighly but not be getting switched on by pin.
Jul 07, 2009 | Dryers
Door sag
Hello, you need to replace the hinge pins and bushings. Just take a hammer and knock the hinge pins out and put the new pins with bushings in the hole and tap it into place. Some vehicles have a locking ring on the bottom of the hinge pin just knock it off with your hammer and a screwdriver. They don't have to be replaced but, if you want the dealer sells those too. Good luck and any questions please ask.
Jan 23, 2009 | 1999 Chevrolet Tahoe
Remove the pins on a B&D electric screwdriver 9019, to remove the cover and to change batteries
use a end of a small nail to tap it on thru'. replacement is just the reverse [don't need new pins if you are careful!]
Jun 21, 2008 | Black & Decker 9072CTN Cordless...
I have a Timex Ironman Triathlon Speed + Distance...
The Timex Ironman manual and website says to take the watch to a repair facility. Nope! Do it yourself!
How to replace the battery in a Timex Ironman watch:
This is easier if you remove one of the rubbery wrist bands.
1. Take note of the position of the metal back cover. You'll need to reinstall it exactly as you see it in order to hear the alarm.
2. Remove the four screws that hold the metal back cover, and pry off the cover.
3. There is a round metal clip that holds the battery in place, covered with a transparent plastic cover which likely says, "Unlatch to remove battery". Within the center of each clip, there's a small opening just large enough for a straight pin to be inserted. A jewelers screwdrive won't work - use a straight pin. Insert a straight pin into the tiny opening at the edge of the clip, and wiggle it. The clip should release. You'll only need to unlatch one side of the battery retaining ring.
4. Gently pry up the batter retaining clip, then pry up the battery. Insert new battery.
5. Replace the clip.
6. Insert a flat blade screwdriver into a slot which has two "electrodes" or pins - they need to be shorted with the screwdriver to reset the watch. Just touch the screwdriver blade across the two pins to short it.
7. Reinstall the back cover but be sure to position the cover so the alarm sounding place ( a small disc attached to the inside back cover) will reside over the sounding spring.
8. Insert screws.
Dave
Oct 01, 2007 | Timex Sports Ironman Triathlon 100-Lap...
Black & Decker 9072CTN Cordless Screwdriver Logo
382 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
