Question about HP Pavilion dv1000 Notebook
Charging cable gets hot, charge port too, not battery though
So, when I plug in my HP Pavilion dv1000 laptop, the power brick gets really hot, and so does the port where the cable plugs into the computer. The battery, however, still holds a charge and does not get hot. The fan is still running as it should, and I've had no shutdown problems. Could this be a capacitor problem, a sensor issue, or anything else I don't know of? Thank you.
  • 42 Answers
No it is not a problem. The power dissapiation in the adaptor causes it to become hot.
Posted on Jul 16, 2008
My hp dv1000 power cord goes on and off from charging mode to battery, is the power port the problem?
Alot of laptops have the same problem. Power ports and the plugs get wiggled around and they eventually get loosened up. It is most likely the problem. Try holding it in a position that you know it's charging and the let go and see if its still charging or not.
Mar 25, 2011 | HP Pavilion dv1000 Notebook
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
My hp pavillion dv1000 wont turn on it is plugged in but the charging light doesnt show up and when i push the power button nothing happens
Problem with your charger, try this :
1. Check whether the charger plug is properly inserted in the Power port/jack of your Laptop!
2. Check the power cord (any cuts OR torn-out)!
3. If above steps don't work, replace your charger.
Jan 02, 2010 | HP Pavilion dv1000 Notebook
Battery is working fine but laptop is unable to charge the battery
If the battery is definatly not faulty, and the laptop won't charge it, then I would assume the charging circuit is faulty. As they are built in to the motherboard that would need replacing.
Nov 21, 2009 | HP Pavilion dv1000 Notebook
Hp dv1000 won't power up running on power cord or battery
PLease check both of them. First check the power cord by replacing the power cord and see if its charging or the battery and see if it is charging.
Thanks
Aug 13, 2009 | HP Pavilion dv1000 Notebook
My HP DV1000 will not start.
You have a power issue. The board is not charging the system or the battery. If you know someone with a similar model, ask them if you can borrow their battery and see if your system boots with it. If it does, you may need a new adapter or the power board in the notebook is out. When you remove the battery and try it, there's enough juice to power it up for the moment, but not sustain it.
Nov 19, 2008 | HP Pavilion dv1000 Notebook
HP pavillion dv1000 won't charge
Try using your laptop without the battery and just using your power supply (new universal or your old one).
If your laptop works on just mains power it means your battery is causing the problem, which is not unusual.
Aug 07, 2008 | HP Pavilion dv1000 Notebook
Battery life is very short
Not really. What happened is you shorted the life of the battery by always having it plugged in and in a charging state. The battery has a memory and since it's always been plugged in, it will never charge fully. There are products out there that will drain your battery down and reset the memory issue. But it would be cheaper to get another battery. If you are going to keep it plugged in the majority of the time, charge up the battery and remove it.
Jul 25, 2008 | HP Pavilion dv1000 Notebook
HP Pavillion power link blinks
aa505 -
I can almost guarantee you this is an issue with the power jack on the laptop's motherboard. Even though it may not appear to be loose, its most likely the solder connection on the motherboard has broken, only allowing intermittent connection when the laptop is in /just/ the right position.
It'd be best to get this looked at sooner rather than later, preferrably if the computer is still under warranty. The connection will steadily decline, until the laptop is unusable.
Otherwise, let me know if you want to get rid of the system! I have a system, almost exactly the same model, that I need parts for!
Hope this helps!
-thinstatic
Jun 12, 2008 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
256 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
