Question about SanDisk Sansa c150 MP3 Player
Frozen MP3 My MP3 player is frozen on one of the songs I've been listening to. I press pause to go to the bathroom when I returned I pressed pause again. I have taken out the battery for over two days now and have tried a different battery and the same song in pause still shows.
  • mudflap68 Aug 04, 2008
    Same problem for me. I connect it to the computer and it only shows it stuck on the same song. It's never recognized by the PC.
  • Obstacle Sep 19, 2008
    I also have a Sansa c150, frozen on a track. Symptoms:
    * When powered on, the SanDisk logo appears for a few seconds, and then the display shows that the c150 is frozen x minutes and x seconds into a track.
    * After it freezes it does not respond when any key is pressed.
    * The battery level (shown with the frozen track info) is low/red even if I put a good battery in it.
    * If I put a low battery in the c150 and power on, it shows "Low Batt" and powers off.
    * The only way to power off is to pull out the battery.
    * The firmware update downloaded fromhttp://www.sendspace.com/file/7ge9cr fails to install (it takes several minutes to reach the failing point). The error message shown (on the PC, not the c150) when the firmware update fails is too long and cropped off by the window which cannot be resized.
This isn't a full solution yet, but I found on rockbox.org the instructions for putting the c150 into "Production Test" mode: insert the battery into the c150, simultaneously press and hold "volume down (left end of volume bar)" and "AB (the bottom portion of the ring-shaped button)", and then press and hold the "menu (power on)" button for two seconds. The display will then show "Production Test" and "MENU Key to Continuou" [sic]. Press the "menu (power on)" button, then you get to choose between "Test 1" and "Test 2", use the ring button to choose which one you want to run. You will need to connect the c150 to a computer using the USB cable for "Test 2" (it doesn't matter that the PC does not recognize the c150). My c150 passes both "Production Tests", but when powered on normally, it is still frozen stuck on the last track (see my post above).
The webpage for the c150 on rockbox.org also provides a link to another firmware update (v2.0.008A), which needs to be installed using "tcctool". I tried this, and was able to install the v2.0.008A firmware (apparently successfully, no error messages), but this firmware update does not fix the frozen track problem, and it also changes how Windows XP recognizes the c150. Windows XP now recognizes the c150 as a "libusb0" device and not as a "USB TCC77x" device as it did in the past. It seems that tcctool makes changes in the Windows registry which causes Windows to recognize the c150 differently. I haven't messed with the registry to try to restore the previous TCC77x device manager.
Posted on Sep 20, 2008
  • 42 Answers
Connect it to the computer and reformat it.
Posted on Jul 16, 2008
How do you restart an Ipod?? I was trying to
IF IPOD ISN'T FROZEN.
  1. Hold the Power button until you see the "Slide To Power Off" slider.
  2. Let go of the Power button, and slide the slider.
  3. Wait until it turns off completely, press the Power button again to turn it back on.
IF IPOD IS FROZEN.
  1. Press and hold the power button and the square home button at the same time.
  2. Wait some time it will reset eventually.
  3. Be patient.
Hope this helps - good luck!
Sep 17, 2009 | Apple iPod touch
Frozen
press the MIDDLE BUTTON and MENU button at the same time
or
press PLAY and the MIDDLE BUTTON at the same time till you ipod resets
Jul 02, 2009 | Apple iPod mini 2nd generation MP3 Player
IPOD FROZEN
Try doing this: Toggle the hold switch and put it back in the off position. Then press and hold the center button and the menu button simultaneously for ten seconds and the apple symbol should come up on the screen. Then it should work like normal. Hope this helps!
Apr 07, 2009 | Apple iPod nano
Music mode screen is frozen after listening to FM radio
press the middle button and the power button for q0 seconds
Oct 11, 2008 | SanDisk Sansa e260 MP3 Player
Frozen screen
Get the firmware upgrade from iRiver website
Jun 26, 2008 | iRiver H10 MP3 Player
Help Me!
Try pressing the reset button next to the USB connector on the bottom of the player with a thumb tack or paper clip.
Jun 17, 2008 | Disney Mix Max Digital Media Player
My mp3 player is frozen
Plug it in to the computer with the USB cable, use a paperclip to push the reset button inside the top hole, and then press the power button.
Feb 26, 2008 | Memorex MMP8565 MP3 Player
Philips Mp3 PSA610/05
press the pay/pause and up buttons simultaneously, it should shut down, then restart normally
May 15, 2007 | Philips PSA610 MP3 Player
I won´t turn on/off
hi, i'm from chile and i don`t speak much english, but i'll try to help you, because i think i've the aswer by my experince. when i was listening some song, and press for the next song, my MP4256FM frozen and i can't turn it off or nothing like that. after many times that i put play again the same song and frozen again, i understand that the MP4256FM will not read any song that in his name have a X,?,?,?,?, or ? (example axel.mp3 or introduci?n.mp3). So you have to change the name of the song on your pc and the ploblem will solved. I hope that this help you. bye! =) Jonathan Zu?iga el.zunhiga@hotmail.com
Jan 10, 2007 | Audiovox MP4256FM (256 MB) MP3 Player
Open Questions:
SanDisk Sansa c150 MP3 Player Logo
152 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
