Question about Gateway GT5220 PC Desktop
Burner disc software
My disc burner software has somehow been uninstalled, What can I do?
  • 137 Answers
If it came preinstalled, you can go download it again from manufacturer's website. If you have the disc, then reinsert the disc in tray and follow instructions to install onto hard drive.
Posted on Jul 16, 2008
Hello sir my dvd ram is not writing properly. after writing 5-6% of disc it stopped autometically. and my disc distroyed.
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then restart your computer then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you will have options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
you might uninstall your burning software restart your computer then reinstall the burning software
or scroll to the bottom taskbar/toolbar right click select taskmanager applications also,processes you can see what's running during a burn if youre willing to waste a disc
please do one thing at a time then check to see if it has resolved the problem
you might have bad batch of rw discs
or you might uninstall then restart your computer then reinstall your burning software if you have a disc for it
Feb 02, 2011 | LG (GCC4521BK) CD-RW/DVD-ROM (Combo)...
I have a Tdk burner worked fine until my husband had his buddy install some other burning software now my burner doesn't read there's a cd in it and it keeps opening up...still looking for original tdk...
Installing different burning software should not really affect reading capabilities of the burner. Nevertheless, it is not recommended to have two burning software packages on the same computer.
You can try uninstalling the new software that was installed on your computer, the reboot the system and check if that worked. If Windows does not open the disc automatically, you can go to My Computer and access the disc by double clicking on the TDK drive.
If you continue to have the same problems, please make sure the DVD burner is connected properly to the computer.
Aug 21, 2010 | TDK (aid+420blkb) Burner
My drive will not burn dvd-r anymore but it used to, it burns cd-r and reads discs no problem, but now when i try to burn the disc spins but makes a strange knocking noise.
sometime it has more to do with the driver software than it does with the unit itself.
Try uninstalling the writer software, restart the computer, reinstall the software, restart the computer, and attempt burn again. Software occaisionally gets confused and needs to be "rebooted" from time to time. Hope this helps.
Oct 12, 2009 | BenQ DW1670 Double Layer 16 DVD RW IDE...
Is the burner in my computer broken?
sounds like the head in the burner is off or has been jarred out of alignment somehow its probably cheaper to replace it than to have someone service it ......check to see if the burner ur using has been selected in the software options menu first...you'd be wasting time and money if it was something that simple
Sep 28, 2009 | Acer Computers & Internet
Sony DRU 510A wont burb discs
if any error come that means your writer is ok only circuit loose
Jun 18, 2009 | Sony DRU 510A DVD±RW Burner
Disc burner or software not found
U must be using vista. So uninstalling the scanner or try system restore to time before u installed the scanner(hopefully that is vista compliant) and see if u can burn ur discs, if you can, then there is a resource conflict after installing the scanner, which can be chaged on the drivers--properties--resorce tab..........sodeep
Mar 28, 2009 | Dell Inspiron 530s Desktop Computer
Software downgrade or uninstall messes with driver, throws **DVD** copy/write into PIO
1) I've discovered over the years that disabling the 'auto-protect' mode on the anti-virus while burning speeds up the process.
2) Try uninstalling the BURNER software instead of anything else, I got a laptop in my shop the other day with SLOOOOooow burn (if at all) process, by uninstalling and installing another burn software (Roxio instead of Nero for example), tends to alleviate the problem.
Hope this helps.
Aug 30, 2008 | Microsoft Windows XP Media Center Edition...
Won't burn picture image
http://www.liteonit.com/global/index.php?option=com_content&task=blogsection&id=9&Itemid=69
if you can copy an image ( alone- nothing else waste a disc here) as a data file it's the software - uninstall and re-install it--- if you cannot copy the image as a data file , it's the software in a different capacity and may you need firmware from the link - I would uninstall the device in device manager and then let wizard find it on a re-start
Jan 15, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Will not write dics
What burning software are you trying to use? Also, try uninstalling and reinstalling the hardware from Device Manager
Nov 15, 2006 | Mitsumi (CR-4804TE) CD-RW Burner
Gateway GT5220 PC Desktop Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
